Need help, wheel bearing assembly stuck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ashjwilliams, Aug 18, 2018.
  1. Aug 18, 2018 at 3:53 PM
    ashjwilliams
    ashjwilliams [OP] Well-Known Member
    Replacing front wheel bearing assembly on 2010 Tacoma 4x4 V6. Got the 35mm nut off, 4 captured bolts holding the assembly in place are loose. This thing is stuck hard. I have maybe a 2-3mm gap all around now but its still sticking. Borrowed a slide hammer from autozone, its not getting it done. Can i shoot PB blaster in the spline area? Is this thing liked corroded onto the spline and thus I'm pulling on the CV axle?
  2. Aug 18, 2018 at 3:58 PM
    Longboard1110
    Longboard1110 ...................
    San Jose
    A few things
    A 3 jaw puller should get it done, local auto parts store should have one.
    ashjwilliams[OP] and Hartford like this.
  3. Aug 18, 2018 at 4:04 PM
    ashjwilliams
    I have a slide hammer bolted up to the assembly. I am starting to feel like imma break this thing.
  4. Aug 18, 2018 at 4:19 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Unscrew the 4 bolts behind the hub to push it out against the hub
  5. Aug 18, 2018 at 4:20 PM
    ashjwilliams
    Thats how i got it started earlier. Then i got the slide hammer. I will go back to that.
  6. Aug 18, 2018 at 4:32 PM
    Bogg
    Bogg Well-Known Member
    Surrey, Canada
    07 TRD Sport 4x4
  7. Aug 18, 2018 at 6:21 PM
    ashjwilliams
    Ahhh...i see what you mean. When I saw this post I thought it was an attachment for the slide hammer, which I didnt think would help me. Yeah i will try this tomorrow.
    Longboard1110[QUOTED] likes this.
  8. Aug 18, 2018 at 8:21 PM
    ColoTacoPrerunner06
    ColoTacoPrerunner06 Truck of my dreams
    Speedway Blue 06 Prerunner built like I like it.
    5.5 lift front 4 rear on 33s with an endless amount more work to do
    You can also take a towel and tie it to the weight on the slide hammer and use the length of the towel to amplify force. Watched my technicians do it for years. Instead of 10 tries it takes 3.
  9. Aug 19, 2018 at 7:01 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    I just kept hitting mine at each rear corner with a BFH until it broke lose.
  10. Aug 19, 2018 at 7:05 AM
    ashjwilliams
    Hallelujah...this thing would have never come off without the 3 arm puller. I had to put 2 wrenches on that even. But its off, and surprisingly looks pretty good/clean. Time for breakfast. Hopefully I dont have a lot of problems grtting it back together now (looks at spline).
  11. Aug 19, 2018 at 7:08 AM
    ashjwilliams
    Sorry for the double post btw, I wasnt sure how much action I would get in the marketplace area. Had to get this done before Monday.
