My truck just died while driving?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OldManTacoFeels, Feb 9, 2021.
  1. Feb 9, 2021 at 6:36 PM
    OldManTacoFeels
    OldManTacoFeels [OP] The bells of tacos
    Billy Jr.
    2012 DCLB SR5
    Bilstein 5100s, AFE dry intake, Icon AAL pack, Bed stiffeners, and ideally some UCAs soon
    So I’m driving and my trucks stereo starts flashing on and off, then all the lights get dim and the gauges jump around a bit, I start losing power in the pedal, so I start pulling over, all the “oh fuck” lights turn on the dash.
    I turn my truck off, and try to turn back and no starter clicking. Just dead.... wtf just happened
  2. Feb 9, 2021 at 6:38 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Sounds like the alternator died and you were running off the battery until the battery just gave up the ghost.
    Hopefully that's all you've let rhe Magi smoke out of.
    Check your serpentine belt as well, it's possible the alternator is fine, but the belt broke and you just flattened your battery.
    Man I wish these trucks had battery and oil pressure gauges like the Tundys.
  3. Feb 9, 2021 at 6:48 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Still should have seen the big red battery warning light from no charge on the alternator. If your SERP is gone, check for remnants behind all pulleys before just slapping on another one. It will destroy hoses and crank seals, ask me how I know. Best of luck.
  4. Feb 9, 2021 at 6:53 PM
    OldManTacoFeels
    Billy Jr.
    2012 DCLB SR5
    Just checked and my belts (that I can see) and in tact. Like I said all the lights came on, including the battery light. So this sounds like alternator
    zippsub9 likes this.
  5. Feb 9, 2021 at 6:58 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Hopefully, I would try to get power to it and check codes before just dumping a new alternator or at least pull the alternator and have it checked before purchasing another. Depending on how old the battery is and what you had powered at the time would affect how long your truck would last without charge. Night time with headlights, blower motors, stereo, any extra lights and an aged battery may just give all about at once. However, check alt-s fuses as well in the system, and ensure no codes.
  6. Feb 9, 2021 at 7:00 PM
    OldManTacoFeels
    Billy Jr.
    2012 DCLB SR5
    Definitely gunna figure it out tmro. Praying it’s just an old battery.
    zippsub9[QUOTED] likes this.
  7. Feb 9, 2021 at 7:02 PM
    Yukon DoIt
    Yukon DoIt Opinionated Northerner
    Paul
    Yukon, Canada
    2006 White Tacoma DCLB 4wd Auto, 1988 Blue 4Runner 4wd Manual
    Stock-y
    I've heard of this happening from a short in the wiring of a sensor on the exhaust of the pre-tacoma pickups. Hope you find the problem without too much fuss.
  8. Feb 9, 2021 at 7:16 PM
    Yukon DoIt
    Paul
    Yukon, Canada
    Stock-y
    Did you notice if the battery light was on before it died? I feel like if your alternator died it would have thrown the battery light up before the truck had no juice left but I might be wrong.
  9. Feb 9, 2021 at 7:20 PM
    risethewake
    risethewake Well-Known Member
    Will
    '15 MGM Sport AC
    Basics. Tires, painted headlighes, UHLM, baby winch in the bed, and heated mirrors :)
    If you didnt get a charging system light prior to the chaos, the battery may have just dropped a cell. Happened to me a while back. Drove into town, parked for a bit, then had no juice to start back up. No lights or warnings telling me it wasnt charging.
    A kind stranger jumped me, drove ~40mins back home, turned it off, and again had no juice when I tried starting it back up. Jumped again to drive to the dealership ~1 hour away, and about halfway there I lost all power a few brief times, with dash lights going crazy as if I was twisting the key back and forth
    Dealership said the battery was roasted and held zero charge, but luckily the charging system was fine. Seems like it dropped a cell and was shorting out internally.
  10. Feb 9, 2021 at 7:54 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Hmmmm 2012 Tacoma dying while mid-drive.... sounds familiar
    OldManTacoFeels[OP] likes this.
  11. Feb 9, 2021 at 7:54 PM
    OldManTacoFeels
    Billy Jr.
    2012 DCLB SR5
    What u mean
    Marc70, whatstcp and stickyTaco like this.
  12. Feb 9, 2021 at 7:59 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    I'm curious too...following now to see what @Tcomaboy means.
    SR-71A and whatstcp like this.
  13. Feb 9, 2021 at 8:02 PM
    Texas Aggie
    Texas Aggie Well-Known Member
    Michael
    TEXAS
    2013 SR5 4x4 Lifted
    King 2.5's Front and Rear 700# coil, 2" wheelers aal, 315/75R16 BFG KM3's Pelfreybilt Front and Rear Steel Bumpers, All Pro Sliders, 4.56 Gears
    Had an alternator die in a previous truck and it did what you just described.
  14. Feb 9, 2021 at 8:04 PM
    OldManTacoFeels
    Billy Jr.
    2012 DCLB SR5
    Shiiiiiit well if that’s it, it sucks, but it could be worse. I bought a $10,000 Legacy GT spec B and the transmission shit itself 50miles from where I had just bought it. Took the dealer 3 tries to fix it smfh
  15. Feb 9, 2021 at 8:54 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Most likely a bad battery,same exact thing happened in my daughters corolla.
  16. Feb 10, 2021 at 3:30 PM
    TexasWhiteIce
    Texas
    It seems like every week there is a thread of a 2012 dying while driving. If you do a search for “limp mode” some of the reasons have been running out of fuel, blown fuse, etc. seems like it’s always a 2012.
    Marc70 likes this.
  17. Feb 10, 2021 at 10:29 PM
    OldManTacoFeels
    Billy Jr.
    2012 DCLB SR5
    That’s weird af and pretty concerning
    BananaMan likes this.
  18. Feb 10, 2021 at 10:54 PM
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    Any update?
  19. Feb 10, 2021 at 11:03 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    The fact that it died while driving and not just suddenly failed to start tells me it’s the alternator.
    Had the same thing happen a few years back, almost exactly the same scenario the OP described. He probably just overlooked the red battery dash light come on.
  20. Feb 10, 2021 at 11:08 PM
    ThaiChillyTaco
    ThaiChillyTaco David aka Chilly aka Booty Freak
    David
    Goose Creek - South Carolina
    2021 Cement Grey TRD Off-road 4x4 Longbed
    Rough Country 3.5 Lift SCS BR6 wheels rolling in 285/70/17 Falken Wildpeaks
    shit I drive a 2012 and this has not happened to me and hopefully it won't. :burnrubber:
    Marc70 likes this.
