Napa brakes and rotors?
Discussion in '1st Gen. Tacomas (1995-2004)' started by SouthernYoder, Jan 2, 2020.
  1. Jan 2, 2020 at 11:37 AM
    SouthernYoder
    SouthernYoder [OP] If you skarred, say you skarred.
    Knoxvegas, TN
    01 dbl cab 4x4 3.4l SR5
    3" OME, 883 coils, Nitros, AAL, 07 FJ Trail team wheels, K&N CAI, Tundra brake upgrade.
    Alright folk, gonna get some new pads and rotors from Napa here locally before I do my needle bearing on my driver side. From what I’m finding all they have is their house brand on the shelf. What are your all’s opinion on their house brand stuff. TIA
    Taco critter likes this.
  2. Jan 2, 2020 at 11:44 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Before you do that, I recommend upgrading to Tundra pads, rotors, and Calipers. They’re 231mm instead of the stock I believe 197mm.
    ELMO67 and Taco critter like this.
  3. Jan 2, 2020 at 12:02 PM
    SouthernYoder
    Knoxvegas, TN
    Your right, there is no doubt about that. I wonder if they would have those in stock as well?
    also, this truck isn’t a wheeler anymore, it’s going to be a grocery getter now that I’m expecting a little one and a boat/kayak hauler.
    Which brake lines for that conversion was people using again without having to drill out the banjo bolt?
    I know, search button is your friend but I’m being lazy af and I can have my thread to look back on when I run this up lol. Thanks.
  4. Jan 2, 2020 at 12:12 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I eliminated the banjo bolt completely and just used the stock hard lines from the Tundra. LC Engineering sells a brake line conversion kit with SS brake lines for about $170.
    ToyotaDriver likes this.
  5. Jan 2, 2020 at 12:19 PM
    SouthernYoder
    Knoxvegas, TN
    Ya I thought about that, but I’m not much of a fan for those hard lines right there.
    13WL calibers with the wheelers brake lines? Is that correct since the wheelers lines comes with new banjo bolts?
    Edit: Slow work day and trying to understand a little better before I rip this thing apart.
  6. Jan 2, 2020 at 12:29 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Yeah I think the Wheelers is another option. I don’t know about banjo bolts though. You can drill the stock ones and use the stock lines no issue.
  7. Jan 2, 2020 at 12:30 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Also, the 3rd Gen 4Runner has an identical hard line setup to the 1st Gen Tundra. One way to save money is just buy brake lines and components made for a 1996-2002 4Runner. They don’t have banjo bolts like us.
    2002Tacoma4x4 likes this.
  8. Jan 2, 2020 at 12:33 PM
    SouthernYoder
    Knoxvegas, TN
    Interesting. I’d really like to use the 13WL calibers and the wheelers lines. Guy from wheelers said it would work with their banjo bolt. I may have to stack copper washer but oh well. Hopefully someone else has this set up and can chime in. Overall, I’ll compare the price with piecing this together and the LCE kit and make a decision. Thanks.
  9. Jan 2, 2020 at 12:52 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Parts store brakes are fine as long as you stick to the high level stuff. Napa adaptive one is good if they have it for our trucks. Also get the premium coated rotors. Also flush out your lines real good with fresh fluid.
    Imo, the tundra upgrade is overrated for people who arent towing a lot or arent on big tires. A good flush/bleed paired with new ceramic pads and rotors is a great combo. I have zero complaints with my stock brakes.
    Edit: Oreillys is having 15% off when you bundle a set of Brakebest pads with two rotors. Its Bosch stuff. Ive done two brake jobs this month with their parts, no complaints.
    hfjeff, Wyoming09 and CS_AR like this.
  10. Jan 4, 2020 at 8:12 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Like Tyler says, Tundra is a good option. There are a couple ways to go with this upgrade - you can do a kit, but IMO you get better results (braking) by going with OEM (or OEM reman) components. You can read about my experience in the links below... is going to depend on the quality of parts you get, so is a bit unpredictable.
    I should say that I first installed 13WLs with no problem using Wheelers banjos and they worked great for a year. That's this post:
    New-to-me Tires and a Tundra Brake Upgrade (and here's a good argument/data about going with quality components)
    On a trip this year, when I was running the Lolo Motorway, I had a caliper seize up on me. I had to replace it on the trail. That's here:
    IDBDR Pt. 7 - The Curse of the Lolo Motorway
    After the trip, I thought a bit about my repair experience (above), and how I got into the situation in the first place. That is this Rig Review:
    Rig Review: Idaho July 2019 - What worked and what didn't?
    Finally, I decided to go a different route than the Wheelers banjo lines. I decided that doing the job "right" (or maybe, "completely"?) was the best approach. Here:
    Making It Right: Tacoma-to-Tundra Brake Upgrade
    Shoot if you have questions. Reach out if you want a hardline kit for way less than LCE.
    You know, there's a hardline kit now that's only $110 :p.
    Sort of. Some of the parts will work, but not all. That's actually the reason a custom kit is necessary. Especially the stainless steel flex lines - which are significantly different for the Taco than the 4Runner.
  11. Jan 4, 2020 at 8:14 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Your hardline link is broken Dan haha
  12. Jan 4, 2020 at 8:15 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    I don't think so...
  13. Jan 4, 2020 at 8:22 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Guy just wanted new rotors and pads, he doesn’t need the tundra brakes.
    If you offroad with big tires, or maybe tow heavy loads, sure, the tundra brakes are a good upgrade, but they also tend to make your brakes feel squishier and they also ~double the cost of a pad and rotor job.
    So to answer OPs question, yes, napa parts are fine.
  14. Jan 4, 2020 at 8:28 AM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    I have the wheelers brake lines with the callahan tundra brake kit and have had zero issues.
  15. Jan 4, 2020 at 9:37 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    I got a 404 earlier. Looks like it’s working now.
  16. Jan 4, 2020 at 9:44 AM
    jbrandt
    Justin
    maybe your internet sucks.
  17. Jan 4, 2020 at 9:46 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    Totally true. Napa parts are good either way, really.
    SouthernYoder[OP] likes this.
  18. Jan 4, 2020 at 10:04 AM
    SouthernYoder
    Knoxvegas, TN
    did you buy those parts at Napa or resourced them somewhere else?
  19. Jan 4, 2020 at 10:20 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Any more I use all Napa Brake Parts the delivery Woman is cute might have some bearing in the decision
  20. Jan 4, 2020 at 10:44 AM
    tntacomaguy
    tntacomaguy Well-Known Member
    I'm running the Napa Adaptive1 pads and Napa coated rotors on my truck. No complaints here, I was wanting to upgrade to the Tundra brakes but had to replace the brakes before I could afford to upgrade tires and wheels. Unless something changes my mind before the next time my brakes are due, I'll most likely go with Napa brakes again.
