Need help deciding - 250 or 450 dirt bike?
Discussion in 'All Terrain Vehicles' started by aaronk, May 25, 2009.
  1. May 25, 2009 at 6:26 PM
    aaronk
    aaronk [OP] Well-Known Member
    2009 Dbl Cab V6 TRD
    A little background information....
    I'm 6'3 and 220 lbs. I would be using this bike to ride a little bit of everything: woods/trails, dunes, fire roads, and maybe even some motocross sometime down the road. I currently own a '73 Honda CB750 but have never ridden a dirt bike. I raced downhill mountain bikes for a few years, but with the price of those bikes reaching the cost of a used (or even new!) dirt bike, I'd rather get something with an engine rather than something I have to pedal :p In any case, I love the speed and jumps of DH mountain biking and am hoping to get that adrenaline rush with a dirt bike.
    My dilemma is, 250 or 450 (it's going to be a 4 stroke)? I've heard the 450's are scary fast, but would a 250 be leaving me wanting more? My CB750 has got power, but I have to ride it pretty hard to get that power. At the same, the bike is very controllable because of this. I just don't necessarily like to be running it that hard all the time...
    I'm going used for sure, and the local dealer is sitting on a lot of Yamaha 250's and 450's. I'm thinking I can get a pretty good deal on a late model used. I'm hoping they'll at least let me take them both for a spin around the parking lot, but that won't help me much to decide. Given my information, any recommendations from those who have ridden both extensively? My other question is on size - do the 250 and 450 share the same frame or will I be getting a physically bigger bike with the 450? Even if the 250 has enough power, if the 450 is a bigger bike all around, that might make the decision a little easier...
    Thanks!
  2. May 25, 2009 at 6:34 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    I'm more of a quad guy but have dirtbike friends so here's what I've heard and seen:
    Size- the 250's and 450's are very similar in size. I think the 450 may be a very slight amount bigger.
    power- I know guys that ride both 250s and 450s. It seems unless you do a lot of riding in desert or dunes, the 250 has plenty of power. The 450 obviously has more, but that only seems to come into play in the wide open areas. Also, if you're inexperienced, a 450 may be too much. I know the first time I rode a crf450 I almost flipped it over backward on a grippy surface when I got on it a little too much LOL. I'm used to riding a built honda 450 quad(motor is stroked, ported and polished, cam, high compression, valve work. Dynoed at 50hp to the tires) but it still caught me off guard.
    I'd try riding both id you could, or maybe start on the 250 with the intent on moving up to a 450 after a year or 2. By then you'll be able to find the fuel injected bikes used and you can fit that in as part of the upgrade process.
  3. May 25, 2009 at 6:51 PM
    aaronk
    2009 Dbl Cab V6 TRD
    Thanks Relentless. You've echoed what my buddy who rides a Yamaha 450 quad has said. Which reminds me, I have to hit him up to ride his quad, which should give me a better idea of what a 450 engine can do. From what I've heard the Yamaha 450 quad engine is similar to the YZ450F dirt bike engine. He's pushing me towards a 450, but he's also the type that thinks you can never have enough horsepower.
    The dunes would probably be a once a year trip for me, if I were riding regularly there I would definitely be leaning towards the 450.
  4. May 25, 2009 at 7:08 PM
    TL697
    TL697 Well-Known Member
    Jacksonville, FL
    '09 DC SB 4x4 TRD Offroad Magnetic Grey Met
    For your size, you need a 450...
  5. May 25, 2009 at 7:33 PM
    Garrett Timmerman
    Garrett Timmerman Active Member
    North Augusta, South Carolina
    2000 ext. cab lift 33" BFG a/t
    *33" BFG all terrains *15" Mickey Thompson rims *straight dual exhaust *K&N air filter
    i'm with TL697, at your build, you would look like a clown riding a 250. so go with the 450 and ride like a bandit
  6. May 25, 2009 at 7:40 PM
    TL697
    Jacksonville, FL
    I'm 5'8", 175lbs, with a B-class motocross background, and I can ride a 250F to it's limits... It would probably be enough bike until you got comfortable, but it would leave you wanting after that... You can be cautious and careful while learning to ride the 450F, but when you finally get comfortable, you won't be disappointed...
    Also, 250F's are made to be ridden at high rpm, and basically, "balls to the wall"... 450F's can be short shifted and "lugged" a little, but still have adequate power...
    Just my $.02...
