Need help choosing Coil springs from toytec
Discussion in '2nd Gen. Tacomas (2005-2015)' started by yokohamaboi, Dec 15, 2014.
  1. Dec 15, 2014 at 5:37 PM
    yokohamaboi
    yokohamaboi [OP] Member
    Ton
    South Texas
    14" DCSB SuperWhite
    I have a 2014 TRD Sport 4x4 DCSB tsb leaf/ So far i want to know which is a better idea. Ive done some research but need a Opinion.
    Option 1: Bilstein 5100 all around set at .85 with Eibach/Toytec 1.6 620LB spring. With a 1/4 Spacer on the driver side (Taco Lean) with Wheelers 1.5 AAL.
    Or
    Option 2: Bilstein 5100 all around set at "0" with a Toytec 2.5 lift coil 620LB with no top plate spacers, Only 1/4 driver side spacer (taco lean) with Wheelers 1.5 AAL.
    I know option 2 would be better cause less preload on the coils. Now whats the pros and cons? They should have the same lift?
    http://toyteclifts.3dcartstores.com/Toytec-3-lift-front-coil-springs_p_1205.html (2.5 front coil part #521600) 2.5 is 2.5in lift?
    http://toyteclifts.3dcartstores.com/ToytecEibach-front-coil-lift-springs_p_14.html (1.6 front coil part #112-620) 1.6in+.85= 2.45in lift?
    Thanks if you can help
  2. Dec 15, 2014 at 5:41 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  3. Dec 15, 2014 at 7:29 PM
    darkfader
    darkfader Will this fit without rubbing?
    Josh
    West Virginia
    2018 DCSB6MTFTMFW
    also subbed. i had asked in the suspension section about the newer 2.5" eibachs, looking for real world measurements, and never got any responses. if someone is running the 521-600 2.5" eibachs, i'd be interested in exact measurements of the lift achieved on a double cab V6. thanks
  4. Dec 15, 2014 at 7:31 PM
    yokohamaboi
    Ton
    South Texas
    14" DCSB SuperWhite
    I don't think their listed as Eibach on toytec. Just "toytec" 2.5 coils
  5. Dec 15, 2014 at 9:27 PM
    el tardo
    el tardo Well-Known Member
    so i have option #2 and let me say first they are 600lbs not 620lbs and yes they give 2.5inches of lift set at zero on 5100's.
    get door #2
  6. Dec 15, 2014 at 9:29 PM
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    I have option #1 and its a great ride on and off road.
    In the rear I have wheelers 3 leaf pack and no TSB.
  7. Dec 15, 2014 at 10:45 PM
    yokohamaboi
    Ton
    South Texas
    14" DCSB SuperWhite
    Didn't know I went back and check the link it says 620LB :confused:
    And how do you like your set-up?
  8. Dec 15, 2014 at 10:47 PM
    yokohamaboi
    Ton
    South Texas
    14" DCSB SuperWhite
    How much height difference from stock tsb compared to yours?
  9. Dec 16, 2014 at 12:47 AM
    el tardo
    i called them before i ordered,but look at the part numbers see how one has 600 and the other 620
  10. Dec 16, 2014 at 8:29 AM
    yokohamaboi
    Ton
    South Texas
    14" DCSB SuperWhite
    Ah i see probably a typo, how does it perform? do you off road much?
  11. Dec 16, 2014 at 8:36 AM
    mattgecko
    South San Jose, CA
    Not sure, probable about the same. I haul 3 dirt bikes in the bed and a closed trailer with 3 more bikes with no problem.
  12. Dec 16, 2014 at 12:01 PM
    yokohamaboi
    Ton
    South Texas
    14" DCSB SuperWhite
    Geez that's alot of weight but even then damn! Does your truck sit even with out all the cargo? Or front end is higher or rear higher?
  13. Dec 17, 2014 at 7:30 AM
    mattgecko
    South San Jose, CA
    It sat rear high by a small amount, I added an extra 3/8" spacer to the front to level everything.
    My build thread in my sig has a list of my mods.
  14. Dec 17, 2014 at 7:35 AM
    cgchambers93
    cgchambers93 Well-Known Member
    Christopher
    Houston
    14 Tacoma SR5 4x4
    Wheels and tires, Billstein suspension
    I have 5100s in the front with 887s and an Icon 1.5 in the rear with 5160s. My truck was a little high in the front until it settled to level with 3 inches of lift see signature.
  15. Jan 10, 2015 at 8:00 AM
    jhcole
    jhcole Well-Known Member
    Hunter
    Birmingham, AL
    '15 DCSB 4x4 TRD-OR MGM
    ToyTec 3" w/ Bilstein 5100's
    Bump. Looking for the same info. I have the 521600 2.5" coils sitting in the garage waiting to be installed. I have a 2015 DCSB TRD OR with the TSB leafs. Looking for real world measurements with the 521600 up front (no spacers) and ToyTec/Deaver ' 2.0" ' AAL's. Curious to what my rake will be at this set-up...
  16. Jan 10, 2015 at 8:23 AM
    wardamntaco
    wardamntaco Well-Known Member
    Seattle, WA
    '13 DCSB TRD Sport 4wd
    This might be long winded, but here we go. I have a 2013 DCSB TRD Sport 4x4. I bought lr uca's, toytec 2.5" lift coils, 1/4" drivers side spacer, 5100s all around, and a 1" block in the rear (with the TSB leaf pack). After the install, with the billies set at zero, I was sitting about 1/4" higher in the rear and I was rubbing pretty bad in reverse (on the cab mount) with 275/70r17 on sport 17s with 1.25" spidertrax spacers. I pulled the front end apart and set the billies to .85 and installed a 1/2" spacer on the drivers side and moved the 1/4" spacer to the passengers side. I'm no longer rubbing and I'm sitting about 3/4" higher in the front. FYI, I also had to install the ECGS bushing to eliminate front end vibrations. Hope this helps.
    mattraptor likes this.
  17. Jan 10, 2015 at 8:38 AM
    jhcole
    Hunter
    Birmingham, AL
    Are you suspecting I'll rub with the 2.5" coils only? I'm a little confused as I already have the 265/75/16's on with no rubbing at stock height.
    Also, noticed you're in Birmingham, couldn't talk you into any lift install assistance huh?
  18. Jan 10, 2015 at 8:59 AM
    wardamntaco
    Seattle, WA
    I wasn't implying that you will rub. I just wanted to give as much info as possible. I didn't take any measurements, but based on my scenario I don't think the 2.5" lift coils actually provide 2.5" of lift.
    I would love to help out, but I'm a CPA and I won't have much free time until the end of March. If you haven't done the install by then I'd be happy to help.
  19. Jan 10, 2015 at 9:05 AM
    jhcole
    Hunter
    Birmingham, AL
    Got it, so by that logic, running the 2.5" coil AND the 1/2" top plate spacer probably still wouldn't be a full 3.0" on my DCSB 4x4? (based on your results)
    Not a problem, mother in-law is a CPA (in Auburn actually) so I understand the busy season. The plan is to do the lift next Saturday in the driveway. A few month's back I did 5100's on my wife's 4Runner with no problem, so it shouldn't be too much different.
  20. Mar 8, 2015 at 6:32 PM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
