My truck has developed a front end creaking noise
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoinMD, Dec 13, 2017.
  1. Dec 13, 2017 at 8:58 AM
    TacoinMD
    TacoinMD [OP] Well-Known Member
    Tim
    Ft. Lauderdale, FL
    2017 Silver Double Cab Sport.
    The truck is scheduled for a service appointment next week for this issue, however, I'd like to get an opinion of what might be causing this creaking noise.
    The video makes the noise sound like a knock, I feel it's more like dry metal parts rubbing against one another. I did notice that the rubber ball joint boot at the top of the wheel mount was leaking a bluish / purple grease and maybe water?
    The noise happens only when traveling at speeds right around 20 mph (low speed issue) over the soft neighborhood speed humps. It seems that as soon as the suspension is compressed on the upside side of the speed hump the creaking noise appears.
    All stock, no suspension mods, 5,600 miles on the odometer.
    Thank you for your help! At least I'll have some knowledge when I head to the dealer next week.
    ChadsPride and BOZOJUICE like this.
  2. Dec 13, 2017 at 9:01 AM
    RevivalOL
    RevivalOL Well-Known Member
    Pete
    Berkley, MI
    2017 TRD Off-Road DCLB
    Do a search on here about the front radiator/body mounts. That would be my guess. People are seeing them go bad as early as 1,500 miles. Last week I found 4-5 threads about it. Don’t have the links handy at the moment though.
    Victory likes this.
  3. Dec 13, 2017 at 9:12 AM
    TacoinMD
    Tim
    Ft. Lauderdale, FL
    Ok, thank you.
    I'll take a look at that possibility.
  4. Dec 13, 2017 at 9:15 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Sounds like it could be a loose swaybar end link as well. That'd be easy to check on your own. Just take a 17mm and see if you can tighten it down any.
    boogie3478 and ChadsPride like this.
  5. Dec 13, 2017 at 9:36 AM
    TacoinMD
    Tim
    Ft. Lauderdale, FL
    Thank you, I'll check that too.
  6. Dec 13, 2017 at 10:06 AM
    68injunhed
    68injunhed Well-Known Member
    Jeff
    SE Kansas
    2018 SCrew F150
    A couple things
    Mine ended up being a strut assembly, replaced under warranty.
  7. Dec 13, 2017 at 1:51 PM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Mine was the passenger side body mount. Couldn't tell from the "non-video".
    G.
    InfernoTonka likes this.
  8. Dec 13, 2017 at 2:19 PM
    InfernoTonka
    InfernoTonka Infernal Order of Knights Templar of Inferno-ness
    TOD aka Toyota Onroad Development
    2016 Inferno SAF base model SR5 4x4
    My money is on the ball joint even though they shouldn't need replacement yet :anonymous:
    BassAckwards likes this.
  9. Dec 17, 2017 at 7:34 PM
    TacoinMD
    Tim
    Ft. Lauderdale, FL
    Seems I'm not the only one with this problem, I'm going to attempt to replace the front body mount bolts.
    Victory likes this.
  10. Dec 17, 2017 at 7:46 PM
    KevC
    KevC Well-Known Member
    I have the same exact sound/issue. I believe it's the front body mounts. I'm going to mention it at my 20k toyota care service. Let me know if your fix resolves the problem!
  11. Dec 17, 2017 at 7:58 PM
    InfernoTonka
    Could it be bushings?
  12. Dec 17, 2017 at 9:14 PM
    ajmogen
    ajmogen Well-Known Member
    Aaron
    Wisconsin
    OR MT TACO T4R YARIS MT Corolla Hatchback MT
    I had the same issue. Replaced front body mounts, which were worn but not the cause.
    Spray some lubricant in the spring bed, top and bottom where the spring rests in the coil over. Stand on your door jamb and rock the truck to work it in. Be liberal with the lube.
    It worked for me, haven't had a problem since.
  13. Dec 17, 2017 at 10:14 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Shot ball joint...
    Can you take a better pic of the castle nut area of the upper ball joint? Same angle as your video, just zoomed in...
    Is that a shiny spot? Balljoint seems to move before the uca does.
  14. Dec 18, 2017 at 7:07 AM
    fortiz619
    fortiz619 yeh i drive a 2wd big woop wanna fight about it?
    Southern California , IE ,SD
    04 Tacito 5lug, 16 tundra, 07 tundra
    THIS! I have this exact problem on mine although im at 19k miles , as soon as the front hits a speed bump u can hear it , I have a list I’m taking to the dealer with 10 things that are of my concern with my 2016
  15. Dec 18, 2017 at 7:14 AM
    bradshawnh
    bradshawnh ...to the rescue!
    Boston, MA
    2017 TRD OR DCSB 6MT, Tech, Inferno
    Warranty! Why would you attempt it yourself if you are still under warranty?
    I am all for working on my own truck, but free parts and free labor always win out!
    RevivalOL likes this.
  16. Dec 19, 2017 at 6:59 AM
    TacoinMD
    Tim
    Ft. Lauderdale, FL
    Just dropped the truck at the local dealer. The tech went for a ride with me, he clearly heard the noise. He then watched the video, and oddly enough the video sounds like a clunk or a pop, however, to the ear, the noise is more of a metal on metal sound. He advised "something ain't right" but what is that something? Lets see how this plays out.
    shakerhood likes this.
  17. Dec 19, 2017 at 8:08 AM
    RevivalOL
    Pete
    Berkley, MI
    Ask them to take a run with chassis ears on.
  18. Dec 19, 2017 at 11:11 AM
    spencer2423
    spencer2423 Well-Known Member
    2016 TRD Sport
    I have the same problem. originally at 10k miles and sprayed lubricant at the lower control arm. was good for about 5k miles now its back again... Let us know what they tell you at the dealer. Thanks!
  19. Jan 3, 2018 at 11:01 AM
    ripRavioli
    ripRavioli Well-Known Member
    Evan
    SLC
    2017 Tacoma Access cab 4cyl 4x4
    I have less than 2k on my truck and i have got the same noise starting on my front passenger side, it sounds like a squeek and only if i hit dips or bumps at low speeds and or jumping up and down on the door frame.... 2k miles.... what??????? please let me know what you find out. Mine is only an SR.
  20. Jan 3, 2018 at 11:14 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Did they solve the problem?
    BOZOJUICE likes this.