  7. May 25, 2009 at 8:00 PM
    gearhead69
    gearhead69 Member
    05 Tacoma Pre
    Dood, Ive been riding dirt bikes for 20+ years. Buy an Xr 400. It is the perfect bike for what you described you are going to use it for. Indestructable air cooled PLENTY of power. I've had mine for 10 years. There is a good reason why they have never changed the design!! I will dust any 450 on a nasty technical hill. Buy a cheap CR 5hundy for the sand. I have 2, and burn 10gal of fuel everytime I go, cause I can't eat enough 450 to get satisfied!!
    but man it's fun tryin
  8. May 25, 2009 at 8:07 PM
    TL697
    Jacksonville, FL
    Good advice as well, if you want more than one bike... The XR400R is a badass woods bike, but is a dog in the sand. Obviously, the reason for the recommendation on the CR500R...
  9. May 25, 2009 at 8:34 PM
    taco_machine
    taco_machine Member
    Calgary
    '08 Taco TRD Sport
    Mods coming soon
    450 fo sho. If it's too much you can always sell it. But it won't be!
  10. May 26, 2009 at 10:01 AM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    The 250 and 450 are the same size, you cant tell them apart unless you look at the engine (if you know what to look for).
    As for the XR400 eating CRF450s, I rather doubt it, I guess it depends on the riders (the guy on the 450 was his first time out?)I think I know what your saying though, the 400 has far more linear power and easier to control tirespin...
    But just for your information, the CRF250X was made to replace the XR400, its lighter too.
    I am 5'6 125 lbs and ride/race a CRF450R, my wife has a 250X and its fun too, I would say as a beginner a 250 would be OK, but if your a quick learner and aggressive, you want a 450.
  11. May 26, 2009 at 10:13 AM
    Bart
    Bart Well-Known Member
    Franklin,NC
    08 TRD OFFROAD V6 4x4
    metra ipod
    Go with the xr 400 the crf 250 and 450s are race bike lot's of maintence .
  12. May 29, 2009 at 1:16 PM
    Manwithoutaplan
    ID
    Go with 450 !!!
  13. May 31, 2009 at 8:13 AM
    Garrett Timmerman
    yall are all about some damn hondas! no trash talk to their woods bikes, but i've never heard very good stuff about their race bikes, they're nightmares.
    just gotta show my yamaha riders some love, have never had a thing go wrong on the four yamahas i own(ed) in the past 3 or 4 years.
  14. May 31, 2009 at 8:29 AM
    CableTec
    CableTec Legend in my own mind
    J-ville and P-ville, FL
    2007 V6 PreRunner SR5 TRD
    See sig.....
    or a 250 two stroke......it takes more skill to ride well than a 450; but they are a blast and quite cheap to maintain, and much easier to work on than a 450 four stroke.
    That being said, a 450 is easier to ride fast than a 250 certainly.
  15. Jul 18, 2009 at 9:56 PM
    cantac09
    cantac09 Official TW Igloo Builder
    Hugh Jass
    Saskatchewan
    tundra
    stock
    im 6'4 205 pounds and i ride a 250f i like it. a 250 has enough power but i just think that a 450 would be too much like i ride my 250 to its limits and i never need to go any crazier
  16. Jul 27, 2009 at 7:50 AM
    1sicktaco
    1sicktaco Well-Known Member
    Atlanta
    2009 TRD DC
    450 no doubt
  17. Jul 27, 2009 at 7:59 AM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    I am 6'3 220 lbs. I ride a Yamaha WR426FP and I absolutely love the power in the woods. When you come around a blind corner and are staring up at a hill just hit the throttle and get to the top no porblem, my buddies 250 has to get a longer running start at it. The wide open stuff is fun but this thing is an ablsolute beast in the woods :devil:
  18. Aug 21, 2009 at 1:08 PM
    James3492
    James3492 Well-Known Member
    James
    EAST COUNTY
    Black-out Tail lights Painted Rims & Hood Scoop
    i would go with a 450. cuz its good for you size and it has alot more power.
  19. Oct 9, 2009 at 10:14 AM
    kmrofka
    kmrofka Im so hungry i can ride a horse...
    Arizona
    03 V6 Prerunner SR5
    Stripped down to the frame
    i just picked up a crf250r and from what i can tell the 450r and 250r are the same as far as frame and suspension set up like most have said its going to be the motor thats the difference. if your going to be trail riding your going to want to get one with a light and such the race bikes dont come with those so yeah if youve rode a bike before the only thing i think you need to worry about is transitioning from road to dirt it is a big difference. just my 2c.
  20. Oct 23, 2009 at 12:29 AM
    seaNOmercy
    seaNOmercy Member
    09 TRD Magnetic Gray
    2.5 inch leveling kit, all-weather mats, hood protector
    This is crazy! I was just googling the exact same question and I just so happen to be a registered member here! It's been awhile.. I am in the market for a dirtbike and I'm 6ft3 220lbs as well... GLORIOUS! haha...
