My Strut Assembly doesn't fit back into the Control Arm Bolt, help!!
Discussion in '5 Lug' started by erval09, Apr 15, 2016.
  1. Apr 15, 2016 at 7:55 PM
    erval09
    erval09 [OP] Well-Known Member
    Montclair, CA
    06 Tacoma SR5, 2WD, 4cyl, 2.7L, 5 Lug, 5 speed manual
    I am installing the ReadyLift 69-5510 2wd five lug Tacoma kit on my 2006 Base Taco and I followed all their steps in their instructions video link below. I added the strut spacer and even rotated the top part of the strut 120 degrees (even thought they never freaken explained how to do that, which i found out by using strut spring compressors to loosen the top of the strut) but after that i'm stuck!
    https://www.youtube.com/watch?v=7w_Hg8JoKLY&list=WL
    The strut assembly doesn't fit anymore! :( Either I install the sway bar endlink and the lower part of the strut doesn't reach the control arm; or I install the strut assembly to the control arm bolt but the upper endlink with bushings doesn't reach the other side.
    Please help i'm stuck! If you have installed this kit or are familiar with lifting 06 base 5 lug tacomas I need your help!!
    Here are some pics of my frustration! You can see how the lower part of the strut is way out from the control arm and the top strut bolts have already been installed.
  2. Apr 15, 2016 at 8:02 PM
    Asianguywithatruk
    Asianguywithatruk Well-Known Member
    CenCal
    05 taco DCSB
    King RR coilovers Ironman leaf springs 17" scs sr8 jet black 285 75 17 Yokohama geolandar Demello front bumper Brute force rear bumper
    I don't have a 5 lug but it looks like you still have your sway bar attached. Try removing that and see if the lca will drop further down. Also loosen the top bolts so you have some wiggle room.
    RelentlessFab likes this.
  3. Apr 15, 2016 at 8:27 PM
    erval09
    Montclair, CA
    Yea in the instructions it says just remove the end link which I did but then if i install the strut assembly the endlink bolt doest reach the bracket to screw from the top side (the bolt sits too low and doesn't reach the hole). Idk what I did wrong and i'm so frustrated :/
  4. Apr 15, 2016 at 8:35 PM
    2ski4life7
    2ski4life7 Well-Known Member
    Seattle WA
    17 DCLB 4x4 TRD Off Road Previously '12 DCLB 4x4 SR5
    if the top nuts don't reach try using a jack to push the lower control arm up?
  5. Apr 15, 2016 at 8:35 PM
    Pacific_roots
    Pacific_roots John 3:16
    Josh
    Big Island, hawaii
    MGM 2015 dcsb trdoffroad
    Maybe try install the strut assembly with the sway bar end link disconnected then use a Jack under the lower control arm to bring it up to attach the sway bar
  6. Apr 15, 2016 at 8:39 PM
    erval09
    Montclair, CA
    I actually tried that, didn't work :( i felt my truck was going to tilt over :eek: haha
  7. Apr 15, 2016 at 8:39 PM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Did you cut down the bolts on the shocks as per instruction? Also I would disconnect the lower sway bar link on both sides and reattach it when everything else it bolted in.
  8. Apr 15, 2016 at 8:40 PM
    2ski4life7
    Seattle WA
    Is the whole front lifted on jacks?
  9. Apr 15, 2016 at 8:43 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    Your spacer looks too low at the top
  10. Apr 16, 2016 at 12:48 AM
    erval09
    Montclair, CA
    Yea I did everything exactly the way it says in the instructions and video. When I try to put my strut assembly back, either the strut will fit or the sway bar end link but not both. The sway bar link's bolt (the one that goes through that bracket hole) barely touches the bracket and it not 'long enough' to go through the hole because the control arm is lowered and when i lift it up then the lower strut doesn't fit in its right place. It's just a major frustration !
  11. Apr 16, 2016 at 12:52 AM
    erval09
    Montclair, CA
    Yes the front is lifted on a jack and two stands. And the top strut nuts are fine, the problem is the lower strut that goes through the control arm, it seems that it has gotten 'longer' to fit when i try to lift the control arm back up to install the end link, that's when it creates chaos for me.
  12. Apr 16, 2016 at 12:55 AM
    erval09
    Montclair, CA
    you think so? Why do you think is that? i tighten the bolts tight enough. Do you think maybe the spring compressor might have messed it up? I compressed the coils so that i can rotate the top 120 degrees using the new spacer bolts and mount them back into the OEM strut holes.
  13. Apr 16, 2016 at 4:56 AM
    Asianguywithatruk
    CenCal
    05 taco DCSB
    What I would do is remove both end links. Get both coils bolted in. set the truck on the ground then bolt the sway bar back on. With both end links unbolted, you should be able to move the sway bar up and down. I think the reason the sway bar won't move right now is because you have one end link bolted in.
    erval09[OP] and 5 Lug Fury like this.
  14. Apr 16, 2016 at 5:58 AM
    5 Lug Fury
    Kenny
    Knoxville, TN
    ^^^^^ I didn't un bolt both at the same time and it was a pain leave the sway links undone until everything it back in place. As for the top strut rotate the spacer and see if a different side fits better I can't remember if it's lopsided or not.
  15. Apr 16, 2016 at 6:11 AM
    Pportera
    Pportera Well-Known Member
    3rd gen.
    Disconnect sway bar on both sides and rotate it upwards out of the way. I tried prying lower controll arm with prybar and couldnt get mine back in. I had to unbolt the lower ball joint(two large bolts) to allow enough play to get my struts back in.
    But mine is 4x4 yours looks kinda diffrent
  16. Apr 19, 2016 at 9:08 AM
    erval09
    Montclair, CA
    Thanks man! I didn't know that by removing both end links the sway bar moves. I thought you had to unscrew the middle bolts to remove the whole thing, this really helped putting the end links back into the sway bar. You are a life saver man!! :thumbsup:
  17. Apr 19, 2016 at 9:10 AM
    erval09
    Montclair, CA
    yea, by unbolting both end links the sway bar moves up and down making it reachable for the links to bolt in.
  18. Apr 19, 2016 at 12:03 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    So you finished?
    :worthless:
    EatSleepTacos likes this.
  19. Apr 19, 2016 at 12:45 PM
    erval09
    Montclair, CA
    Yes I am. I will be posting pics tomorrow after i get my new tires installed :D
  20. Apr 20, 2016 at 7:56 PM
    erval09
    Montclair, CA
    As promised, here are my before and after pics.
    5 Lug Fury likes this.
