Need help selecting a lubricant for uniballs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TACOtrd1106, Dec 17, 2015.
  1. Dec 17, 2015 at 4:33 PM
    TACOtrd1106
    TACOtrd1106 [OP] Well-Known Member
    Cali
    2012 Black TRD 4x4
    Can anyone one guid me to right one?
    Thanks
  2. Dec 17, 2015 at 4:35 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
  3. Dec 17, 2015 at 4:38 PM
    slcsez2000
    slcsez2000 Well-Known Member
    St Aug, FL
    12 TRD Sport 4x4
    Exterior: -Current Suspension- Icon extended travel front struts w/ 700lb coils Icon extended travel Remote Resi rear shocks Dakar leaf pack Icon Tubular UCAs with covers Icon neoprene shock covers -OEM Roof Rack -2 fold down cup holders in bed -Bed bottle opener -Access lite rider roll up tonneau cover -AFE Prodry air filter -Pop and lock bed lock -Rear differential breather relocation mod (behind tail light) -Aeroturbine 2525XL Muffler Armor: -SOS Concepts bolt on sliders W/ kick out -SOS Concepts aluminum front bumper with full hoops -SOS Concepts Rear HC Bumper -SOS Concepts IFS/Mid skids
    Everyone is going to tell you not to lube you uniballs cause it will attract dirt
    With that said I have the icons with the dust cover caps so mine aren't as exposed
    I use the dry lube tri flow. Have had the caps on and covered with the tri-flow a year ago. Took the caps off a couple months ago and they looked like new. Wiped em off, squirted some more in and slapped the caps back on.
    Over and out
    Alfred likes this.
  4. Dec 17, 2015 at 4:39 PM
    TACOtrd1106
    Cali
    2012 Black TRD 4x4
    Thanks man
    GHOST SHIP[QUOTED] likes this.
  5. Dec 17, 2015 at 4:43 PM
    TACOtrd1106
    Cali
    2012 Black TRD 4x4
    Thanks for that info. I got the same ucas with the dust cap. My first question to you is, how often should I lube them? When I remove the caps, should I apply a new adhesive to the caps, or will I be fine just putting back on with the same adhesive. My Last question is am I suppose to lube the underside as well?
    Thanks!
  6. Dec 17, 2015 at 4:48 PM
    GHOST SHIP
    GHOST
    I have the same UCAs. You shouldn't need lube too often. I've heard guys adding that to the maintenance list for when they do the oil change and I've heard others never doing it at all. So really it's a case-by-case scenario. Apple valley is a lot of dust/dirt, but since you have the caps, you should be ok. You also should not need to do the underside. The best advice I heard was to use the dry lube. Let it dry, wipe off the excess and replace your caps (using new double sided tape like 3M for outdoor use)
  7. Dec 17, 2015 at 4:54 PM
    TACOtrd1106
    Cali
    2012 Black TRD 4x4
    Thank you for the advice:thumbsup:. I just needed to be sure on how to go about the ucas, I just found out that my coilover is leaking so I got to get that fixed
  8. Dec 17, 2015 at 5:31 PM
    tonyt915
    tonyt915 Well-Known Member
    My Name Is Toby!!!
    Tomball, TX
    2010 TRD Off-Road
    Pelfreybilt front bumper, SOS skis plates and rear bumper, Icon extended travel coilovers, Icon 2.5 w/resi's rear shocks, Dakar lead springs, Warn 9.5ti winch, Oem roofr rack
    Ive put about 40k miles on my Camburg UCAs and not one squeak. Found some stuff called DriSlide at a motorcycle shop that was like $30 for a 4oz bottle but its a dry moly lube and works amazing
  9. Dec 17, 2015 at 5:35 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    KY.
    jmaack likes this.
  10. Dec 17, 2015 at 6:47 PM
    slcsez2000
    St Aug, FL
    12 TRD Sport 4x4
    You will have to replace the adhesive. I have only lubed mine once in a year. I however spray my whole suspension setup with a lube to keep everything from rusting, including the ucas and underside of the uniballs.
    Here is some info on the dust caps where I took pics one year later.
    https://www.tacomaworld.com/threads/icon-tubular-uca-caps.368936/
    And see my posts here and follow up of spraying my whole setup with lube
    https://www.tacomaworld.com/threads/king-vs-icon-vs-fox-racing-coilovers.203714/page-25#post-9670354
  11. Dec 17, 2015 at 7:09 PM
    TACOtrd1106
    Cali
    2012 Black TRD 4x4
    That was very informative!
    I'm going to try some of that t-9
  12. Dec 17, 2015 at 7:18 PM
    slcsez2000
    St Aug, FL
    12 TRD Sport 4x4
  13. Dec 17, 2015 at 7:29 PM
    TACOtrd1106
    Cali
    2012 Black TRD 4x4
  14. Dec 21, 2015 at 12:07 PM
    TACOtrd1106
    Cali
    2012 Black TRD 4x4
    I finally got the tri flow through Amazon, realized that it's not the dry lube. Is it okay to use it even though it not the dry formula? 20151221_120558.jpg
  15. Dec 21, 2015 at 5:15 PM
    slcsez2000
    St Aug, FL
    12 TRD Sport 4x4
    I personally would only use the dry formula...any other lube that is not dry will not give you good results as dirt and crap will stick to the uniballs even worse and start creaking.
  16. Dec 21, 2015 at 9:48 PM
    GHOST SHIP
    GHOST
    Don't use the "wet" lube. Since the uniball cup is teflon lined, the wet lube can catch small particulates and essentially "pull" them into the teflon surface causing it to wear faster- AKA "squeak!" The dry lube keeps the natural seal intact and still keeps the surface lubricated.
  17. Dec 21, 2015 at 9:55 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Dry graphite lube.
  18. Dec 21, 2015 at 9:55 PM
    TACOtrd1106
    Cali
    2012 Black TRD 4x4
    I just ordered the dry formula. I'll just keep this one for something else.
