Need advice, used vehicle GX470
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jrain904, Jan 19, 2020.
  1. Jan 19, 2020 at 7:01 AM
    jrain904
    jrain904 [OP] Well-Known Member
    First of all I LOVE my 3rd gen taco. With another kid on the way, however, I am considering moving on to a used Lexus gx470. With the equity I have on the Taco I can almost do an even trade. I am looking at two different gx470's right now, a 2003 and a 2004. the 2003 has 20,000 more miles but has very detailed maintenance records on Carfax with two owners both of whom owned it for very long periods of time. the 2004 has 20000 less miles but not very detailed maintenance records on Carfax (shows new registration each year but no maintenance until second owner in 2017). The first owner owned until 2017 and the second owner only owned for 2 years (weird right?). How much emphasis do you put on Carfax reports? I have not test driven either yet. What advice does everyone have? The 2003 has 128,000 and the 2004 has 149,000.
    Superdave1.0 likes this.
  2. Jan 19, 2020 at 7:42 AM
    Mojlnir
    Mojlnir Well-Known Member
    Parker, CO
    2018 SR ACLB Utility Pkg
  3. Jan 19, 2020 at 7:58 AM
    Friggin Fuego
    Friggin Fuego Well-Known Member
    2004 Toyota Land Cruiser, 2007 Toyota FJ Cruiser 6MT 4x4, 1988 Toyota Hilux SSR Diesel 5MT 4x4
    Carfax reports things but not all things. The GX470 has the same V8 as my Land Cruiser. Definitely check the timing belt and water pump to see the condition they are in. It is recommended that they both be changed out at 90k mile intervals. Make sure those vehicles had it done. Other than that, the engine and drivetrain are solid.
    jrain904[OP] likes this.
  4. Jan 19, 2020 at 8:16 AM
    ian rogers
    ian rogers Well-Known Member
    Ian
    Sf Bay Area
    69 fj40, 2019 OR manual
    Locked Sliders Roll cage H41
    FYI- I have three kids and they fit in the Tacoma. I do also own a land cruiser, it’s a wonderful suv. Seats 8 and is amazing in the dirt. I guess I actually own two land cruiser, the kids don’t ride in the fj40.
  5. Jan 19, 2020 at 8:51 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    "Fit" and "Comfortable Fit" are two different things. The Tacoma was just for me and occasionally my wife as at the time I drove close to 90K miles in two years. Now my driving is down to 20K a year and I have more business passengers I drive the Tundra. Much bigger back seat and softer too.
    So yes, you can fit three in a Tacoma back seat. Are they comfortable? Not unless they are awful small lol.
    Skydvrr likes this.
  6. Jan 19, 2020 at 9:08 AM
    Hstone556
    Hstone556 Ain’ters gonna ain’t
    Hunter
    Austin
    2019 Ram 2500 Laramie
    Raceline 17" Gauge's 37x12.50 Toyo's RT, Carli King 2.5s
    I dont know how much research you have done on the year model changes but.. in 2006 Lexus updated the diff supports. Not a big deal, but one less thing to do. 2005 they added VVTI.
    2003 and 2004 can use a Tundra 4.7 Supercharger if you can find on and if you want one.
    in 2007 for the model year 2008, the GX 470 received styling updates, including a dark metallic grille, liquid graphite wheels, added exterior and interior chrome, revised turn signal lights, and added wood and body color options.
    If you want a modern Nav/DVD screen unit, make sure you buy a Non Nav model. If not, you could still upgrade the sound system but you'll only be able to replace the tape player with a single DIN sized unit and you'll have to bypass the stock amp. Just some stuff i had saved when i was on my search for a GX myself. I ended up with a 3rd gen 4Runner and do not regret it.
  7. Jan 19, 2020 at 9:10 AM
    jrain904
    Any of the generations generally thought of as better than another?
  8. Jan 19, 2020 at 9:10 AM
    mmcarbo
    mmcarbo Well-Known Member
    Massachusetts
    Make sure you carefully check the frame for rot. Also, the rear air suspension and exhaust manifolds can be an issue.
    GreyBaldTaco likes this.
  9. Jan 19, 2020 at 9:10 AM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    Make sure you change out the front brakes on the 470's for the 460 brakes.
    Water pump and timing chain should be done at 90k, if not see if you can get that worked into the deal.
  10. Jan 19, 2020 at 9:13 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Just curious, what they are asking for GX470's? Around here 03/04's with those miles are going for 8 to 9K. Because you mentioned, enough equity to do possible even trade. There's a few 08's under 100k miles for 12 to 14K
  11. Jan 19, 2020 at 9:15 AM
    Bishop84
    Bishop84 Well-Known Member
    Listen for exhaust leak on cold start, very common.
    Coolant leaks from water pump and radiator.
    Timing belt history.
    Suspension condition, the shocks and air ride are very expensive to repair if they have failed.
    Make sure to get an independent inspection!
  12. Jan 19, 2020 at 9:27 AM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    An absence of Carfax maintenance items could simply mean the owner preferred to do the easy maintenance themselves...lots of people do their own oil changes.
  13. Jan 19, 2020 at 10:41 AM
    Friggin Fuego
    I personally would prefer a GX460. You can get a base model without air suspension. Plus, you can spend $600 on OEM parts to get you crawl control and mult-terrain select that is already pre-wired in the vehicle.
  14. Jan 19, 2020 at 10:45 AM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    I LOVE our gx470. Both of those examples are considered low miles. I bought mine for $5500. But that's because it had 220k when I bought it. These trucks really run forever. The power, options, quietness of the gx470 will blow you away compared to the rugged tacoma. Plus it is equally or even more capable offroad. Get one!!
  15. Jan 20, 2020 at 7:06 AM
    jrain904
    Seems that around here its about 11 - 13k for low mileage (under 150k) and clean interiors and around 8 - 9k for higher mileage (175k-200+k) with worn/ripped interiors. I am looking at the 12k-13k vehicles.
    robertjohnsonjr likes this.
  16. Mar 9, 2020 at 11:34 PM
    robertjohnsonjr
    robertjohnsonjr Just looking for help from og tw
    B
    Tacoma
    2001 xtra cab 3.4 manual 4x4 tacoma
    No more 33s, exhaust,auxilary battery for lights and woofers, canopy w auxilary power...ditching hids soon
    What does it take to get a locking diff on one? Seems to be a great feature on the Tacoma
  17. Mar 10, 2020 at 9:26 AM
    Superdave1.0
    SoCal
    Many options. ARB locker is popular. I think it's about $1,000 in parts.
