Need Heelp with my New Fortin EVO-ALL Command Start Plug n Play
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Harley1340FXDG, Oct 31, 2021.
  1. Oct 31, 2021 at 9:35 AM
    Harley1340FXDG
    Harley1340FXDG [OP] Member
    Hi...wanna know if someone is very familiar with Fortin EVO_ALL remote start (plug and play) i've bought that unit and the flash link....uploaded the last firmware for my 2017 Tacoma Push-Start.....done the Decryptor.....both installed exactly successfully as mention in the guide....install the B PLUG as mentionned for Tacoma....i've hold the button...plug power cable...was flashing blue-yelow-red and when it was showing a solid blue light i've released the button....blue light stayed on....push start button twice....blue light went off....few seconds after blue light blinking (supposed to be programmed at that point) push start button once again to stop....all lights went off.....closed the door...went up front of my Taco....push the lock button 3 times (OEM Remote)....nothing's happening except locking doors ?? check out the FAQ and looks like everything i've done was OK....is someone have another trick or clue to help me out ? Thanks in advance
  2. Oct 31, 2021 at 9:48 AM
    DTaco18
    DTaco18 Well-Known Member
    2020 TRD SPORT DCSB 6AT MGM
    make sure you are slow and consistent with the "lock" presses... lock, pause, lock, pause, lock.
    If I recall, one of the module led's should blink every time you press lock, then it begins the remote starting sequence.
    I would sit inside the truck where you can see the module and then press the remote 3 times to see whats happening on the module.
  3. Oct 31, 2021 at 9:51 AM
    Harley1340FXDG
    Hi....yes i've tried it nothing is working is possible cause i don't have any hood pin or toggle switch that can be the problem ??
  4. Oct 31, 2021 at 10:12 AM
    Harley1340FXDG
    Hi Mister....ok i've just tried that....i've sit on the passenger side and watched the fortin unit....and give 1-2 seconds between each lock push....each time i've pushed the lock button i heard the doors locking but no led is flashing on the fortin unit....all leds are off...maybe there is my problem between the unit and my OEM remote....it's weird...should be a 20 min job....geez everything is complicate with me hahaha
  5. Oct 31, 2021 at 10:16 AM
    Harley1340FXDG
  6. Oct 31, 2021 at 10:27 AM
    DTaco18
    Tacoma should have a hood switch integrated. My 18 and 20 both show hood-open status on the display.
  7. Oct 31, 2021 at 10:36 AM
    DTaco18
    It's been a while since I installed these on my vehicles. A little googling shows that the blue LED should blink with each lock press. If it's not, then I'm guessing that's your problem.
  8. Oct 31, 2021 at 10:40 AM
    Harley1340FXDG
    ok thanks it means it's not that the problem then
  9. Oct 31, 2021 at 11:38 AM
    Harley1340FXDG
    Ok i guess it's where is my problem too....i've tried 4-5 differents older firmware to see if there will have a difference.....still the same with every older firmware....installed and programmed ok with all the flahing and solid led's etc...but when it's time to test and push the lock button there is no led flashing or anything on the unit...it's like my OEM Toyota Remote isn't compatible with the Unit....
  10. Oct 31, 2021 at 1:43 PM
    Harley1340FXDG
    Hi again....ok i see....i've read many Troubleshooting and FAQ this afternoon but first time i read about being minimum 10' of the truck and about the yellow loop...i've seen one post on that but it was for a 2014 TACO mine is a 2017...it's worth a try to check that out thanks
  11. Oct 31, 2021 at 3:15 PM
    Harley1340FXDG
    My setup is plug and play don't think i should start cutting anywhere yet....just wrote at Fortin support to see what they think about it
  12. Oct 31, 2021 at 4:30 PM
    Harley1340FXDG
    Ok i see what you mean now....mine is not like that....it looks like this
  13. Oct 31, 2021 at 4:34 PM
    DTaco18
    Is this yours? or just a generic photo?
    You should have two t-harness connections; BCM & Ignition. I only see one in that photo...
  14. Oct 31, 2021 at 4:36 PM
    Harley1340FXDG
    It does have 5 but use 4....data link with the button....large white next to it....on the other side small white and a small red...exactly the same truck as mine and kit as in this video https://www.youtube.com/watch?v=zVQYlQRu-gs&ab_channel=TacomaBeast
  15. Oct 31, 2021 at 4:39 PM
    Harley1340FXDG
    yeah exact same truck as mine....same kit....i've tried the exact same setup as he as done in the video...worked all the same as him...except mine at the end it doesn't start....there is an issue somewhere but where... :( pretty sure the problem is with the OEM FOB....will wait to see what Fortin Support are gonna tell me about it
  16. Oct 31, 2021 at 4:53 PM
    Harley1340FXDG
    Yes done all that perfectly step by step as mentioned in the guide and in the video...still no luck of getting it started
  17. Oct 31, 2021 at 5:20 PM
    Harley1340FXDG
    I thought so too....finally i've spent the day at searching for information on the problem....watch a bunch of videos...read a bunch of FAQ...but no luck....for me lucky as i am it will be maybe a 20 hours job hahaha
  18. Oct 31, 2021 at 5:22 PM
    BOSS-DS2
    BOSS-DS2 Well-Known Member
    Sam
    Texas
    2016 Tacoma 3.5L A/T DCSB
    Motofab 3” Spacer lift Spidertrax 1.25” wheel spacers Yokohama G003 M/T 285/75/17 (34”) MBRP 3” Turndown PowerStop slotted & drilled rotors Tekonsha P3 brake controller
    I have the one another user posted and was never able to get mine to work. Best case scenario was if I jumped an ignition hot wire. Then I could get it to program, or so the LED blinks claimed.
    At that point I could get the truck to attempt to go through the start procedure, except all that happened was the doors locked and then the fuel pump primed. Wouldn’t ever start.
    I bought the remote start kit years ago and have since attempted to install it multiple times, thinking each time I would have an “AHA!!!!!” Moment, but I never have.
  19. Oct 31, 2021 at 5:26 PM
    Harley1340FXDG
    Ok hope it goes better for me then you...and they were supposed to be the greatest one....geez lucky i didn't bought the worst one...it is electronics can fail anytime....as long they repair the problem
  20. Oct 31, 2021 at 7:59 PM
    DTaco18
    I've been buying StartX the last few times, which are rebranded fortin. The kit for this truck is $135. Haven't had any issues using them, so your experience reassures me it's worth the few extra bucks for a preprogrammed plug n play...
