Need help!! No running tail lights...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Zac of all trades, May 3, 2016.
  1. May 3, 2016 at 2:43 PM
    Zac of all trades
    Zac of all trades [OP] FWP Fabrication Vendor
    Zac
    fwpfab.com
    2013 4x4 Locked DCLB
    886/5100s/AAL/UCAs/360 armor/RTT/295 17s
    Thanks for reading...
    When i turn on my headlights at night my running tail lights DO NOT light up. The brake lights, turn signals, and reverse lights all work. I have pulled and checked every fuse under the dash and under the hood, and i can not see any OBVIOUS signs of blown fuses.
    Also i've noticed that the backlights for my radio and AC do not light up.
    I can get my hands on a multimeter but im not not sure exactly how to use it to check the fuses...
    Im thinking i blew a fuse or a relay... Any input will be appreciated.
    Thanks
    Opc22 likes this.
  2. May 3, 2016 at 2:57 PM
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    Find the fuse marked tail and replace it. It's top row third in on inside fuse box on my truck. Yours may be different.
  3. May 3, 2016 at 2:58 PM
    327 Well-Known Member
    Mark
    Covington, LA
    Former 06 TRD Sport Silver Current 06 Sport 4Runner
    Did you check the bulbs? Aren't they dual-filament ?
    Zac of all trades[OP] likes this.
  4. May 3, 2016 at 3:00 PM
    jakebray
    jakebray Well-Known Member
    jake
    SoCal
    13 PreRunner
    Locked DCLB with Kings and crap
    Behind your glove box is a fuse panel, find the fuse that's busted in there for the taillights, go through them all in there I had the some problem and that was the solution, I think it was a 10amp
    fuse
  5. May 3, 2016 at 3:14 PM
    Zac of all trades
    Zac
    fwpfab.com
    I have checked it but i will replace it just to be safe. Thanks!
    honestly i am not sure but they work when i press the brakes, in reverse, and the turns signals all still work while the headlights are on. Just the running lights are not on and im afraid im going to get pulled over soon.
    I did not know there were 3 fuse clusters in my truck! Geez thats rediculous. I have not checked the fuses behind the glove box. Just the ones under the hood and behind the dash on the driver side.
    Thanks for the help everyone!
  6. May 3, 2016 at 3:17 PM
    Zac of all trades
    Zac
    fwpfab.com
    Also i noticed that if i leave my headlights on they will stay on even after the truck is turned off and locked. Usually they go off... related to my other problem?
  7. May 3, 2016 at 3:20 PM
    jakebray
    jake
    SoCal
    13 PreRunner
    Fix the taillights and that will give you your answer :notsure:
  8. May 3, 2016 at 3:43 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    There is no fuse panel behind the glove box.
    The fuse panel in the cab is behind the small box to the left of the steering wheel.
    You cannot check a fuse visually and know for sure. You need either a meter or a 12 VDC test light probe.
    See post # 2 for the location of the Tail fuse behind the small cubby left of the steering wheel. Replace it, 10 Ampere.
  9. May 3, 2016 at 8:11 PM
    Zac of all trades
    Zac
    fwpfab.com
    Ok so i checked all the fuses again and replaced the tail fuse for good measure.... no luck... Still have the same problem.
    I also swapped the tail light relay and the fog light relay to see if that was the problem and the fog lights still worked. So that is not it. I need to figure out my multi-meter and test all the fuses to make sure all of them are good for sure.
    I have also tried to remove the battery to reset the computer and that did not work either...
    I dont want to take it to the dealership and have them rob me for swapping a fuse or relay or something.
  10. May 3, 2016 at 8:27 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Are you still under the 36/36 warranty? If so take it to the dealer and let them do their job.
    Is the license Plate Lamps working?
    If so it isn't the fuse.
    Parking Lamps, Tail Lights and License Plate Lights all come from the same source.
  11. May 3, 2016 at 8:28 PM
    Zac of all trades
    Zac
    fwpfab.com
    No i have 61k on the odometer. Not sure i have not looked to see...
    If i knew which bulbs were the running lights then i would check them to see if that was the problem. I cant imagine that both have burnt out at the same time.
  12. May 3, 2016 at 10:13 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    RogerMexico likes this.
  13. May 3, 2016 at 10:15 PM
    Zac of all trades
    Zac
    fwpfab.com
    Thanks for the info but my problem is that the tail lights are not on at night. all my headlights seem to be fine except that they do not turn off when the truck is locked...
  14. May 3, 2016 at 10:25 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    What I am trying to tell you is that the Parking Lights in front, The Tail Lights in the rear and the License Plate Lights all come from the same source voltage.
    IF the Parking Lights and License Plate Lights are working, but the Tail Lights are not then the voltage isn't your problem. You have a wiring issue with just the tail lights.
  15. May 4, 2016 at 12:52 AM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    Blown bulb. You probably had one blown and didn't notice, then the 2nd blew too. Pull bulb and examine.
    Sequence for "LIGHT NOT ON " starts like this=
    1. check bulb,
    2. check fuse
    there goes 99% of issues. From your posting so far >>>>>>>>>>>>>> you haven't even checked the light bulb..<<<<<<<<<<<
    If it's not the fuse/bulb, then check elsewhere. In trucks people invert the first two steps because it can be easier to pull a fuse than removing a taillight to check the bulb, Also because you often can't see the filaments thru the lamp housing.
    Edit, just reread your post, sounds like it may be a fuse, import cars dash lights go out to let you know your taillights are not on. I had a pathfinder that did that. First check the bulbs
  16. May 19, 2016 at 6:36 AM
    FLCoyote1
    FLCoyote1 Member
    2001 EXTRA CAB TRD
    NERF Bars, Bull Bar, 30" Mounted Tool Box
    If you have a trailer connector/converter the tail light problem can be from a loose/unconnected power wire in or attached to the converter. Just experience this and probably spent four hours trying to find. Finally found someone on Toyota Nation with same issue that had fixed it by resetting the converter/connector wires. Tried it and it worked, took at least 10 minutes to fix.
  17. Apr 26, 2019 at 5:55 AM
    Stevenv
    Stevenv New Member
    Steven
    2013 Toyota Tacoma TSS
    Fog light mod
    Ok I have the same problem,so how do I reset the converter/connector wires
  18. May 9, 2019 at 3:07 AM
    alouwomack
    alouwomack New Member
    Amber
    2013 Tacoma
    Steve,
    I just went to replace a license plate bulb and now I have no tail lights, etc. The brake lights, signals, reverse still work. I must’ve blown a fuse but can’t figure out which one for sure? There’s a fuse box inside the cab too? On a 2013? I’ve only messed with the one under the hood and had no luck.
  19. May 9, 2019 at 4:04 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Behind that Lil cubby by your left knee is the fuse block. Open it and pull/lift out.
    To check the fuses with a meter, set to dc volts, and put the probes across the fuse. A voltage reading indicates a blown fuse.
  20. May 9, 2019 at 4:24 AM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    @bjmoose "My guess would be the trailer harness brake light is grounding out. You say you "unplugged it" - did you disconnect the harness fully from the right side brake light?
    The other alternative would be a factory wire has somehow failed along the harness - but modern wiring harnesses are so reliable and well protected, that seems like a stretch.
    You've already fully removed the taillight assembly from the truck. At this point, I'd use a multimeter to see if you're getting 12v to the brake light pin.
    I'm pretty sure that the socket shares a ground between the tail light and the brake light. So it wouldn't be a failed ground or the taillight would be out too..."
