Need help with Identifying this corrosion
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mbarbay, Jan 27, 2021.
  1. Jan 27, 2021 at 6:53 AM
    mbarbay
    mbarbay [OP] Well-Known Member
    Baton Rouge, LA
    2016 Tacoma BBP DCSB LTD 4X4
    I was underneath my truck, just inspecting it, and saw this what looks like pink chalky corrosion similar to what you would find on a battery terminals, but this is no where near the battery.
    any ideas as to what it is? also should I be concerned and take it to the dealer ( i have an extended warranty).
    for what its worth, the truck is a '16 3.5L with a little over 82k miles
  2. Jan 27, 2021 at 6:55 AM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    That’s a coolant leak, take it ASAP.
    Markcal, Skydvrr, TomTwo and 8 others like this.
  3. Jan 27, 2021 at 6:56 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Looks like dried coolant to me too.
  4. Jan 27, 2021 at 7:02 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Yes check coolant level just to CYA, but it's probably not very low, as that's a small leak, but still needs addressed.
    Junkhead and mbarbay[OP] like this.
  5. Jan 27, 2021 at 7:10 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    That's not good when the rear of the engine is leaking coolant like that...
    Skydvrr and mbarbay[OP] like this.
  6. Jan 27, 2021 at 7:14 AM
    mtip
    mtip Go Outside & Play!!!
    South Louisiana
    18 TRD Sport 6MT 00 Tundra 5MT
  7. Jan 27, 2021 at 8:02 AM
    mbarbay
    Baton Rouge, LA
    Thanks guys.
    I do remember seeing my coolant low at like 20k miles or so, I was told that it was nothing. filled the reservoir and haven't had an issue since. I just checked and the coolant is lower than full, but still not considered low..I should be good for a few days until I can get to the dealer.
    Junkhead likes this.
  8. Jan 27, 2021 at 10:26 AM
    TnShooter
    Deogee
    STOCK
    Yeah, you’ll probably be fine.
    As crusty as that looks, it’s been leaking for a while.
    Looks like it’s a slow leak.
    I probably wouldn’t miss a days work over it.
    Keep an eye on the coolant level and get it checked out when you have the chance.
    MannyS and Chew like this.
  9. Jan 27, 2021 at 10:42 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    Did the dealer tell you this? Was there a service order written up? Hopefully
    If so, you may be able to argue it was leaking and not repaired correctly, while under warranty. I'm not saying it's a slam dunk,,,, but I'd make a case. I had to make a similar claim, when my work truck ate it's own diesel engine alive. It was a very short conference call between our CEO and the Ford service manager, when he pulled my service records,,,,, ok thanks guys, and sorry to take your time,,, I'll let you know when we're done, but it's a very big job, so it'll be week or so.
  10. Jan 29, 2021 at 5:35 AM
    mbarbay
    Baton Rouge, LA
    the first time I noticed it (@around 20k miles) I did bring it to the dealership completely pissed that they didn't notice that it was low during my last service...there may or may not be a write up in the system for it...but I do have the extended warranty, so I should be still good...I doubt (but honestly wouldn't be surprised) that a coolant leak wouldn't be covered by warranty...they better not pull some "wear and tear" shit...
  11. Jan 29, 2021 at 5:39 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    Hopefully they take care of you either way. Oh well, Lessoned learned, you have get every instance documented, ,,,,, the dealer isn't going to do it unless you ask.
  12. Jan 30, 2021 at 4:03 AM
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    Many higher mileage V6 3rd gens have this minor seepage issue.
    Many owners are not aware of the issue because there are no drips and you need to get under the truck in order to view the pink coolant crust buildup in a specific engine area.
    Some high mileage four cylinder Tacoma engines have a similar issue with the plastic bypass hose buried under the intake area.
  13. Jan 30, 2021 at 5:45 AM
    trktwo
    trktwo Nagger
    tommy
    biloxi
    2015 MGM DCLB TRD Sport 4x4
  14. Jan 30, 2021 at 6:01 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Hopefully not the rear bypass :fingerscrossed:
  15. Jan 31, 2021 at 11:16 AM
    flatus
    flatus Well-Known Member
    biloxi,ms
    2020 TRD OR DCSB 4wd Auto
    Waiting for bank account to grow
    I hope not
