My Winch Cradle Setup
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HolyHandGrenade, Dec 10, 2015.
  1. Dec 10, 2015 at 8:10 PM
    HolyHandGrenade
    HolyHandGrenade [OP] NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I know a bunch of you guys got in on the Mobtown black Friday sale. So, this might help some of you who bought their recovery bar?
    Parts:
    Mobtown Recovery Bar with receiver:
    http://mobtownoffroad.com/product/front-recovery-bar/
    Mile Marker Winch Cradle:
    http://www.amazon.com/gp/product/B0008F68NK?psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s00
    Winch Wiring:
    http://www.amazon.com/gp/product/B00VVZLYYY?psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s01
    HD Alligator Clips:
    http://www.amazon.com/gp/product/B000XMI1JC?psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s00
    Jumper Cable Bag:
    http://www.amazon.com/Bucket-Boss-6...263_img_2?ie=UTF8&refRID=0N0NANAM3S2CECWR5GEQ
    ComeUp Seal Gen2 9.5 Winch
    http://shop.comeupusa.com/p/seal-gen2-9-5rs-12v-winch?pp=12
    Factor 55 ProLink:
    http://www.amazon.com/gp/product/B009X1XJWI?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s01
    First, I installed the Mobtown Recovery Bar
    7101F0B4-62EC-4F80-9687-1529ACC80A43_zps_35e93bd07bb229390425017cd428fd28d4bac872.jpg
    Next, I bolted the winch to the FIRST winch cradle. IT was welded together crooked...
    82590D55-5834-4A97-9FD7-37EF66E0A3E3_zps_a9549efcd52ab404c55bd42b80112002ff854390.jpg
    So, I returned the first cradle and bought another that was three times the price... The second one was perfect... Almost
    B3A4FC34-8367-4D6A-9030-229B97DDD31F_zps_9e54c602e6105bd57541d03f7d4cae19e2d3d3d5.jpg
    It's put together straight, but it stuck out from the grill way too far for me.
    7584F292-29FD-4920-85A1-BB8B5188468A_zps_3613198e907296b687c60bd5d128a444c3dfffce.jpg
    So, after measuring front and rear, I introduced it to the chop saw and drilled a new hole for the receiver pin.
    A55B1391-76A4-48F4-AF46-B4DA6DCD345C_zps_379570f03bea4253ace32474285e306dc9dc9e29.jpg
    Much better
    C9BDF022-68F1-43C0-9F95-4F9AB48E8B4C_zps_ab150e7934af92a7a58a0c32acb79908ae9b08c1.jpg
    Still fits the rear after the trim
    77AC3F7A-1902-4518-A0AE-E976049C89D1_zps_246acc03096bb878c1d31b53591fbf251535a9a0.jpg
    Close...
    1AFE0D12-236D-411B-B664-DDF17B23EB6D_zps_a8f07ad54f4c777c989904021b658c080a2ed7f4.jpg
    For the wiring, I purchased the kit I linked to above.
    It came with two 3' lengths of cables with disconnects for the winch and for the front of the truck. I hooked one to the winch, and one directly to the battery terminals and stuck it through the grill.
    The kit also came with a 20' plus set of cables with disconnect for the rear. I didn't feel like running the cables under the truck. Instead, I bought some jumper cable ends and crimped them on.
    6AD5FD3D-644B-496B-88D8-259C0DE91045_zps_b35b9d8555c9902056bca26d8e4fcd05125aaf60.jpg
    These cables were not connected to one another like jumper cables are. So, I ran electrical tape down the entire length of cable to make them easier to handle and store.
    22064209-5F1C-4447-90BE-6209FF1F9826_zps_ab14bff8c2c6293b4cee8b42497326d82b8231f7.jpg
    And lastly, rolled it up neatly, put it in the jumper cable bag, and put it in the toolbox.
    ACF9E3DA-B931-4717-860D-045039D0F860_zps_2fa3cfe91e12a3f56175ee8c786c168b96bae2f7.jpg
    D41C4D5D-A8DE-4D2E-98C2-B330797182B1_zps_d98fc530ce2d1f4fcf890c60e66231e3a0613248.jpg
    C013A1E2-9B74-45D1-B2B5-693D8BF1A030_zps_3c1b539881138d0c5ddc868138c0fe25eda07d00.jpg
    I also had a cover made for it out of tonneau cover material. It ruins the "look" for sure, but I'm hoping It'll keep salt and road grime off of the synthetic rope.
    72F6697D-2397-4D5C-83C1-108BC3AF7AF6_zps_c61b9e51b4ced3a3cc55bb9d518a48de07fd6e83.jpg
    Wow... That took forever... Hope it helps!
    Oh, don't forget to pick up a locking hitch pin :thumbsup:
    yesmar, DoorDing, taco-man and 2 others like this.
  2. Dec 10, 2015 at 11:33 PM
    DC-USAF
    DC-USAF Well-Known Member
    Dale
    WNC
    2015 SR5 Access Cab 4x4 V6
    TRD PRO Grill, mobtown offroad recovery bar, SCS Ray 10's
    I've been making a list of items that I thought I would need once my recovery bar comes. You have saved me alot of time searching for parts and im sure more people will also appreciate your help. Thanks for taking the time to do this.
  3. Dec 11, 2015 at 4:55 AM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    No prob. Good luck!
  4. Dec 11, 2015 at 7:18 AM
    Pigpen
    Dan
    Northwest Montana
  5. Dec 11, 2015 at 7:24 AM
    SportsmanJake
    SportsmanJake Well-Known Member
    VA
    2006 Tundra
    I am assuming you will keep it in the cab unless you actually need to use it or are in a situation where it might me needed?
  6. Dec 11, 2015 at 8:48 AM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Thank you. I almost went With the Warn Cradle myself.
    Nope. I leave it on the front. That's the reason I went with 886's when I did the lift.
    That's also why I had the cover made.
  7. Dec 11, 2015 at 7:19 PM
    yesmar
    yesmar Well-Known Member
    Ramsey
    Harrisburg, PA
    A couple cars
    this is the winch set up I'm aiming for. you can't beat the option of front and rear winching on the fly. but ill only be rocking it when i need it
    my only question why would you leave it on all the time? Isn't one of the luxuries of having a mobile winch set up so you don't have to drag it around with you everywhere you go, no?
  8. Dec 11, 2015 at 7:30 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    The luxury is having options. I can take it off if I want. That is nice.
    But, one thing I know for sure, when you need the winch, you don't want it to be sitting in the work bench. ;)
  9. Dec 11, 2015 at 7:36 PM
    yesmar
    Ramsey
    Harrisburg, PA
    A couple cars
    yeah i hear that, I'm going to keep mine in my toolbox on my truck.
    Keep this thread updated when you use it. I'm sure its not as sturdy as one bolted to a plate bumper but i know it will get you out.
    deff going with this style set up.
  10. Dec 11, 2015 at 7:38 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Will do. I'm looking forward to using it. I'm not looking forward to being stuck. I'm so conflicted...
    yesmar[QUOTED] likes this.
  11. Dec 11, 2015 at 7:41 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Another reason I leave it on, is that I put 886's on with the lift. I know I'm going to do sliders and armor at some point. Didn't want to have to do the coils twice. The winch up front helps break the 886's.
  12. Dec 11, 2015 at 7:43 PM
    yesmar
    Ramsey
    Harrisburg, PA
    A couple cars
    hey, how much would you say the whole cradle and winch weigh? like just what you'd be pulling on and off the truck
  13. Dec 11, 2015 at 7:50 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    The winch is 85 lbs with synthetic rope. The cradle is 30 lbs. 115 lbs. Not too bad.
  14. Dec 11, 2015 at 8:25 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    That's easy - rescue some poor stranded jeep.:bananadance:
  15. Dec 11, 2015 at 8:46 PM
    Pigpen
    Dan
    Northwest Montana
    Interesting... I'm running steel line. I wonder what my setup weighs now. I would have guessed less than that.
  16. Dec 11, 2015 at 8:58 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    I just checked their site. Synthetic is 89.1 lbs. wire is 116 lbs. so, another 25-30 lbs depending on rope length. Theirs are both 100'.
    Jtaoj0 and Pigpen[QUOTED] like this.
  17. Jan 6, 2016 at 7:30 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    yesmar likes this.
  18. Jan 6, 2016 at 7:53 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    That'll keep it out of your way. Gonna be a pain to lift the lid on that box now, though.
  19. Jan 6, 2016 at 7:56 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Yeah, this is true. It's all recovery gear and such in there. If I need to get in, chances are, I'll need the winch anyway... :thumbsup:
  20. Jul 5, 2016 at 12:04 PM
    deeve
    deeve Well-Known Member
    Dave
    Hillsboro, OR
    2015 TRD OR SB MGM
    Great post...Thanks for the write-up. I am curious on your thoughts regarding the hitch pin strength for recovery. It seems that would be a weak point, but I have never used one so I am curious. I like the low profile of the Mobtown recovery front bar.
    Thanks!
    DAVE
