need advise on Scan Gauge 3
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 84-4runner, Jul 28, 2023.
  1. Jul 28, 2023 at 9:08 AM
    84-4runner
    84-4runner [OP] Well-Known Member
    frank
    Northern Arizona
    2019 tacoma offroad
    intake mods, firestone airbags, campershell, backup lights,
    I bought a Scan Gauge 3 after speaking with the manufactuer I was told to stop by and speak with the engineer any day after lunch. I then drove 200 miles one way to speak with the engineer. Of course he/she was missing in action. I then ordered the scan gauge 3 on Amazon
    since if it did not do what the girls at the front said it could do.
    The website has a bunch of codes to uses when the scan gauge 3 does not find the code.
    I am looking for oil pressure and manifold pressure ( manifold vacuum ). The gauge does a
    scan for what it can find and has an option to add codes for what you are looking for. I could
    not find the codes on their help site nor could the gauge find them. So as they recommended
    I sent an email to obtain the codes. All I got back was a smart ass reply.
    SO does anyone here know the 4 part codes for oil pressure and manifold pressure ( manifold vacuum ). Or will I have to return it.
    FYI is you have a stick the cable turns right into you left foot operating the clutch. So
    beware.
    thanks in advance
    AmateurTaco1313 likes this.
  2. Jul 28, 2023 at 9:10 AM
    AmateurTaco1313
    AmateurTaco1313 Next truck will be a Hilux
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    Following, have the scan gauge 3 and am interested if you find the solution for this
  3. Jul 28, 2023 at 9:35 AM
    84-4runner
    frank
    Northern Arizona
    2019 tacoma offroad
    @AmateurTaco1313 If I do will share with everyone, scan gauge doesn't seem too interested in their customers.
    have tried looking at older post but everyone seems interested in trans temp which I found.
  4. Jul 28, 2023 at 11:02 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
  5. Jul 28, 2023 at 11:19 AM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    I don't think you will find manifold pressure, it's mass air flow system. Oil pressure as I recall is a low only switch.
  6. Jul 28, 2023 at 11:35 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
  7. Jul 28, 2023 at 12:26 PM
    mattleg
    Kansas
    2020 OR DCSB AT 4WD
    Engine datalist from techstream on my 2020 V6, at idle. No oil pressure or intake manifold pressure. Good chance if techstream does not have it, scanguage will not either.
    2020 Tacoma 2GR-FKS
    [Parameter] [Value] [Unit]
    Vehicle Speed 0 MPH
    Engine Speed 737 rpm
    Calculate Load 17.6 %
    Vehicle Load 14.5 %
    Mass Air Flow Sensor 3.76 gm/sec
    Atmospheric Pressure -1 psi(gauge)
    Coolant Temperature 156 F
    Intake Air Temperature 88 F
    Ambient Temperature 88 F
    Engine Run Time 574 sec
    Initial Engine Coolant Temperature 81.5 F
    Initial Engine Intake Air Temperature 87.1 F
    Battery Voltage 13.6 V
    Accelerator Position 0.0 %
    Throttle Request Position 0.761 V
    Throttle Sensor Position 0.0 %
    Throttle Position Sensor No.1 Voltage 0.761 V
    Throttle Position Sensor No.2 Voltage 2.324 V
    Throttle Position Command 0.761 V
    Throttle Air Flow Learn Value (Area 1) 0.97
    Throttle Air Flow Learn Value (Area 2) 1.04
    Throttle Air Flow Learn Value (Area 3) 1.01
    Low Revolution Control OFF
    Engine Stall Control F/B Flow -1024.00 Nm
    Throttle Position 0.02 deg
    Target Fuel Pressure (High) 344 psig
    Target Fuel Pressure (High) Supported Supp
    Target Fuel Pressure (Low) / Target Fuel Pressure 2 44 psig
    Target Fuel Pressure (Low) / Target Fuel Pressure 2 Supported Supp
    Fuel Pressure (High) 3764 psig
    Fuel Pressure (Low) / Fuel Pressure 2 42 psig
    Fuel Pressure (Low) / Fuel Pressure 2 Supported Supp
    VSV for Vent Valve OFF
    Fuel Pump Control Duty Ratio 22.1 %
    Injector Cylinder #1 (Port) 3260 us
    Injection Volume Cylinder #1 0.090 ml
    High Fuel Pressure Sensor 25.976 MPa
