NAPA Drive Axle (CV Axle) Differences?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MolonLabeTaco, Mar 15, 2019.
  1. Sep 10, 2020 at 10:19 PM
    #41
    DKTaco78
    DKTaco78 Member
    Derrick
    2018 Tacoma Trd Off-Road
    Stock
    Life is too short to not use Oem parts.
  2. Oct 25, 2021 at 8:45 AM
    #42
    Phil P
    Phil P Active Member
    2010 Tacoma 4 door 4X4
    None
    Hello Lady’s & Gentleman
    I have now 7 Tacoma 4X4 in the fleet.
    Some are TRD and some are unmarked.
    However, I have just gone thru this Design 1 and Design 2 issue with Cardone a manufacturer of aftermarket axles that NAPA sells.
    They advised me that Toyota has a different part number for the axle in the second-generation Tacoma TRD than for the other second-generation Tacoma 4X4 pickups.
    And Cardone does not make or rebuild the axle called out by Toyota for the second-generation Tacoma TRD 4X4.
    Now as a follow-up on that statement I have been using the NAPA axle in all of our second-generation Tacoma 4X4 without issue.
    Phil P
    Marc70 likes this.
  3. Oct 25, 2021 at 4:14 PM
    #43
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    Thats not true. All "Trd" options are just "base" model trucks with a TRD option.
    Check out the "fitment" section of this page. All (2nd/3rg gen) 4wd tacomas have the same shafts.
    https://parts.olathetoyota.com/oem-parts/toyota-cv-axle-left-right-front-4343004071
  4. Oct 26, 2021 at 9:16 AM
    #44
    Phil P
    None
    I did not say they were different. Just that both my dealer and Cardon tell me the Toyota part number is different for the TRD than the standard Tacoma 4X4.
    Cardon takes the position that their axle only replaces the axle for the standard Tacoma 4X4 this is probably a liability dodge issue their lawyers have advised them to take.
    NAPA doesn’t even acknowledge there is a Tacoma TRD.
    Phil P
  5. Oct 26, 2021 at 9:17 AM
    #45
    Phil P
    None
    Now for all of you:
    Just what is a TRD option?
    Phil P
  6. Oct 26, 2021 at 11:23 AM
    #46
    ZColorado
    13 DCSB OR 6MT
    The Toyota OEM parts catalog shows all the Tacoma 4WDs take the same axle. It even calls out TRD pro, TRD, SR, etc. Look at the link I posted above.
    sounds like your parts department and napa are confused.
  7. Oct 26, 2021 at 11:25 AM
    #47
    ZColorado
    13 DCSB OR 6MT
    Check out this screen shot from the "Fitment" section. Thats all the models of 4wd Tacoma made.... both engines, and all trims.
    Beware that a TRD package will pull up in the Toyota VIN lookup as a "Tacoma Base" They only called them different toyota models for the 3rd gens. I've seen some great used car deals when dealers dont realize they are selling a TRD option listed at base prices. (although now thats not happening due to the chip shortage)
    CV Axle (Left, Right, Front) - Toyota (43430-04071)
  8. Feb 8, 2022 at 6:33 PM
    #48
    singletrack_ftw
    singletrack_ftw “I chopped the wrong leaf!”
    Tyler
    AZ
    ‘08 TRD OR 4wd
    https://www.tacomaworld.com/threads/singletrack’s-‘dad-shred-build-thread’-i’m-just-doing-it-for-the-kids.619250/ Sos offroad sliders (kickout + filler) Sos offroad full belly skids (steel) Sos offroad front recovery point Sos offroad concepts HC rear bumper with bedside kickout tubes Marlin Crawler LCA frame brace kit Trail Gear rear diff cover Bilstein 5100 + OME 885 Total Chaos UCA BILSTEIN b110 OME Dakar standard pack Wheelers Ubolt flip kit Wheelers Superbump f/r Wheelers SS extended brake lines FN five star 16x8 -25 Milestar Patagonia MT 315/75r16 Custom projector retrofit (acme super h1 + morimoto 4300k) Baja Designs S2 sport ditch pods on CBI ditch pod mounts Amazon AMAK rock lights CMC CB radio hardmount
    Still no regrets running Napa HD $120 axles. I will continue to run them as long as I’m stock travel on the front end. The lifetime no questions asked replacement warranty is unbeatable. We’ll see if they tolerate locked front end and 37’s but they have been fine with front end locked on 35’s.
    b_r_o, lo2hi and TnShooter like this.
  9. Feb 8, 2022 at 6:37 PM
    #49
    singletrack_ftw
    Tyler
    AZ
    ‘08 TRD OR 4wd
    Also FWIW here is my cv angle with my 2.3” lift and 37’s and “full armor” lol
    k_j_souv and TnShooter like this.
