Need an explanation about CCA test
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KentF, Oct 12, 2023.
  1. Oct 12, 2023 at 7:27 AM
    KentF
    KentF [OP] Active Member
    NJ
    2022 Tacoma Off-Road DC 6'
    Hi all
    Had issue starting engine after drained battery a while ago. I know the cause and it’s 2022 TRD. At Toyota dealer,
    they ran “regular” battery test and came back as OK. I insist to keep the car and start engine in the morning. So they did and i’m sure they couldn’t start engine easily. So they ran “advanced” health test and it shows 94 CCA. They replaced it under warranty.
    my question is that the regular test didn’t find the CCA state issue. if this is normal, i shouldn’t trust regular battery test?
    Thank you for your intel in advance!
  2. Oct 12, 2023 at 7:37 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    sounds like they tried to pencil-whip it and send you on your way the first time. I can't imagine what the cost difference is of the second test,, and why they would do the first test,,, in the first place.
  3. Oct 12, 2023 at 7:41 AM
    tcjacado
    tcjacado Well-Known Member
    The new batteries in these tacoma's really suck. There have been many issues on this topic with this 3rd gen.
    I think tesla (dick fuck musk) and all the electric/hybrid vehicles from all manufacturers are taking the good elements to make those batteries. :ballchain:
    2k2 and HondaGM like this.
  4. Oct 12, 2023 at 7:43 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  5. Oct 12, 2023 at 7:46 AM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    The only thing I can say is these new hand-held battery testers are not always accurate.
    I’ve had a battery fail with a snap on hand held tester but passed with the Midtronics GR-8…….and vice versa.
    Bottom line is it should be at least 80% charge to test.
    Years ago at Sears automotive we would put a loaner battery in your car, trickle charge the do a specific gravity measurement of each cell and individual cell voltage along with a manual load and recovery test.
  6. Oct 12, 2023 at 7:54 AM
    KentF
    NJ
    True. on top of that, they had to give me a round trip ride including LYFT cost…
    i read all and understood about 60% Ha ha. Thank you very much for the link. I guess the dealer should have listen what customer complained and do the advanced test first. But i now know to do that required some time and didn’t want to do the through test at first. At least they did and i got new battery. I learned new!
  7. Oct 12, 2023 at 7:55 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    lol but they know better
    tcjacado likes this.
  8. Oct 12, 2023 at 7:55 AM
    KentF
    NJ
    Sears did proper process as the battery king. sorry to miss them!
  9. Oct 12, 2023 at 10:05 AM
    rolled93slc
    rolled93slc Well-Known Member
    Jerry
    Lynchburg VA
    16 Tacoma TRD Sport DCSB MGM
    Looks like the initial test was done after driving, like what @Sandman614 said. I have tested dozens of batteries that were jumped and driven in, with a "Good" CCA reading. Those I will test several times in a row, to see if the battery will "recover" from the testing. And they usually fail after a few attempts. I would say all most 99% of the time, the techs will not go to the Advanced Tester right off the bat. It takes a long time, especially if the tester wants to charge and retest. It will do this several times. And can take up to an hour. That's a lot of dead time for the tech, who isn't getting paid while your battery is charging and taking up his lift.
  10. Oct 12, 2023 at 10:15 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    This. My battery lasted just over 2 years in the Florida heat (my truck lives in the driveway) before the numbers on my tester started to drop. I went to Batteries Plus and had an X2 Power AGM battery dropped in so I don't have to worry about it for a while. Heat is a flooded battery killer.
    tcjacado[QUOTED] likes this.
  11. Oct 12, 2023 at 10:37 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    They'd always tell me I must have a brand new battery when my Optima came back with like 1130 CCA on their normal test. I always wanted to flip the battery switch to my house setup, so it'd be pulling from all 3 Optimas... Forgot every dang time I went in, and now I don't have the triple battery setup anymore :( missed opportunity. My luck they'd pull the battery clamp off though, and zap something thinking it wasn't hooked to a battery when it was, so maybe it's a good thing I never did it.
  12. Oct 12, 2023 at 11:38 AM
    KentF
    NJ
    Thank you very much for your intel sharing. By reading the Tacoma genuine battery is sucks, I'll consider getting AGM or other type after out of warranty...
  13. Oct 12, 2023 at 11:43 AM
    KentF
    NJ
    You talking about Litium. Tesla battery is made by Panasonic. Panasonic made Battery Giga factory somewhere in desert to produce tons for Tesla. So their battery must be good. I also understand Tesla is now making it by themself after learning (stealing?) the know-how from Panasonic...
  14. Oct 12, 2023 at 12:34 PM
    rolled93slc
    Jerry
    Lynchburg VA
    My original battery lasted 5 years. Batteries are like any other electronic part. The manufacturer has a "built in" defect rate, that is allowable. That's why they have warranties. The OEM battery on my Mercedes lasted 14 years. I tried to use Optima batteries in the past. And had no luck with them lasting more than a year. If the car sat for more then 3 weeks it was flat.
  15. Oct 12, 2023 at 12:53 PM
    Rusty66
    Rhode Island
    I had a Diehard battery that lasted ten years! It’s still amazing that retail giant is gone. Sears automotive used to sell a lot of tires and batteries. I remember one Saturday after thanksgiving we had a tire sale. All 28 bays did tires all day…500+ tires in one day.
  16. Oct 12, 2023 at 1:22 PM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    My 22 is 11 months old. I’m on Toyota battery numero tres.
  17. Oct 12, 2023 at 2:21 PM
    Gatafly
    Gatafly Well-Known Member
    Shawn
    2020 TRD OR AT V6 MGM
    Probably because CCA ratings are done at 0 degrees F. A good battery will always put out more than rated when its warmer than that.
