Need easy way to get power wire from battery to inside the cab.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kagetsu, Jul 11, 2023.
  1. Jul 11, 2023 at 4:42 PM
    Kagetsu
    Kagetsu [OP] New Member
    2015 4x4
    I'm trying to mount and power a 2m/70cm 50w radio in my truck. So I need at least 12 amps.
    I'd like to do it without pulling the dash apart. Or even find some place to do it for me.
  2. Jul 11, 2023 at 4:48 PM
    Jojee117
    Jojee117 Well-Known Member
    Joe
    MT
    06 TRD Sport Prerunner 4WD swapped
    It's very easy to poke a little hole in the main wire grommet in the firewall behind the e brake pedal and feed wires through. Use an online calculator or chart to determine a safe wire gauge for 12 amps at the length of wire you expect to run.
    muddog321, Geeves77 and tak1313 like this.
  3. Jul 11, 2023 at 5:07 PM
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    At 12v, you can use 14awg up to about 11 feet with 2% or less voltage drop (important for electronic items). If you can get by with 7 feet, you can use 16awg - easiest to go through the main grommet as @Jojee117 stated - just make sure you don't tear anything trying to get the new wire through.
    Edit - this is assuming full copper wire (not CCA).
  4. Jul 12, 2023 at 2:19 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    There is a small part that you can cut the tip off and feed wire through. It's on the lower side of the grommet.
    pic from another thread:
  5. Jul 12, 2023 at 2:46 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    Depending on where you're mounting the box, you can drop right behind the passenger's side dash (right behind the glovebox) with a very clear path by pulling out and modifying an unused firewall plug.
    On the passenger's side firewall, you can pop out a plug, razor blade the inside of it out, and re-use the plug (now a grommet). Here's a post about it:
    https://www.tacomaworld.com/threads...nch-runs-and-more.712981/page-4#post-27008673
    It should fall right into the footwell without even needing to remove the glovebox, and you can run it wherever you want from there, through the back of the dash, to the side of the console, or you can tuck it under the edge of the console to get under the seat cleanly.
  6. Jul 12, 2023 at 4:51 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    There's also one of those on the driver side too. I ran my wires through it to some temporary (read: permanent) switches in my tiny coin cubby. When I eventually get around to building a fuse box and cleaning up the wires, Ill do that technique you shown in your post. I dont know if it'll be big enough to allow all the wires through when everything is done.
    -J
    deanosaurus[QUOTED] likes this.
  7. Jul 23, 2023 at 1:44 PM
    Kagetsu
    2015 4x4
    Ah yes. I looked at that plug in the passenger firewall again and pushed a screwdriver through the padding behind it. That looks like a good way to come through.