    High Pressure Fuel Pump Duty Ratio (D4) 0.0 %
    High Pressure Fuel Pump Discharge Rate 0.000 ml
    Injection Mode Port
    Injection Timing Cylinder #1 (D4) 0.0 deg
    (CA)
    Injection Time Cylinder #1 (D4) 996 us
    Target Air-Fuel Ratio 1.000
    A/F (O2) Lambda Sensor B1S1 1.006
    A/F (O2) Lambda Sensor B2S1 1.003
    A/F (O2) Sensor Voltage B1S1 3.329 V
    A/F (O2) Sensor Voltage B2S1 3.312 V
    A/F (O2) Sensor Current B1S1 0.003 mA
    A/F (O2) Sensor Current B2S1 0.000 mA
    A/F (O2) Sensor Heater Duty Ratio B1S1 31.2 %
    A/F (O2) Sensor Heater Duty Ratio B2S1 21.8 %
    O2 Sensor Voltage B1S2 0.690 V
    O2 Sensor Voltage B2S2 0.820 V
    O2 Sensor Heater Current Value B1S2 1.054 A
    O2 Sensor Heater Current Value B2S2 1.047 A
    Short FT B1S1 -3.125 %
    Short FT B2S1 -3.125 %
    Short FT B1S2 -0.782 %
    Short FT B2S2 -0.782 %
    Long FT B1S1 -3.907 %
    Long FT B2S1 -0.782 %
    Long FT B1S2 -0.782 %
    Long FT B2S2 -0.782 %
    Fuel System Status Bank 1 CL
    Fuel System Status Bank 2 CL
    Ignition Timing Cylinder #1 20.5 deg
    Knock Correct Learn Value 19.2 deg
    (CA)
    Shift SW Status (Neutral) Supported Unsupp
    Complete Parts Monitor Avail
    Complete Parts Monitor Result Compl
    Ignition Monitor Spark Ignition
    Fuel System Monitor Avail
    Fuel System Monitor Result Incmpl
    Misfire Monitor Avail
    Misfire Monitor Result Compl
    EGR/VVT Monitor Avail
    EGR/VVT Monitor Result Incmpl
    A/F (O2) Sensor Heater Monitor Avail
    A/F (O2) Sensor Heater Monitor Result Compl
    A/F (O2) Sensor Monitor Avail
    A/F (O2) Sensor Monitor Result Incmpl
    Secondary Air Injection System Monitor Not Avl
    Secondary Air Injection System Monitor Result Compl
    EVAP Monitor Avail
    EVAP Monitor Result Incmpl
    Heated Catalyst Monitor Not Avl
    Heated Catalyst Monitor Result Compl
    Catalyst Monitor Avail
    Catalyst Monitor Result Incmpl
    MIL OFF
    MIL ON Run Distance 0 mile
    Running Time from MIL ON 0 min
    Time after DTC Cleared 20 min
    Distance from DTC Cleared 0 mile
    Warmup Cycle Cleared DTC 1
    Distance Traveled from Last Battery Cable Disconnect 2741 mile
    Number of Emission DTC 0
    Ignition Trigger Count 493
    Misfire Count Cylinder #1 0
    Misfire Count Cylinder #2 0
    Misfire Count Cylinder #3 0
    Misfire Count Cylinder #4 0
    Misfire Count Cylinder #5 0
    Misfire Count Cylinder #6 0
    All Cylinders Misfire Count 0
    Misfire Margin 87 %
    Previous Trip Coolant Temp 156 F
    Previous Trip Intake Temp 88 F
    Previous Trip Ambient Temp 82 F
    NT Sensor Speed 700 rpm
    Shift SW Status (P Range) ON
    Shift SW Status (R Range) OFF
    Shift SW Status (N Range) OFF
    Shift SW Status (N,P Range) ON
    Shift SW Status (N,P Range) Supported Supp
    Sport Shift Up SW OFF
    Sport Shift Down SW OFF
    Shift SW Status (S Range) OFF
    Shift SW Status (D Range) OFF
    Shift Status 1st
    musicisevil likes this.
  8. Jul 28, 2023 at 12:33 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    You drove 200 miles? Why not just talk to the engineer on the phone?
    Anyway, the person above is correct. Just because the gauge supports the reading does not mean the vehicle has that data available. This would be true of all OBDII scanner type things - the ECU will not report data for a sensor or reading that does not exist in the vehicle.
    There are posts on here of guys (with 2nd gen trucks) who tee into the oil switch fitting and plumb in a real pressure gauge into the cab (or an aftermarket electronic sending unit and custom gauge in the cab). If you really want the data that would be the only way
  9. Jul 28, 2023 at 12:44 PM
    84-4runner
    frank
    Northern Arizona
    2019 tacoma offroad
    For some reason the engineer is afraid of phones or refuses to talk on the phone.
  10. Jul 28, 2023 at 12:49 PM
    Clearwater Bill
    Billy
    Largo Florida
    SR-71A[QUOTED] likes this.
  11. Aug 1, 2023 at 3:57 PM
    84-4runner
    frank
    Northern Arizona
    2019 tacoma offroad
