Need Help. Starter, Single Click without start.
Discussion in '1st Gen. Tacomas (1995-2004)' started by bfinan, Nov 24, 2019.
  1. Nov 24, 2019 at 4:28 PM
    bfinan
    bfinan [OP] Member
    2000 Tacoma Pre-Runner v6 3.4L
    Situation:
    I was out getting groceries and stopped at a market. Everything seemed normal.
    I turned the key and heard a single click. Nothing else happened.
    1. Tried my Noco Jump box: Single Click, no start.
    2. Tried to jump from a car after charging for a bit: Single Click, no start.
    3. Got the truck home. Tested all fuses and starter relay: Single Click, no start.
    4. Tested Battery: 12.5 V no load 11.6 V while trying to crank: Single Click, No start.
    5. Pulled Starter replace contacts: Single Click, No Start.
    6: Replaced Starter (O'Reilly's, only place in walking distance) : Single Click, No Start.
    7: Replaced Battery (O'Reilly's): Single Click, No Start.
    8: Turned Crank Shaft to make sure nothing crazy was up: Single Click, No Start.
    9: Voltmeter to check for current with solenoid wire: Looks Good
    10: Tested relay, Good. And can feel it click when I crank: Single Click, No start.
    The single click is loud and coming from both of the starter solenoids (trying to engage?)
    What am I missing? So frustrated.
    Thank you for any help.
    Benjamin
    wilcam47 likes this.
  2. Nov 24, 2019 at 5:01 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    I'm putting my two pennies on the starter contacts not being able to hold the plunger pulled due to corrosion and pitting. The original starter that came on these Tacomas is a high quality Denso unit. The bearings, construction in general is good stuff. I definitely recommend replacing the starter contacts and the plunger if the starter is a Denso. If it's a crapped out parts store reman on your taco than I'd recommend replacing with a reman unit from Toyota. The point is that it's very easy to stay away from the crappy ones. That's what I recommend :D
    Edit: sorry man I thought those were a list of what you wanna try next. My bad. I'll reread in a new light lol:rofl:
    bfinan[QUOTED][OP] likes this.
  3. Nov 24, 2019 at 5:23 PM
    bfinan
    bfinan [OP] Member
    It's a great idea. And step 5 of what I have tried so far. So now I have a sweet rebuilt starter that only clicks. I am starting to think that step 9 may be the culprit. High resistance in my starter connector wire, the small one. Though I am going to need to recruit another pair of hands to help me jump it. Unless I can wire up one of my ham power supplies to it. Leave my ignition on and just flip the switch to my power supply for a second.
    Again, not sure. But thank you for the suggestion.
    cruiserguy likes this.
  4. Nov 24, 2019 at 5:47 PM
    cruiserguy
    Elijah
    SEKS
    Oh you've already replaced the cibtacts
    Yes it's acting as if it's not getting full voltage to the starter. I agree
  5. Nov 24, 2019 at 5:52 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    How do the battery clamps and cables look? Any corrosion?
    Wyoming09 and bfinan[OP] like this.
  6. Nov 24, 2019 at 5:55 PM
    Catcrazed
    Catcrazed Love is Dogs and Toyotas
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    91 Flatbed, 4.88's, ARBs, SAS, 3.4 Swap, 35s, M8000, lots lights, Aux tank, Protech
    Ignition switch?
  7. Nov 24, 2019 at 6:30 PM
    bfinan
    bfinan [OP] Member
    The battery cables look good, the starter (S terminal) connector and wire was coated in grime and stuff from snowy roads. Maybe 19 years of stuff finally built up in the connector and convinced it to stop trying. Pulled all my grounds and cleaned and reconnected them, though they all looked okay.
    Giving up for the night. The next plan is to remove the connector wire and find a way to jump the terminal as a friend cranks it...
  8. Nov 24, 2019 at 6:32 PM
    cruiserguy
    Elijah
    SEKS
    If you have an ohmmeter you can see if the resistance is excessive
  9. Nov 24, 2019 at 6:33 PM
    bfinan
    bfinan [OP] Member
  10. Nov 24, 2019 at 6:36 PM
    bfinan
    bfinan [OP] Member
    I do! I've learned a lot about it today. I didn't realize it had a min/max function until today. To test this, do I have to stick one probe in the connector and the other where ever the other end is? How much is too much? Do I just do the whole V = IR and look for a resistance that would drop the voltage less than... 2.5v or so?
  11. Nov 24, 2019 at 6:48 PM
    cruiserguy
    Elijah
    SEKS
    I wouldn't imagine you should have much resistance at all. Yeah one probe on end and other on other end of cable.
    You could also probe the positive and negative at the starter while someone turns key to make sure you have 12V getting there
  12. Nov 24, 2019 at 6:49 PM
    cruiserguy
    Elijah
    SEKS
    If the resistance is too high less than 12V will be getting there
  13. Nov 24, 2019 at 6:50 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Bad battery
    TWJLee likes this.
  14. Dec 20, 2019 at 7:33 AM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    Well how’s it going you get this figured out?
  15. Dec 21, 2019 at 8:35 AM
    Glamisman
    Glamisman Well-Known Member
    check the ground cable where it bolts onto the block. It sure sounds like you have bad cable(s) / connections.
    Wyoming09 likes this.
  16. Dec 21, 2019 at 10:40 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Just because all the connections look clean and tight does not mean the cable can not be corroded under the insulation to the point it no longer conducts enough
  17. Dec 21, 2019 at 12:09 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Try to turn the crank pulley
  18. Dec 21, 2019 at 12:14 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    OP has tried that already!
  19. Dec 21, 2019 at 12:15 PM
    Area51Runner
    Didn't see that... Oops
