My rear passenger side tire wobbles
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nazareth7, Jun 14, 2023.
  1. Jun 14, 2023 at 10:47 PM
    Nazareth7
    Nazareth7 [OP] Well-Known Member
    2007 Tacoma 2x4
    Hello community, I have a wobble rear passenger tire while driving , I don’t hear noise of wheel bearing going out, but is it just my eyes, whenever I check it from my passenger side mirror while driving I can see the wheel wobbles. I don’t see this from my rear driver side tire, that one is straight when I’m driving . Thanks
  2. Jun 15, 2023 at 3:46 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
  3. Jun 15, 2023 at 3:54 AM
    bryanh69
    bryanh69 Well-Known Member
    2015 MGM Toyota Tacoma TRD OR
    take the tire off and make sure there isn't something between wheel and the hub. Make sure the lugs are tight. Is the wheel bent?
  4. Jun 15, 2023 at 4:00 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Take it to a good tire shop, have them remove it and run it on their balance machine. Determine if it's the rim or the tire. If all is good then the other alternative is a bent axle or similar. It could be something like shifted or broken belts, even a bent rim isn't the end of the world, you may need to look a bit but you should be able to find another one in the same style.
  5. Jun 15, 2023 at 5:05 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Aftermarket wheels/tires? Stock width tires don't stick out far enough to be visible from in the cab via the side mirrors.
  6. Jun 15, 2023 at 5:18 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Watching rear tires in the mirror can be deceiving.
    WOODY2 likes this.
  7. Jun 15, 2023 at 5:21 AM
    dklehman
    dklehman Well-Known Member
    Darin
    Eastern wa
    2021 TRD off road
    Make sure it doesn't have a dirty patch or some kind of mark on the tire causing it to look like it is wobbling. If it was wobbling enough to see it you would for sure feel it.
    WOODY2 likes this.
  8. Jun 15, 2023 at 7:29 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Bent rim??
  9. Jun 15, 2023 at 7:33 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Swap that wheel with another one (like a tire rotation) and recheck
    GilbertOz and SR-71A like this.
  10. Jun 29, 2023 at 12:12 PM
    Nazareth7
    2007 Tacoma 2x4
    Update I checked the tire and the rim and they look tight to me . And the lug nuts are tight as well.
