My Grandpa's 1996 2.4L
Discussion in '1st Gen. Tacomas (1995-2004)' started by lan40583, Feb 10, 2014.
  1. Feb 10, 2014 at 8:55 PM
    lan40583
    lan40583 [OP] New Member
    96 Tacoma LX
    Well boys and girls, this is my first post at Tacoma World, so I thought I'd introduce y'all to my grandfather's Tacoma.
    My grandpa passed away very unexpectedly in May of last year due to undiagnosed stage 4 pancreatic cancer. My father and aunt, as co-executors of his estate, decided to gift me his truck which I am very thankful for. I finally was able to make the trip back home to bring back the truck, and just got it back from the mechanic a few days ago. Anyways here's what the truck looked like on its first snow day last weekend:
    It's a Pewter Pearl 1996 2WD 2.4L Tacoma LX with automatic transmission, A/C, and only 45,000 miles on it. Apparently my grandpa bought the truck new in July of 1996 and only drove it to church, the hardware store, and to get groceries. The exterior is mostly still shiny and new with only a couple of bumps in the front bumper.
    Now for the bad news. I always knew my grandpa was thrifty; he was one of twelve children, and grew up on a farm in North Dakota during the depression. Since he didn't like to spend money where he didn't need to, there was a considerable amount of maintenance that had been neglected on the truck. Almost everything on the truck was original, including the 18 year old timing belt which was almost falling to pieces after my drive home.
    The most worrying thing is that it looks like my grandpa very rarely changed the oil. My mechanic says that all of the valves were covered in a sooty residue as a result. He added an engine treatment to the new oil that will hopefully clear out all the gunk and get rid of the various worrisome engine noises. One noise in particular that bothers me is tapping noise that only happens at warm idle and gets louder when I sit at idle for a minute or so but then goes away under acceleration. Hopefully it's just valve noise and not something far more serious like piston slap or a knocking connecting rod or wrist pin.
    Black97v6MT likes this.
  2. Feb 10, 2014 at 9:06 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Probably a little stuck, run some MMO oil in it. Other option B12 chemtool great stuff but dont leave in too long, it can eat seals.
  3. Feb 11, 2014 at 3:25 AM
    stardog
    stardog Member
    Bethlehem, GA
    Someone correct me if I am wrong, but the 2.4 is a 22re. I thought the 22re had a timing chain, not a belt. The plastic guides for the chain were always the worry. Anyway, food for thought.
    John L
    Bethlehem, GA
    01 Tacoma DC 4wd
  4. Feb 11, 2014 at 8:03 AM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    Nice rig. FYI, your motor is the 2vz-fe which does have a timing belt. (I'm pretty sure). I'd just replace all your fluids, check your brakes and replace all your belts. Those motors are pretty reliable, so after that, you will have a lot of good miles left in the rig.
  5. Feb 11, 2014 at 8:10 AM
    saundern
    saundern Swerve for nothing
    Nick
    Simpsonville, SC
    2005 TRD Sport
    sounds like you got lucky with the oil not being changed regularly. lube it up and she'll run like a dime piece!
  6. Feb 11, 2014 at 11:25 AM
    synergy10
    synergy10 @synergy10.sd
    San Diego
    Really nice truck!!! Besides the moldings, this truck is exactly the same as the truck we had back in high school. Eventually sold it to a relative, then he sold the truck when he no longer needed it. Now I'm back in a first gen.
    BTW - when I was searching for the truck I have now, I recall reading that the V6 models have timing belts while the 4 cylinders have timing chains. Also, states the same in this thread:
    http://www.tacomaworld.com/forum/te...belt-timing-chain-all-toyotas-toyota-com.html
  7. Feb 11, 2014 at 11:33 AM
    MedicMutt
    MedicMutt Purveyor of Useless Information
    Josh
    Baton Rouge, LA
    '03 DC PreRunner TRD OR; '06 Mercury Grand Marquis GS
    OME suspension, Whiteline bushings, Line-X'd Jason topper, GoRhino "Grille Guard", many more...
    It's actually the 2RZ-FE. And after doing a little down and dirty research (someone please confirm) both 1st Gen 4-bangers had timing chains.
  8. Feb 11, 2014 at 11:42 AM
    muddedtaco
    muddedtaco Well-Known Member
    Wesley
    South Mississippi
    96 Tacoma 4x4 2.7
    Rattle caned black, Mossy oak door panels, shifter shroud, and radio cluster surround
    Yes it is a 2rz and it has a timing chain, Good luck with the truck. I am working on my grandpa's 88 nissan truck that has been sitting since 03, it is a lot of work but at least I have something to remember him by.
  9. Feb 11, 2014 at 12:03 PM
    Bamo
    Bamo Well-Known Member
    Barry
    North Port, FL
    09 Regular Cab 4x4
    It is a 2RZ. I had the same truck in a 97 model. In fact I have an aftermarket water pump and timing chain kit sitting in the garage for it I never installed. Mine had 216K on it. If you want them let me know.
  10. Feb 11, 2014 at 3:31 PM
    lan40583
    96 Tacoma LX
    Interesting, my mechanic said he had to change all of the belts and I'm pretty sure he mentioned the timing belt specifically, but maybe he was talking about the serpentine belt being especially bad.
  11. Feb 19, 2014 at 7:18 PM
    TylerBarr
    TylerBarr Member
    St. Pete, FL
    97 Single Cab Red Rocket
    First off, welcome to TW. Sorry to hear about your grandpa, but his passing brought you here, so it's not all bad. There are 3 different belts on our 2.4 2RZ-FE, the A/C belt, the alternator belt, and the power steering belts. The four cylinder 2.4 and 2.7 both have timing chains. Sounds like you've got a little valve ticking due to the truck sitting. Change the oil in 2-3k miles and you should be good. Let us know how it goes. Nice truck btw, really clean.
  12. Feb 19, 2014 at 7:25 PM
    WThomas1250
    WThomas1250 Well-Known Member
    I had a Cherokee one time that was all gunky when I pulled the valve cover. I literally used a spoon and got about half a cup of dried oil out. Not fun.
    Nice looking truck though!
  13. Feb 19, 2014 at 7:31 PM
    Crawdaddy
    Crawdaddy Apprehended by the TRUTH
    North Carolina
    2012 4 cyl. 4x4 "Plain Jane" stock like old men drive
    Secure tailgate, Cobra 29, Firestick, Cree LED back-em up lights, Front LED's,In toolbox inverter, Bed mounted Jerry, Hardwired mounted Stream Light, CCW Holster, Weather tech mats, K&N filter, Wet Okole, Powder coat tool box, LE vertical LOCKED riot shotgun rack,
    I had a 96, my son drives it now. Over 250,000 and it runs strong. Welcome!
  14. Mar 15, 2025 at 12:49 AM
    Yodar
    Yodar Member
    Preston
    1996 Toyota Tacoma 2.4
    A lot
    I have a 1996 with 227k it’s needed a lot I got my transmission rebuilt but the motor feels healthy put some good mobile 1 oil in her and break her in worst thing a Toyota can do is sit only way you kill them
