NEED HELP FINDING A FUEL ASSEMBLY LEVEL SENDER WITH PUMP
Discussion in '1st Gen. Tacomas (1995-2004)' started by oldguy128, Nov 6, 2020.
  1. Nov 6, 2020 at 2:56 PM
    oldguy128
    oldguy128 [OP] Well-Known Member
    GARY
    Southbury CT
    1996 Toyota Tacoma
    I just had my gas tank removed to have the frame welded now my gauge reads full it was not looking right, I had 1/2 tank full when left the truck and it was reading 3/4 full filled up it took 9 gallons now it reads only full I'm not happy
    I'm getting a STRANGE PART numbers for that full assembly I might as well make it easier
    MY VIN NUMBER IS 4TANL42N2TZ187766
    AUTO ZONE PART IS, FG 204A
  2. Nov 6, 2020 at 3:07 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Have you tried part # 8332080307
    Toyota doesn’t list or sell the whole Pump Assembly.
    It’s broken down by each part in the pump assembly.
    I got that number here: https://partsouq.com/en/catalog/genuine/locate?c=Toyota
    Then typed in your vin#, Selected -Groups, the. Fuel System.
    You can double check me, to make sure it’s correct.
  3. Nov 6, 2020 at 3:43 PM
    oldguy128
    GARY
    Southbury CT
    1996 Toyota Tacoma
    not sure how to use it I woke today my right hand is all numb i'm not in good shape
  4. Nov 6, 2020 at 4:04 PM
    TnShooter
    Deogee
    STOCK
  5. Nov 6, 2020 at 5:50 PM
    oldguy128
    GARY
    Southbury CT
    1996 Toyota Tacoma
  6. Nov 6, 2020 at 6:09 PM
    TnShooter
    Deogee
    STOCK
  7. Nov 6, 2020 at 7:16 PM
    oldguy128
    GARY
    Southbury CT
    1996 Toyota Tacoma
  8. Nov 6, 2020 at 8:19 PM
    oldguy128
    GARY
    Southbury CT
    1996 Toyota Tacoma
    TnShooter likes this.
  9. Nov 7, 2020 at 12:05 PM
    oldguy128
    GARY
    Southbury CT
    1996 Toyota Tacoma
    I have a wiring diagram, but I can't find the fuel tank listed in it, does anyone know if the tank is grounded to the frame or it used its own in the plug? PART 1.jpg PART 2.jpg
  10. Nov 7, 2020 at 12:12 PM
    JonathanH
    JonathanH Well-Known Member
    Jonathan
    Southern Maryland
    11' DCLB
    Here's a breakdown of how Toyota sell the pump.
    23206A is the Pump Bracket
    23220P is the Pump
    The parts shown over the pump are all separate also.
    TnShooter and oldguy128[OP] like this.
  11. Nov 7, 2020 at 1:03 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
  12. Nov 7, 2020 at 2:11 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    The sending unit grounds through the harness Brown Wire so does the fuel pump
    The pump uses the White Black Wire to ground
    The fuel tank will be grounded by the Chassis ground in any case.
  13. Nov 7, 2020 at 3:23 PM
    TnShooter
    Deogee
    STOCK
    OP, I don’t see the sending unit in your diagrams.
    Sometimes it’s under the combination meter / gauges diagram.
    So we’ll have to take @Wyoming09 word for it.
    The Fuel Pump is powered by the Blue wire.
    And Grounded by the White with a black stripe wire.
    Thanks for the help @Wyoming09
    I have little to no information on the 95/96 trucks.
  14. Nov 7, 2020 at 4:39 PM
    oldguy128
    GARY
    Southbury CT
    1996 Toyota Tacoma
    Thanks, I'm being attacked by my live TB for my bladder cancer its called BCG so for sure I'm off my mark BIG TIME well just for fun if feelings in my right hand get better I test a known ground to the tank wall, never know making it ground could roundabout fix it, but that's Mickey mouse then the ground in the plug is bad, I hope I can get Carlos who removed the tank to be able to get the plug off without removing the bed again, but the dam thing is in a bad spot
  15. Nov 8, 2020 at 12:40 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    The fuel tank sending unit is included in the combination Meter circuit.
    Out of the 96 Tacoma EWD Here you go the complete manual
  16. Nov 8, 2020 at 1:15 AM
    TnShooter
    Deogee
    STOCK
    Nice! Thanks man:thumbsup:
    Page #174 is what you are looking for OP.
    oldguy128[OP] likes this.
  17. Nov 8, 2020 at 1:25 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Can`t hurt I still like the paper copy better.
  18. Nov 8, 2020 at 9:51 AM
    oldguy128
    GARY
    Southbury CT
    1996 Toyota Tacoma
    WOW I wish I had this before, it would have helped me fix my other problem
    TnShooter[QUOTED] likes this.
  19. Nov 8, 2020 at 10:52 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Not as fast as finding things in the paper copy .
    But you have it now I don`t touch electrical work with out the EWD for what I am working on.
  20. Nov 8, 2020 at 4:27 PM
    oldguy128
    GARY
    Southbury CT
    1996 Toyota Tacoma
    You can print the PDFs for sure I'm keeping them on a special Fash drive damn they're good info and a nice bunch of guys like you guys and magic can happen