  10. Feb 19, 2022 at 7:16 PM
    #50
    BroID
    BroID Well-Known Member
    The Gem State
    2017 Tacoma TRD off road
    BFG KM2 255/85r16 Bilstein 5100s OME 888, HD Dakar’s, JBA control arms, BAMF Shackle hangers and shackle.
    I’m in the boat of needing to replace my CVs on my taco. 52k miles lots of off-roading and broke one not being responsible after letting things get to me after spending lots of time getting another rig unstuck in a freezing creek. I ended up just slipping out the shaft to get out and home. Napa has three new cvs for our trucks. I don’t see a HD one though. There is one for $122 (NCV 944082)another that looks very similar for $120 (NCV 944052). I think those are the same. Then there is the extreme duty one for $220. Do you know what one your running. With inflation and prices changing I’m double checking that your $120 CV didn’t go up to $220. Thanks!
  11. Feb 19, 2022 at 7:17 PM
    #51
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Go look at them in person if you can. There part numbers are very unreliable
  12. Feb 19, 2022 at 7:34 PM
    #52
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I'd check for a dealership reman axle. I've used them on Sequoia and Tundra, they were always good quality. They're cheaper than you would expect
  13. Feb 19, 2022 at 9:08 PM
    #53
    singletrack_ftw
    Tyler
    AZ
    ‘08 TRD OR 4wd
    They have changed their whole lineup offering since I ordered. I just look for their most expensive non reman one and buy that
  14. Feb 19, 2022 at 9:14 PM
    #54
    BroID
    The Gem State
    Awesome thanks! Happy trails!
  15. Mar 2, 2022 at 10:01 PM
    #55
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Those CVJ high angle axles outer black neoprene boots start cracking in 6 months. Completely tore apart in less than 2 years and I don’t even off road.
    Seems like Napa is constantly changing their cv axle product numbers. But after reading this thread I’m getting the extreme environment with thermo plastic boots NCV 941532. Hoping they will be in stock soon enough.
    Hunterdc1 and 6 gearT444E like this.
  16. Jul 20, 2022 at 5:47 PM
    #56
    crhsharks12
    crhsharks12 Well-Known Member
    Denver, CO
    ‘06 Tacoma 4WD TRD Sport DCSB 4.0L V6
    RR 2.5 King shocks front/rear, Camburg UCA's, Icon AAL Springs Softopper & BA Bumper
    Soooo, what is the consensus here? NAPA Axles still going strong? I might get some of the HD ones real soon here since I have blown boots on both sides. 1 outer, 2 inner.
    I have a 1.5” lift with a camburg UCA, stock LCA’s and a stock spindle. The shocks are extended travel, although I doubt I get that much more travel at all. I’m sure the axles would be fine.
    TerryTac0 likes this.
  17. Jul 20, 2022 at 5:53 PM
    #57
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    I’m also curious about the non-OEM axles.
    Does the warranty cover torn boots?
  18. Jan 3, 2023 at 10:15 AM
    #58
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    Anyone know what the difference is between part # NCV 944052 and NCV 944082? 944052 was showing first edition and 944082 was showing second edition in the store.
  19. Apr 4, 2023 at 4:31 PM
    #59
    Skawdee
    Skawdee SKOL Vikings!
    Star Valley, Wyoming
    2009 Tacoma TRD-Offroad, 6-spd Man.
    Old Man Emu 2.5” Full Suspension Lift w/ Wheeler's Off-Road Progressive Leaf Pack JBA Upper Control Arms Moog Lower Control Arms Victory4x4 Strike Front Bumper w/ Grill Tubing Morimoto XB Headlights Baja Designs Squadron Sport Amber Fog LED’s Baja Designs 20” White LED Light Bar Over-sized BFG All-Terrain Tires K&N Stock Replacement Air Filter Pioneer AVIC-W8400 Head Unit Apple TV Wireless Phone Charging Pad Bed rail mounting with ax, shovel, MaxTrax Bed Extender
    Lesson learned - DO NOT try to pull out a Chevy 2500HD by hooking up to the front recover hook and reversing in full turn. The angle of that CV boot and torque put on that literally exploded the outer knuckle. Alas, I had replaced my CV's a few years ago and had that 1 covered. I decided to pay the difference to upgrade to their newer "Extreme Weather" version. We'll see the test of time and demand on the CV's here in Western Wyoming as I'm not too easy on my rig, but take good care. We have harsh winters, I hunt and camp, etc.
  20. Apr 4, 2023 at 6:50 PM
    #60
    Naveronski
    Fort Worth
    Dont pull in reverse anyway. :broccoli:
