My truck stops running everytime I appy my brakes
Discussion in 'New Members' started by O.D. 96 T100, Dec 6, 2018.
  1. Dec 6, 2018 at 10:20 AM
    O.D. 96 T100
    O.D. 96 T100 [OP] Member
    1996 Toyota T 100
    none
    Im puzzled as to why my truck dies when I apply brakes?? any ideas??
  2. Dec 6, 2018 at 10:22 AM
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    Probably going to need a bit more info on the truck. Automatic transmission? Shuts off the moment you press brakes or as it comes to a stop?
    Welcome to tw
  3. Dec 6, 2018 at 10:24 AM
    O.D. 96 T100
    1996 Toyota T 100
    none
    yes automatic.. 3.4 liter... extened cab ... not a 4 wheel drive.. no electric windows.. it only had electric door locks but they have been disconnted for years
    irayfz6 likes this.
  4. Dec 6, 2018 at 10:25 AM
    O.D. 96 T100
    1996 Toyota T 100
    none
    new altenator, new ground also
    irayfz6 likes this.
  5. Dec 6, 2018 at 10:27 AM
    O.D. 96 T100
    1996 Toyota T 100
    none
    shuts off the moment brakes are applyied
    irayfz6 likes this.
  6. Dec 6, 2018 at 10:28 AM
    O.D. 96 T100
    1996 Toyota T 100
    none
    I am at at loss... so glad to have found this site
    irayfz6 likes this.
  7. Dec 6, 2018 at 10:28 AM
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    Earth, 3rd planet from the Sun (CO)
    1996 Single Cab Taco Manual 4x4 3.4L V6 370k /1985 4Runner 4x4 22RE 200k /2001 Double Cab Taco Auto 4x4 Supercharged 3.4L V6 180k
    1996-JBA upper control arms, replaceable Cardan joint drive shaft, leveling kit, camper shell, trailer hitch... 2001- TRD Supercharged, TRD headers...
    Check for vacuum line leaks.
    Maybe your vacuum booster for your brakes has a leak.
    127.0.0.1 and irayfz6 like this.
  8. Dec 6, 2018 at 10:29 AM
    O.D. 96 T100
    1996 Toyota T 100
    none
    also new ignition also
    irayfz6 likes this.
  9. Dec 6, 2018 at 10:29 AM
    O.D. 96 T100
    1996 Toyota T 100
    none
    will do thanks
    irayfz6 likes this.
  10. Dec 6, 2018 at 10:32 AM
    Trouble_The_Tacoma
    Trouble_The_Tacoma Well-Known Member
    Conrad
    Check for loose or disconnected engine control module or body control module. When I was a younger man I was driving my step dads F150 and the truck just shut off. Had to push it home with my brother. Couldn’t figure out what it was but basically the electronics disconnected from the engine.
    Edit* I meant engine control harness. Check that as well.
    irayfz6 and 96BlueTacos like this.
  11. Dec 6, 2018 at 10:39 AM
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    That would be my first guess.
    I could be wrong, but I think that the brake booster has an idle-up vacuum line to increase the idle of the engine when you hit your brakes so it doesn't bog out. similar to the AC idle up, and also the power steering pump has an idle up. These all take quite a bit of power, so the trucks vacuum system will keep the idle at proper levels when those accessories are added into the power needs of the truck.
    Im no mechanic or anything, so don't go taking apart your booster based on this, but, this is where I would start looking.
    Sounds like you have a bad leak, or an unconnected hose, or maybe an electrical connection disconnected, something related to the brake system..
    And i've seen some guys talk on here about that vacuum booster springing a leak internally in the booster that you can't fix. Hopefully its an easy fix.
    irayfz6 likes this.
  12. Dec 6, 2018 at 12:41 PM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    :wave:
    Electrical.:confused::notsure:
    irayfz6 likes this.
  13. Dec 6, 2018 at 12:49 PM
    O.D. 96 T100
    1996 Toyota T 100
    none
    there is NOTHING working on the dash... the gas light, alt light none of the instrument panel does not work... when i put the lights on high beam the truck dies...
    irayfz6 likes this.
  14. Dec 6, 2018 at 1:18 PM
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    have you had your battery load tested? Sometimes they will hold the charge but once a load is drawn the volts will plummet
    or have you put a multimeter on the battery to even see if you've got the charge you need?
    irayfz6 likes this.
  15. Dec 6, 2018 at 1:27 PM
    BINK05TRD
    BINK05TRD Well-Known Member
    Massachusetts
    TRD OR AC SILVERSKY 15
    Remote starter ?
    irayfz6 likes this.
  16. Dec 6, 2018 at 10:53 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    Welcome!
  17. Dec 7, 2018 at 5:39 AM
    Trouble_The_Tacoma
    Conrad
    That was helpful
