Need help wiring to license plate lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by crunchytaco13, Aug 15, 2020.
  1. Aug 15, 2020 at 11:05 AM
    crunchytaco13
    crunchytaco13 [OP] Well-Known Member
    ‘17 PRO MT Cement
    TRD CAT
    hey everyone, I'm installing a rack in my bed that needs to tap into the running lights or license plate lights positive wire.
    Can anyone point me in the direction of a thread that covers this, or give a diagram of which wires are which, and where they are?
  2. Aug 15, 2020 at 11:11 AM
    crunchytaco13
    ‘17 PRO MT Cement
    TRD CAT
    @Shellshock do you know anything about this? If there's something I can tap into to have constant running light power in any of the wires in the brake light housing, that works too.
    I just need constant power in the rear of the truck
  3. Aug 15, 2020 at 11:45 AM
    Shellshock
    Iowa
    What’s the power being used for? If you are just running lights, most people just tap off the tail light or the 7 pin
    if you need constant power for fridges or other things, you’ll need to pull a wire from the battery
    Tullie D likes this.
  4. Aug 15, 2020 at 12:42 PM
    crunchytaco13
    ‘17 PRO MT Cement
    TRD CAT
    No need for extensive power, just running lights. Do you know which wires in the tail light housing is positive?
  5. Aug 15, 2020 at 12:47 PM
    Clearwater Bill
    Billy
    Largo Florida
    A DVM or even a simple test light will make quick work of that for you. Basic tool kit stuff you'll use often (if you don't have one now)
  6. Aug 15, 2020 at 12:48 PM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    Here's the pin-out of the 7 way connector.
    Shellshock likes this.
  7. Aug 16, 2020 at 1:36 PM
    crunchytaco13
    ‘17 PRO MT Cement
    TRD CAT
    awesome thank you. So I can just tap into the wire that corresponds to the brown #3 in that diagram above?
  8. Aug 16, 2020 at 1:44 PM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Won't Tail/Running be switched with the stem? Is that what you are after?
    G.
  9. Aug 17, 2020 at 6:39 AM
    crunchytaco13
    ‘17 PRO MT Cement
    TRD CAT
    Im not sure what you mean by that - can you clarify what the stem is?
  10. Aug 17, 2020 at 7:18 AM
    Garyji
    Gary
    The light switch on the steering wheel column. Where the blinkers are. Commonly referred to as the stem.
    G.
  11. Aug 18, 2020 at 6:29 AM
    crunchytaco13
    ‘17 PRO MT Cement
    TRD CAT
    gotcha, yea that’d make sense actually. Will tapping into the wire mentioned above make that happen?
  12. Aug 18, 2020 at 6:32 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Get a test light and verify it.
    Garyji likes this.
  13. Aug 18, 2020 at 7:36 AM
    Garyji
    Gary
    What Skydvrr said. Think of it this way; If you were towing a trailer, the trailer lights would be controlled by the "stem" switch. Tapping into any of those wires will give you the same result as your selection on the switch.
    ie. lights on, equals trailer running lights on, etc.
    Not sure if #4 is always hot or not. Just check it.
    G.
  14. Aug 18, 2020 at 7:38 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Stalk not stem
