need help. OEM waterpump not OEM?? WTF!
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1HItaco, Jan 25, 2017.
  1. Jan 25, 2017 at 5:21 PM
    1HItaco
    1HItaco [OP] Well-Known Member
    hello,
    i am in the process of changing timing belt and i am at the point of changing out the water pump. anyway i purchased a brand new OEM toyota water pump (part number 16100-69398-83), but when i took out the original water pump i noticed that it is different that what i purchased.
    basically everything is exactly the same but the new water pump does not have the groove on the mating surface that the original that came off the truck does.
    i checked for the original part number and it is 16100-69395!
    it does also say that the part 16100-69395 was replaced by part number 16100-69398-83.
    https://www.toyotapartsdeal.com/oem...0=VZN170L-CRPDKAB)&Location=water-pump,,16100
    does that mean if i order part number 16100-69395 i will get the new 16100-69398-83 part instead?
    was the original 16100-69395 discontinued?
    should i install the new water pump that doesnt have the groove? reason for making sure is when i read the FSM it says to put the FIPG inside the groove of the water pump. since the new pump has no groove do i still put in the FIPG?
    the hew water pump did come with a metal/rubber gasket. do i put FIPG on both sides of the gasket and install?
    or no FIPG with this new water pump setup?
    the new gasket that came with the new water pump that doesn't have the groove in it
    gasket made of some kind of metal with rubber and gasket like material on the surface.
    not sure how to apply the FIPG to this.
    the procedure in the 2000 4x4 TRD ex cab FSM definitely specifies putting FIPG in the groove and installing within 5-7 mins.
    was this a defective part that was updated to this new metal gasket method? because the original had a lot of fluid leaking out from everywhere.
    how should i proceed?
    try to order part number 16100-69395 and hope it comes with a groove so i can install as the FSM recommends
    or
    install the new 16100-69398-83. not sure if i should use any FIPG with this route. and if so how much and where?
    any help is greatly appreciated.
  2. Jan 25, 2017 at 5:34 PM
    wht95scort
    wht95scort Well-Known Member
    NJ
    2001 3.4 gas guzzler
    Clean off block surface of old FIPG and install new pump with the new metal style gasket. This is how they are. You don't need to use and fipg on the new gasket.
  3. Jan 25, 2017 at 6:11 PM
    1HItaco
    thanks for the response
    can anyone else second that notion?
    is there any service bulletin/recall that specifies the new procedure? same torque specs for the bolts?
    thanks again for any help/advise thats given
  4. Jan 25, 2017 at 6:24 PM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    I did mine recently and the new water pump was like what you have pictured. I just followed the same torque specs. I didn't add FPIG. So far so good...
  5. Jan 25, 2017 at 9:00 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Pardon my ignorance, what's FIPG?
  6. Jan 25, 2017 at 9:05 PM
    Pickeledpigsfeet
    Pickeledpigsfeet Well-Known Member
    Foothills, CA
    Form In Place Gasket
  7. Jan 25, 2017 at 9:06 PM
    Pickeledpigsfeet
    Foothills, CA
    Seconded.
  8. Jan 25, 2017 at 9:07 PM
    1HItaco
    thanks everyone for the input will proceed with install tomorrow.
  9. Jan 25, 2017 at 9:10 PM
    Boneretreiver
    Boneretreiver Well-Known Member
    Tom
    Eastern WA.
    2010 AC TRD Sport 4x4
    No groove, no fipg! Use the gasket that came with new waterpump. Doubling up on any gaskets never works, period!
  10. Jan 25, 2017 at 9:13 PM
    Catcrazed
    Catcrazed Love is Dogs and Toyotas
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    91 Flatbed, 4.88's, ARBs, SAS, 3.4 Swap, 35s, M8000, lots lights, Aux tank, Protech
    I would assume the redesign was do to labor. The cost of having a dealer install the water pump is the same but they save 30min having the tech scrape old fipg off. So I turn they are making more per hr.
  11. Jan 25, 2017 at 9:48 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    I believe the part number suffix -83 indicates it's a rebuilt part. If that sites says the original part has been replaced by this, then this is all that you can get from Toyota. It should be as high a quality rebuild as any. Sometimes you see these rebuilt parts with -83 for alternators, half shafts, etc.
  12. Jan 26, 2017 at 12:19 AM
    1HItaco
    thanks everyone for the input.
    1 more question.
    when installing the thermostat the FSM says to install the "jiggle valve" DOWNWARD. I'm assuming thats the little piece that can jiggle around that is hanging there on the thermostat.
    anyway the videos that i watched says to install the thermostat with the little jiggly thing pointing upwards?
    does the little giggle piece need to point up or downward like the FSM states?
    this little piece
  13. Jan 26, 2017 at 3:50 AM
    wht95scort
    NJ
    Install it with the "jiggle valve" at 12 o'clock. This helps bleed off air. if installed at the bottom it may cause an overheat condition.
  14. Jan 26, 2017 at 3:57 AM
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    ThunderOne and DrZ like this.
  15. Jan 26, 2017 at 9:04 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    I have a V6 and when I asked myself that question I took a look at the manual. It said to install the thermostat with the jiggle valve at 12 o-clock.
    So I did.
    When I then drove the truck I noticed that the water temperature gauge needle was exactly centered (pointed at 9 o-clock), so I read the manual again. This time it said to install the thermostat with the jiggle valve down. It was then that I noticed I was reading from 2 different manuals. I can't recall which ones though. Anyways I reinstalled the thermostat with the jiggle valve down. When I drove the truck the temperature gauge needle now pointed below the 9 o-clock position, just like it has since I bought the truck new.
    There must be a hundred threads on this. You can install it however you want, but I installed mine with the valve at 6 o-clock. I have been happy with it ever since. (I bought the truck brand new in 1998, and replaced the thermostat about 2 years ago, FWIW.)
  16. Jan 26, 2017 at 9:49 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
  17. Jan 26, 2017 at 10:32 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
  18. Jan 26, 2017 at 11:50 AM
    1HItaco
    thanks again everyone for the input. I will follow the 2000-FSM and install the jiggle valve downwards.
    sucks that the videos online showing the procedure all say to install the valve at the 12 o-clock position.
    seems the consensus is downward at the 6 o-clock position
  19. Jan 26, 2017 at 12:09 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Correct. V6 = jiggle valve at 6 o'clock. I4 = jiggle valve at 12 o'clock.
    Edit - this info is applicable to the Toyota 5VZ 3.4 and the Toyota 3RZ 2.7, just felt need to clarify.
  20. Jan 26, 2017 at 1:48 PM
    Roadeater
    Roadeater Well-Known Member
    Kennesaw, Ga
    2004 Black Tacoma Prerunner TRD V6
    Interesting. My V6 when I replaced waterpump, the original jiggle valve was at 12. I installed it back the same way.
