My Lighted Copper Roof Cupola Build And Install
Discussion in 'Garage / Workshop' started by File IFR, Aug 23, 2014.
  1. Aug 23, 2014 at 5:54 PM
    File IFR
    File IFR [OP] "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    I finally got around to adding a finishing touch to my new garage.
    Built from Azek, so I'll never have to paint it.
  2. Aug 23, 2014 at 5:55 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    That's nice work
  3. Aug 23, 2014 at 5:58 PM
    File IFR
    Central MA
    More shots....
  4. Aug 23, 2014 at 5:59 PM
    File IFR
    Central MA
    Thanks Pete.
  5. Aug 23, 2014 at 6:03 PM
    File IFR
    Central MA
  6. Aug 23, 2014 at 6:06 PM
    File IFR
    Central MA
  7. Aug 23, 2014 at 6:09 PM
    File IFR
    Central MA
    Now the window sash and crown moulding install...
  8. Aug 23, 2014 at 6:10 PM
    File IFR
    Central MA
    Hawco636 and Biscuits like this.
  9. Aug 23, 2014 at 6:11 PM
    OZ-T
    Peter North
    British Columbia
    Wow , very nice job
    Well done
  10. Aug 23, 2014 at 6:14 PM
    File IFR
    Central MA
    Thanks. The only thing I really sucked hard at was the soldering of the copper roof. I've seen way neater jobs. :)
    I doesn't look pretty, but it keeps water out.
  11. Aug 24, 2014 at 8:24 AM
    medic2230
    Murph
    Bama! Roll Tide
    That looks really good Mike! Excellent job!
    Does the sash have any kind of sealant to prevent water intrusion around the glass?
  12. Aug 24, 2014 at 8:43 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Will this eventually turn green? I love that green patina that copper gets. An added bonus is the leaching out copper keeps moss from growing in your shingles.
  13. Aug 24, 2014 at 9:28 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Very nice work!
  14. Aug 24, 2014 at 9:31 AM
    File IFR
    Central MA
    Thanks guys. :D
    Not around the glass to the Azek sash frame. The channel the pane sits in will allow any water between to weep out to the sides of the sash and onto the sill (it's at each side of the frames, not shown here).
    I'm guessing it will turn green in 20 years... it will be a brownish color in about a year or so.
    I never knew moss won't grow from the copper 'run-off' to the shingles, good to know.:)
  15. Aug 24, 2014 at 9:43 AM
    File IFR
    Central MA
    I had fun doing this, but there was a huge amount of cursing when time came for the roof to be soldered.:eek:
    As for the roofing guys that work with copper, I now have a much higher regard for them and the fine, high-end work they do.
  16. Aug 24, 2014 at 9:48 AM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    Very nice. Congrats on a job well done!
  17. Aug 24, 2014 at 10:12 AM
    medic2230
    Murph
    Bama! Roll Tide
    I read something not long ago about how you could run copper wiring and secure it across your roof if you have moss problems. As the water runs across it on the way down the roof it coats the roof so the moss won't grow.
  18. Aug 24, 2014 at 10:30 AM
    koditten
    Kirk
    Central Michigan
    That works, but looks bad. The wire sags in between the fasteners.
  19. Aug 24, 2014 at 10:31 AM
    OZ-T
    Peter North
    British Columbia
    Zinc moss strips fastened under the ridge cap work
  20. Aug 24, 2014 at 10:34 AM
    OZ-T
    Peter North
    British Columbia
    We put a copper standing seam roof on the turret of a house I recently built and the copper went from shiny like yours to dull brown in about a year , as you say , most likely green in about 10-15 years but there are products you can get that accelerate the patina process
