Need help finding Push pins for rear bumper plastic cover
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Paulrv6, Feb 1, 2022.
  1. Feb 1, 2022 at 1:43 PM
    Paulrv6
    Paulrv6 [OP] Well-Known Member
    paul
    2005 Tacoma
    I have a 2005 stock rear bumper and there are 4 push pins (two on top and two underneath) that holds the black plastic cover to the bumper shell. Once you remove them they break so I need to replace. Anyone know the toyota P/N and where I can find these? Thank you for the help.
    paul
  2. Feb 1, 2022 at 1:47 PM
    JonathanH
    JonathanH Well-Known Member
    Jonathan
    Southern Maryland
    11' DCLB
    This might help.
    Geeves77 likes this.
  3. Feb 1, 2022 at 1:49 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    You should be able to just call up the local dealership and get the P/N however, auto parts stores sell whole racks of plastic clips that should cover most of the different varieties. Do you have a removed one you can take with you and compare?
  4. Feb 1, 2022 at 2:02 PM
    Paulrv6
    paul
    2005 Tacoma
    Thanks guys very much. I'm assuming it is item #4 which combines the two pieces of the push pin? P/N 52161-04010
    Does the two at the end in paratheses mean qty 2, because there should be four. Thanks again
  5. Feb 1, 2022 at 2:08 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
  6. Feb 1, 2022 at 6:59 PM
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    Yes it means QTY 2. I don't recall there being 4 of those push pins, just the 2 on the top of the cover, but not the bottom (as illustrated in the attached Toyota parts breakout). Unless you have a X-Runner, which appears like it might use 2 push pins on the bottom inside/middle area of its bumper shrouds (reference very bottom of attached Toyota parts breakout).
    Also, for reference here's a couple past threads illustrating the rear bumper assembly (non X-Runner) and they do not show or mention any push pins on the bottom as well:
    https://www.tacomaworld.com/threads/removal-installation-of-rear-bumper.41023/
    https://www.tacomaworld.com/threads/diy-rear-bumper-hitch-and-bumper-cover-removal.556093/
  7. Feb 2, 2022 at 7:09 AM
    Paulrv6
    paul
    2005 Tacoma
    My 05 uses 2 push pins underneath on the black plastic where in one of the videos it shows a 10mm bolt, maybe it's specific to the 05.
    Anyways thanks so much for the links and info, definitely needed for my work to replace the bumper ( as soon as I get one). Thanks
  8. Feb 2, 2022 at 6:19 PM
    burrito782
    08 TRD Off Road
    Unless you're the original owner and know for a fact that bumper has never been touched, you may want to take a closer look at the holes where those two push pins underneath came out of. They should be two threaded holes on the bumper support beam for bolts. I could be wrong, but I'm doubtful what you're reporting is specific to the 05s (and isn't reflected on Toyota's parts breakout) and instead is probably something squirrely that took place with your truck in the past. Perhaps at some point they were rusted/stripped/drilled out and push pins were used as a workaround or maybe the bumper was replaced with one of those cheap aftermarket bumper assemblies that uses push pins instead. :notsure:
  9. Feb 3, 2022 at 6:38 AM
    Paulrv6
    paul
    2005 Tacoma
    I am the original owner and the rear bumper has never been touched. So for what ever reason the factory used push pins on the two flaps or tabs on the underside of the cover. Thanks
