Need help finding whining noise front of engine.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mdmt800, Jan 22, 2016.
  1. Jan 22, 2016 at 6:06 PM
    mdmt800
    mdmt800 [OP] Active Member
    Houston
    2007 Tacoma
    Hi, my taco has 137 k miles and just started with a pretty loud whining noise from the front of engine like a pump or pulley. I had to drive 30 miles on it, no lights or burning smell. I stopped when I got home and put in park and still had whining noise so I don't believe any transmission problems.
  2. Jan 22, 2016 at 6:08 PM
    Burnett
    Burnett Well-Known Member
    Nolan
    North Georgia
    98' Xtra cab v6 4x4 evergreen pearl
    Bilsteins 5100's & 5125's, OME Dakar leafs Custom toolbox Custom bedstep/towhook/reverse light combo Custom Bedrack
    Check power steering fluid, check tension on belts. Somewhere to start if you haven't already done this.
  3. Jan 22, 2016 at 6:21 PM
    mdmt800
    Houston
    2007 Tacoma
    I did check power steering fluid and it was ok. Tension on belt was good. I'll try to upload a video tomorrow afternoon.
  4. Jan 23, 2016 at 10:05 AM
    ds46000
    ds46000 Well-Known Member
    07 PreRunner TRD Sport
    Mine recently had the same symptoms & it turned out to be the alternator. When doing the research on it, most people that had a noise up front ended up replacing idler pulleys...so you can check those too.
    Best way i found to determine exactly where the source of the noise is, is to buy a cheap mechanics stethescope (got mine for about $5).
    Good luck.
  5. Jan 23, 2016 at 10:32 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    As others have said I'd check the power steering fluid and replace the serpentine belt (after 137k miles = :D) unless you know it's been done recently.
  6. Jan 23, 2016 at 3:39 PM
    mdmt800
    Houston
    2007 Tacoma
    Here is a quick video. I was all over the place but you can hear the whine. It really sounds like it's on the side of the alternator. Would a Mechanic's Stethoscope help me find the problem? The belt looks ok, I plan to replace now. The power steering fluid is full. The power steering works good.
  7. Jan 23, 2016 at 4:55 PM
    ds46000
    That's exactly what mine sounded like & it was the alternator. Truck only has 73k miles on it. And yes, if you would like to confirm before you remove it, you can spend the few bucks for a stethescope and place the tip of the metal rod directly on the body of the alternator. The harder you press, the more distinct the sound will be. (Cant put it on the alternator pulley bolt as it spins w/ the pulley).
    If its not the alternator, which i suspect it is, you can also use sterthescope to determine which of the other pulleys it may be.
    Good luck & report back.
    PS: New alternator was around $165 @ autozone and new belt was $36.
  8. Jan 23, 2016 at 5:01 PM
    ds46000
    Should have mentioned: replacing alternator can be done by yourself, although it would be helpful if you had someone to hold it in position while you put the two larger bolts in.
    You do not need to remove the battery or anything else to remove it. You can slip it out through the wheel-well if you remove a small piece of rubber skirt material (4 small plastic clips).
  9. Jan 23, 2016 at 5:28 PM
    mdmt800
    Houston
    2007 Tacoma
    Awesome. I'm going in the morning to get the stethoscope. watched a video on youtube about the alternator. I hope to report back with good news by the end of the day. Thanks all for your help.
  10. Jan 23, 2016 at 5:45 PM
    Halena Molokai
    Halena Molokai Well-Known Member
    Black 2016 TRD DCSB OR 4x4 MT6
    BFG KO2 265/70/17 Moto Metal 17x 9 -12mm ToyTec Boss 2.0 lift Kit Wet Okole, Ceramic tint 35% Bakflip F1 Flowmaster Exhaust Single in /Dual out with 3"stainless tips DashMat Covercraft Custom windshield shade Tilt Alarm Weatherbeater Mats Diode Dynamic LED upgrade to interior OEM Bed Mat OEM 5" Chrome Side Steps
    Use a long enough screwdriver or ratchet extension and place it on each unit you suspect the noise, you WILL hear it. Most likely a worn bearing.
  11. Jan 23, 2016 at 5:56 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Sounds like the alternator to me also.
  12. Jan 23, 2016 at 6:01 PM
    mdmt800
    Houston
    2007 Tacoma
    I appreciate the advice. I'm hoping to make some progress tomorrow.
  13. Jan 23, 2016 at 6:29 PM
    kiahb12
    kiahb12 Well-Known Member
    Kiah
    Western North Carolina, attend WCU
    2007 Access Cab PreRunner
    Couple mods down, many mods to go
    Mine makes more of a high pitched whine. I was told its in the catalytic converter. That could be it
  14. Jan 23, 2016 at 7:56 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    His ain't no cat converter.
    kidthatsirish likes this.
  15. Jan 24, 2016 at 2:21 PM
    mdmt800
    Houston
    2007 Tacoma
    I think I got it. The noise is gone. I drove around sounds normal. No more whine. The alternator, belt, and stethoscope wound up being 149.09 after refund on the core, including tax. I made 2 separate purchases with online promo codes which dropped it some. I was able to pull the alternator out the top next to the oil filter. I had to move some wires over a little bit. I did take the battery out to give me extra room. Thanks everyone for your help. That led me in the right direction.
    http://shop.advanceautoparts.com/p/carquest-or-toughone-alternator-remanufactured-100-amps-11324a/20850845-P?navigationPath=L1*14920|L2*14999
    http://shop.advanceautoparts.com/p/driveworks-v-ribbed-belt-835k7/10065163-P?navigationPath=L1*14920|L2*14999
    http://shop.advanceautoparts.com/p/...scope-ac637/10042652-P?searchTerm=stethoscope
  16. Jan 24, 2016 at 5:47 PM
    ds46000
    Awesome, glad you got it all fixed up. It's a nice feeling starting it up for the first time to find that the noise is completely gone, huh? You did a lot better than i did on the prices too, nice work!
  17. Jan 24, 2016 at 5:49 PM
    mdmt800
    Houston
    2007 Tacoma
    Thanks, for sure a good feeling. Thanks for your help.
  18. Feb 28, 2022 at 3:58 PM
    RSparks8
    RSparks8 New Member
    Green 2011 Toyota Tacoma
    I know this is an older thread, but I'm having the same problem with the whine. Today I replaced the battery and the alternator and its still whining. I will try replacing the serpentine belt Tommorow. Just in case that dosent work, does anyone have any suggestions?
    Other research I found may suggest transmission??? I sure hope not.
  19. Feb 28, 2022 at 4:01 PM
    Tromezze
    Tromezze Active Member
    Antonio
    Arizona
    2011 Toyota Tacoma TX-PRO 6MT
    I had the same problem with mine and it ended up being the idler pulleys and serpentine belt and fixed the problem.
  20. Feb 28, 2022 at 4:04 PM
    RSparks8
    RSparks8 New Member
    Thanks for the reply, I will look now at prices for the idler pulleys and see how hard it will be to replace.
