my piaas shaking bad ,while driving
Discussion in 'Lighting' started by Tylers dream, Jun 24, 2012.
  1. Jun 24, 2012 at 7:21 AM
    Tylers dream
    Tylers dream [OP] Member
    Bruce
    Winterville ga
    4x4 metallic gray sr-5
    3" suspension ,nitto trail grappelers, baja bull bar, 2 PIAA's extreme white,stainless step rails
    Ok folks here is the deal ,i bought some piaa extrême lights to put on my baja style Bull
    Bar .but once on and running down the rd ,they shake pretty violently .
    So my fix was to fabricate à better mount . So i fabbed one out of 2" by 1/4" thick allumniun plate. N powder coated it, thinking that the stiffer material would be better. Still shakes!!!!! :(>. So next step was to take à rubber bushing of an new air cond compresser mount n put it under the actual light mount ,its even worse .!!!!!!! Talk about agrivated, i know my Bull bar has à lil shake , but not while im idiling!!!!! .im.really disapionted ,i want to have whole bar line x' n wanna get this problem addressed before i line x bolts etc....
    Any advise is appréciated .Thanks in advance Bruce Arnold :D
  2. Jun 24, 2012 at 7:36 AM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    curious as well. :popcorn:
    got some pics OP?
  3. Jun 24, 2012 at 3:30 PM
    Tylers dream
    Bruce
    Winterville ga
    $80.00
    Only thing i can think of is à hard rubber pad at back of bar there plate bolts on
  4. Jun 24, 2012 at 3:32 PM
    Forster46
    Forster46 Very nice how much?
    Nick
    Mount Vernon, WA
    The doritos locos taco
    6000k HID's, AUX Reverse Lights, 3" Rough Country Suspension Lift, Pioneer AVH-P4200 Double Din, Underglow and footwell Lights, Camo Seat Covers, Duralast Tool Box, Blacked Out Badges, Grill, Front Emblem, Midland CB Radio, Amber Strobes, POWER REAR WINDOW, cup holder LED's, Firestik 3' in bed, console divider, Ultragauge.
    Same problem with mine, but they are mounted behind the grill
  5. Jun 25, 2012 at 5:02 AM
    Tylers dream
    Bruce
    Winterville ga
    I Thought about that but.... Im running nitto trail grapplers n dont want excessive wear these jokers Aint cheap
  6. Jun 25, 2012 at 6:00 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Can you take pics of the bull bar they're mounted to and how the bull bar attaches to the truck? Those wider 'baja style' bull bars, if it's what I'm thinking of, only attach in the middle of the truck but the bar extends to almost the sides of the truck meaning you have a lot of weight to try and hold steady.
    Mine used to shake on my old grille guard but with my new NFab bar, I've got 4 PIAA's and they don't move a bit. With the addition of some steel, I was able to minimize the shaking on the old grille guard also.
  7. Jun 26, 2012 at 4:11 AM
    Tylers dream
    Bruce
    Winterville ga
    Im gonna post à pic , the bolts use one Bolt per side straight into im assuming à bolt insert made into the stainless tubing
    Whats à chalk test ,link??? Maybe i am running over,
    Thanks à bunch for the replies, keep them coming , its so agravating its like these jokers are on strobe very annoying
  8. Jun 26, 2012 at 4:19 AM
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    One bolt per side? That might just be a starting point. I wouldn't think that would be enough to hold the bar steady.
  9. Jun 26, 2012 at 7:56 AM
    thumper53
    thumper53 New Member
    Dale
    Huntsville AL
    2019 Tacoma TRD OR MGM DCSB
    LED Bulb upgrade, All exterior with turn signal resistors OEM Mudguards OEM Tailgate lock OEM Bed Lights Total Chaos bed stiffeners ARE CX Revo Shell BedRug Mat Alpine Halo ILX-F309 complete Taco kit with XM Tuner Westin HDX Running Boards/Steps 4Runner TRD wheels in Graphic with NITTO Terra Grappler G2 265x70x17 Meso Customs Interior blackout Meso Customs Side Mirror Blackout LED
    I have Westin Bull Bar with 6" PIAA Fogs, had the same problem. Went to Lowe's and bought some large rubber stoppers (Hardware Dept in the slider drawers), I think they were size 8, very tight fit, i pulled the bull bar forward enough on each side to slide them in, there is enough tension to keep them in place, my lights do not vibrate any more unless I am running over train tracks. Size 8 worked for my application, you may have to go up or down a size.
  10. Jun 26, 2012 at 7:58 AM
    Pugga
    Massachusetts
    Those bull bars are just end mounted with one bolt. There's not a lot you can do about it other than get a strong bolt and torque it down really tight (be careful not to strip anything in the process).
  11. Jun 27, 2012 at 4:52 AM
    Tylers dream
    Bruce
    Winterville ga
    Thanks thumper , i put 2 #8 rubber stoppers behind bar ti bumper n one under the light bar mount bracelet to Bull bar shaking gone :):):):)finally
  12. Jun 27, 2012 at 4:53 AM
    Tylers dream
    Bruce
    Winterville ga
    I appreciate all yals help
