My truck is shaking between 20 to 30 mph
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ecko380, Nov 20, 2022.
  1. Nov 20, 2022 at 6:38 AM
    Ecko380
    Ecko380 [OP] Well-Known Member
    Rafael
    2016 Blazing Blue Pearl Tacoma TRD Sport
    Vinyl decal to glove box, sill protector front and back and TRD pro shift knob.
    Hi y’all,
    I wanted to ask y’all if anybody has the same thing happening to them or if they know a fix? My truck is shaking between 20 to 30 mph, I don’t know why this is happening. I did a transmission oil change about six months ago, and this problem started last week. I have a 2016 Tacoma sport, Any information would be greatly appreciated.
    “update”
    It seems like all of the information that I got especially the one about greasing the U joint was the successful one.
  2. Nov 20, 2022 at 6:42 AM
    jamie140
    jamie140 Active Member
    Check for snow, ice, mud or other crap stuck in and around the wheels.
    Might be a balance issue, but that's a strange speed to shake at.
    Ecko380[OP] and wilcam47 like this.
  3. Nov 20, 2022 at 8:26 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    it's a '16, sounds like you need to see a mechanic. i'd check anything that moves underneath the truck. ball joints, drive shafts, suspension arms, wheels.
  4. Nov 20, 2022 at 8:30 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Doesn't look like you're lifted...but still could be the needle bearing and is easy to check. Does the shaking go away in 4wd?
    TS4x4 likes this.
  5. Nov 20, 2022 at 9:16 AM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Run your hands around the top surface of all tires and feel for a bulge which would indicate a broken belt. Move the truck forward a bit and check the surface that was on the bottom.
    gilligoon, shakerhood and wilcam47 like this.
  6. Nov 20, 2022 at 9:26 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    This, or uneven wear on tires. Plus balance issue.
  7. Nov 20, 2022 at 12:33 PM
    Ecko380
    Rafael
    No it does not
  8. Nov 20, 2022 at 12:44 PM
    Ecko380
    Rafael
    I just checked and it’s still does the shaking even on the 4 x 4 still between 20 to 30 mph.
  9. Nov 20, 2022 at 12:48 PM
    Ecko380
    Rafael
    I do the rotation of my tires every 5000 miles when I go to get my oil change.
  10. Nov 20, 2022 at 12:49 PM
    Ecko380
    Rafael
    3 to 4 years ago.
  11. Nov 20, 2022 at 12:51 PM
    Ecko380
    Rafael
    These are some of the services I have done this year. Front & Rear differential on 10/1/22 miles 97,576
    Radiator fluid changed on 5/21/22 miles 90,840
    transmission fluid changed on 1/6/22 miles 85,860
    Brake fluid changed on 5/8//21 miles 73,719
    Serpentine belt/fan belt changed on 10/1/22 miles 97,576
  12. Nov 20, 2022 at 12:52 PM
    Ecko380
    Rafael
    This problem y’all is so annoying. I am literally like three months away from paying off my truck and just to think that now I have this problem!
  13. Nov 20, 2022 at 12:53 PM
    WannabeMechanic
    WannabeMechanic Member
    23 tac0o offroad
    where do u feel the shake? from steering? from brake pedal? from the seat? does it shake when u apply brake? only occur at 20-30mph? , what about at higher speed?
  14. Nov 20, 2022 at 1:56 PM
    Pyle26
    Pyle26 Member
    Jeffrey
    2021 Lunar rock Tacoma trd pro
    I have it on my new 2022. Lifted 4in. It vibrates at exactly 25mph. It needs 2in. blocks tapered 2.5 degrees the drive shaft is rubbing.
  15. Nov 20, 2022 at 1:57 PM
    Pyle26
    Pyle26 Member
    Jeffrey
    I already replaced the needle bearing. The mechanic dropped the drive shaft and it was gone. Waiting for the blocks now.
  16. Nov 20, 2022 at 2:05 PM
    SpeySquatch
    2016 TRD OR DCSB
    If you didn’t get the ECGS clamshell bushing it’s definitely part of the problem. It’s an inevitable issue. Blocks are also going to cause more problems than good. I’ve chased vibes through multiple lifts with multiple Tacomas and have it dialed now. A digital angle reader can be a good investment as well
    TS4x4 likes this.
  17. Nov 20, 2022 at 2:11 PM
    Ecko380
    Rafael
    I do not feel the shaking a high-speed only feel the shaking between 20 to 30 mph. My truck is an automatic truck as well. I feel the shaking throughout the whole entire truck.
  18. Nov 20, 2022 at 2:12 PM
    Ecko380
    Rafael
    I have done the brakes. So you recommend I get new tires and an alignment?
  19. Nov 20, 2022 at 2:14 PM
    Ecko380
    Rafael
    I have not lifted my truck. It is still at factory height with factory wheels and tires.
  20. Nov 20, 2022 at 2:15 PM
    Ecko380
    Rafael
    What is the needle bearings causing shakes?
