Need Help: Manual Transmission Slipping?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by texasfootballer, May 1, 2020.
  1. May 1, 2020 at 12:49 PM
    texasfootballer
    texasfootballer [OP] Member
    09 PreRunner
    My 2009 with a 2.7/5 speed and very high mileage is really being sluggish in 2nd gear until i get it to 3000 plus rpm, what could it be?
  2. May 1, 2020 at 1:52 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Sluggish and slipping are quite different. A better explanation of what it’s doing would be great.
    reg0928 and whatstcp like this.
  3. May 1, 2020 at 1:54 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Remove your foot off the brake when you’re accelerating
    whatstcp likes this.
  4. May 1, 2020 at 4:09 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    I rev high on my truck. Usually shift around 3500-3700 rpms or higher. There is a dead zone around 2500 rpms when the truck just doesn't want to accelerate.
    Don't be afraid to push the little 2.7- it can take it!!
    specter208 likes this.
  5. May 2, 2020 at 5:14 AM
    c212
    c212 Well-Known Member
    Is this a new problem?
    What is "very high mileage?"
    Sluggish from idle to 3K ONLY in second, or in higher gears (especially 3rd) as well?
    Would be interesting to look at any stored codes, even if there's no CEL.
    I have my suspicions, but I don't want to speculate w/o more data.
  6. May 2, 2020 at 9:30 AM
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    If manual trans is slipping, it's got to be making a whale of a racket.
    EdgemanVA and gotoman1969 like this.
  7. May 7, 2020 at 6:43 AM
    texasfootballer
    09 PreRunner
    Its got 236,000 miles bought it new in 2009
  8. May 30, 2020 at 8:35 AM
    texasfootballer
    09 PreRunner
    Just happening in second gear, it makes the truck hop. Have shifted to second without using the clutch and same problem
  9. May 30, 2020 at 8:47 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Id start by cleaning the MAF sensor and throttle body. Sounds like its stumbling and not the clutch slipping. To test the clutch, while driving around 40 mph, shift into 5th gear and floor it. If the motor lugs down, the clutch is still good. If the revs shoot up and you dont feel any forward movement, then the clutch is slipping
  10. May 30, 2020 at 8:50 AM
    BassAckwards
  11. May 30, 2020 at 5:24 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The odd part to me is, that you are not able to replicate the issue in any other gear.
    I would think, if it were strictly an engine problem, you could get the issue to occur in other gears.
    Engine load can differ in each gear. Though typically most manufacturers try to keep the load/torque flat across the gears.
    Have you short shifted or held the shifts higher to see if you can get it occur in other gears?
    I think in my older PreRunner 2.7 it seemed to be the widest ratio between the gears?
    I honestly can’t remember?
  12. May 31, 2020 at 4:55 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    Manual transmissions don't "slip." Highly worn clutches slip, and worn bands in automatic transmissions may slip, but manual transmissions are unable to "slip."
  13. May 31, 2020 at 10:09 AM
    MR5X5
    MR5X5 Well-Known Member
    Sounds like clutch slipping. I've have typically noticed it beginning in 2nd gear. Torque is not uniform per gear, else acceleration would be consistent from gear to gear.
  14. May 31, 2020 at 10:15 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Manual transmissions don't slip. Clutches do.
  15. May 31, 2020 at 10:42 AM
    texasfootballer
    09 PreRunner
    I got a lot of black gunk out of the TB, have not messed with the MAF yet. Still the same, did punch it at 40 mph in 5th and get worked fine
    BassAckwards[QUOTED] likes this.
  16. May 31, 2020 at 12:35 PM
    BassAckwards
    If the clutch didnt slip and it wasn't the TB, it could just be a dirty MAF. Make sure you only use MAF cleaner on it as it is a senstive electronic piece. If the wire in the MAF is dirty or gummed up, it could be causing your issues. Make sure not to touch the wire on the MAF while cleaning it. Just spray, let dry, and repeat
  17. May 31, 2020 at 12:36 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Do you shift without using the clutch, often?
  18. Jun 1, 2020 at 4:19 AM
    texasfootballer
    09 PreRunner
    Every once in a while same issues
