My Ride rite with compressor install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HolyHandGrenade, Oct 23, 2013.
  1. Oct 23, 2013 at 7:00 PM
    HolyHandGrenade
    HolyHandGrenade [OP] NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Been lurking for awhile. Figured I'd contribute...
    I stole the idea of putting the compressor and gauge in the bed storage box from another thread found here: http://www.tacomaworld.com/forum/2n...stalled-firestone-ride-rite-w-compressor.html
    Thanks ScottG...
    Probably overkill here... I used both supplied heat shields on the passenger side because of the exhaust bend. It protects both sides that way. I then made another heat shield to protect the air line out of a license plate and heat tape. THEN, I covered some wire tubing with the same heat tape and put it on the air line. Peace of mind? :D
    Drivers side
    EDIT:
    I added cradles tonight (over a year later). Tired if worrying while it's on a lift... I've seen multiple people asking what's involved adding cradles after the bags are installed, so I figured I'd add it to this thread. I'm also going to put the cradle write up in the suspension section.
    Forgot to snap a pic of the cradles prior to install, so I borrowed this one from the web...
    Let the air out of the bags:
    Removed the bolt holding the bottom of the bag to the leaf spring bracket on both sides:
    Put the floor jack under the tow hitch, and jacked the back of the truck up high enough to slide the cradles in and bolt them down to the leaf spring bracket.
    Drop the jack. Add air. Bring entire family out to the garage so they can see how manly you are!
    jsev, WPNZ and UssMoGn like this.
  2. Oct 23, 2013 at 7:31 PM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    Looks good. Did you keep both sides separated (air hose) or did you tie both side together with a "T" that then connects to the compressor?
  3. Oct 23, 2013 at 8:05 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Thank you. The compressor kit that I got had the option to go single or dual path. I opted to go single path. So, to answer you question, both bags are tied together.
  4. Oct 23, 2013 at 9:20 PM
    jmg256
    jmg256 Calmer than you are
    Al Tonter
    TRD Offroad
    Bilstein 5100 front/rear (front at .85), Hayden 678 Trans Cooler, 20% tint, Curt Hitch/Wiring Harness, Weathertech Digital Fit Floor Mats (Black), Wet Okole Seat Covers (Black), Cooper Discoverer ATP 265/75/16, LED Map/Dome lights, ImMrYo bracket, Debadged, Extang Tuff Tonno.
    You should really keep them separate...as one bag compresses under load, it will send the air to the other bag. This will effectively lower the pressure in the compressed bag, lowering it's load capacity and effectiveness.
  5. Oct 24, 2013 at 10:48 AM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Yeah, I considered this. It was more expensive for the dual path kit. This will work fine for what I need it for.
    Thank you though.
  6. Oct 24, 2013 at 12:51 PM
    jmg256
    Al Tonter
    TRD Offroad
    Just be mindful of what pressure you run your system at, you're not going to want to run it near the upper limit. Running It near capacity could result in a blow out of either bag when the axle articulates, resulting in an over pressure situation on the non compressed bag or supply lines.
  7. Oct 24, 2013 at 12:56 PM
    jmg256
    Al Tonter
    TRD Offroad
    You should be fine if only hauling mild loads on relatively flat surfaces though...
  8. Oct 24, 2013 at 3:29 PM
    Tuctaco
    Tuctaco Well-Known Member
    Todd
    Tucson, AZ
    2012 MGM TRD OR 4x4
    Katzkins, Redline hood struts, Pop & Lock,285/75/16 Toyo Open County ATll, 16X8 Konig Countersteer, Icon extended coilovers, Icon rear shocks, Icon progressive leaf pack, LR UCA's, extended brake lines,
    That is a great spot for the compressor.
  9. Oct 24, 2013 at 4:03 PM
    TFLT
    TFLT Active Member
    Central New York
    10 tacoma Reg cab 4x4
    Yellow Wire, Hella DE Fogs, Firestone airbags
    I installed ride rites as one of my first mods, and think they're great. I installed them with separate lines for each bag, and use a bike pump to air them up, only takes a few pumps. The Schrader valves are in the driver side rear storage compartment. I highly recommend ride rites, they make a huge difference in load carrying, you can actually carry mgvw, and easily overload it should you dare! You'll be happy with them.
  10. Oct 24, 2013 at 4:05 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    OP nice job on the install. In reference to the axle articulation mentioned above check out the Daystar Cradles and never worry about it again:
    http://www.amazon.com/Daystar-KU09140BK-Cradle-Polyurethane-Convoluted/dp/B0084ROJBM
  11. Oct 24, 2013 at 4:26 PM
    jmg256
    Al Tonter
    TRD Offroad
    Those cradles only allow for full suspension travel of the given system...they will do nothing for the pressure differential that I was referring to. In fact, they could exacerbate the problem as they will cause the compressed bag to further compress due to the added height of the cradle
  12. Oct 24, 2013 at 5:19 PM
    Drainbung
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Correct, if the bags are plumbed together it will pump from one to the other, regardless of the cradles. If plumbed separately they remove any worry of over articulation, which is nice.
  13. Oct 24, 2013 at 5:21 PM
    jmg256
    Al Tonter
    TRD Offroad
    OP has the bags linked on a single feed :thumbsup:
  14. Nov 12, 2013 at 11:10 AM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    OP, nice job. Looks really good.
    By the way, there are some low security examples of cabinet lock mods in case you are at all worried about someone fooling with it.
  15. Nov 12, 2013 at 11:16 AM
    TIM.TRDSparks
    TIM.TRDSparks Well-Known Member
    Myrtle Beach, SC
    08 Taco DCLB RR
    CBI BUSHMASTER, BUDBUILT SKIDS SET, OME SUSPENSION, DAKAR LEAFS, TRD EXHAUST AND CAI PLUS MORE
    Looks really clean and great install!
  16. Dec 18, 2014 at 6:26 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Bump for update with cradle install ^^^
  17. Dec 19, 2014 at 1:53 AM
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    Check with Firestone, you will not have any "excessive pressure, blown up bags etc. from a single line system. It is simple Physics, with a single line system the pressure is equal in the entire system. As one bag compresses the air transferred to the other bag will cease transferring when the pressure is equal. Firestone only recommends dual air lines for when you are going to be carrying an "offset" load as with a Camper or such that is usually much heavier on one side than the other. For most towing and general use they recommend the single line "tied together" air bag set up. This is not my opinion, it is direct from Firestones site. There has been a lot of misinformation concerning the Firestone Air bags argued around on this site. Best recommendation is to check the mfgs site for the "Correct" information.
  18. Dec 19, 2014 at 5:20 AM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    There should never be a reason to run anywhere near max pressure that would make him vulnerable to a blow out. I never had more that 15 psi in mine for any haul. He will however experience one of the rear wheels lifting off the ground during tough articulation as I did.
  19. Dec 19, 2014 at 6:16 AM
    dilligaff82
    dilligaff82 Well-Known Member
    New Hampshire
    2014 TRD Off Road DCSB
    Is there any way to weather proof the storage pocket the pump is in? I like this install, but whatever I put in those containers comes out filthy with road grime.
  20. Dec 20, 2014 at 3:08 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Not easily, it's been in there for over a year now. No problems, even through last years LONG winter... I'm not worried
