Need alternate speedo cable options
Discussion in '1st Gen. Tacomas (1995-2004)' started by bgilligan, Jul 8, 2021.
  1. Jul 8, 2021 at 11:29 AM
    bgilligan
    bgilligan [OP] Member
    Brian
    1997 Tacoma 2.7L 4x4
    Hello everyone,
    Just yesterday on a local road my speedometer quit on me, and along with it came the CEL code P0500. After some research, it appears that my speedometer cable has broken. I’ve checked out the gear on the transfer case and it’s in tact, but the speedometer, trip and odometer no longer function.
    I took it upon myself to call Toyota and they gave me a part number 83710-35200 but they say there’s not a single one available in the whole country and Toyota discontinued the part. Is there another part number I can use as a substitute, or one that’s close enough to work? If someone even has one maybe we can work something out. Any help would be appreciated, I’ve got 250k on her now I’d hate to let this be the deathly blow!
    Vehicle details
    1997 (mfg 12/1996) Tacoma
    2 door standard cab
    I4 2.7L 4x4 4 speed automatic
    Cable driven speedometer
    **WITH TACHOMETER**
    Carloss1017 likes this.
  2. Jul 8, 2021 at 11:32 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    wrecking yard, car-part dot com, e-bay, etc...
  3. Jul 8, 2021 at 11:34 AM
    bgilligan
    Brian
    Im totally with you, but it seems not a single website has this part number, I’m looking for any alternate part numbers I can “massage” to fit. (Extended cab models that are too long, etc etc).
    Last resort for me is the scrap yard, these trucks changed so much throughout this year by going electronic I’d like to only rip the dash apart once.
  4. Jul 8, 2021 at 11:39 AM
    jbrandt
    Justin
    I don't think the Xtracabs have any longer cables. The engine/transmission is the same length, only the rear drive line is different.
  5. Jul 8, 2021 at 12:13 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    They vary by part #. But I'm sure there are alternative ones that are still available that can work. 4runner ones would work too.
    Carloss1017 and jbrandt[QUOTED] like this.
  6. Jul 8, 2021 at 12:50 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    You can swap dash to digital and add electric sending unit and wire if you don't find a cable that works.
  7. Jul 8, 2021 at 1:26 PM
    bgilligan
    Brian
    Wouldn’t this require a new ECU considering the mechanical dash holds the vehicle speed sensor and sends its data from the Speedo cable?
  8. Jul 8, 2021 at 1:27 PM
    bgilligan
    Brian
    That would be great, do you happen to know what model years and such would be compatible?
  9. Jul 8, 2021 at 1:36 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    What part of the World do you live in??
    Ask around if you have any Muscle Car Groups in your area that is who hooked me up.
  10. Jul 8, 2021 at 1:41 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Back in the day there were "universal" cables/repair kits. This was the inner cable and some adapters, you would cut to length.
    Looks like NAPA still has them. I have no experience with their use on a Taco.
  11. Jul 8, 2021 at 1:42 PM
    bgilligan
    Brian
    North eastern US. I will try that thank you
  12. Jul 8, 2021 at 1:44 PM
    bgilligan
    Brian
    I care less about the speedometer, and more about the odometer for maintenance purposes and the vehicle speed sensor for the transmission. I also don’t like having the CEL on all the time, I won’t know if an actual code comes up
  13. Jul 9, 2021 at 1:24 PM
    Glamisman
    Glamisman Well-Known Member
    most large cities have "speedometer" shops for speedometer calibration... they should have the capability to manufacture a new cable for you or replace the flex drive portion.
    Wyoming09 likes this.
  14. Jul 18, 2021 at 10:45 AM
    bgilligan
    Brian
    *RESOLVED*
    So come to find out, almost all of the speedometer cables available from that era are about the same length with the same ends on both sides. The only difference I saw, was the placement of the plastic grommets where the cable is secured to various parts of the truck and the heat insulation placement. The cable I have posted below fit my 1997 Tacoma 2.7L standard cab 4x4 Automatic with no modifications aside from a couple zip ties to secure it where the plastic grommets are misplaced. I hope this helps the next guy, because the actual part number for that truck is nearly extinct brand new.
    rocknbil likes this.
  15. Jul 18, 2021 at 11:01 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    glad you were able to find something that worked
    bgilligan[OP] likes this.
  16. Oct 31, 2023 at 9:15 AM
    Carloss1017
    Carloss1017 Well-Known Member
    Carlos
    SoCal
    95.5 Tacoma 4wd 2.7L
    hi, by any chance do you know if this will work for me too ? I have a 95 Tacoma 4wd with no tach
