My frame is rusted does that affect ability to tow?
Discussion in 'Towing' started by LuvMyTacoma03, Jan 17, 2021.
  1. Jan 17, 2021 at 8:38 PM
    LuvMyTacoma03
    LuvMyTacoma03 [OP] Well-Known Member
    2003 Red Tacoma trd
    Hi! I just read thru a bunch of threads about frame rust. Seems like the best thing to do is test the rust with a hammer. If its solid and still sounds like metal than its good and coat it with por 15(or something similar). Or if its soft and can break thru than the whole frame needs to be replaced. Is this the "basic" resolution for rust?
    Soo, I have an excessive amount of rust under my truck (Basically everywhere) I dont see any visible holes and its a very dry rust and seems to be mostly a "surface coating" (i live in california so weather is pretty dry here).
    My biggest concern is is it safe to tow a with a rusted frame? Im Looking to tow a camper around 3,000 lbs. I have a few mechanic friends and they say its completely fine and almost look at me funny for asking. They say if there are no holes than its good.
    Here's some pictures of my rear frame and the base of my tow hitch. The frame has some kind of black coating/paint and is cracking off.. the metal behind the coating appears to be pretty solid.... (i haven't done a hammer test yet only visual inspection)truck rust 1.jpg truck rust 2.jpg truck rust 3.jpg truck rust 4.jpg
    wilcam47 likes this.
  2. Jan 17, 2021 at 8:39 PM
    Bishop84
    Bishop84 Well-Known Member
    It's surface rust, if you're really worried, take a ballpeen hammer and tap it to see if its thinned out.
    That rust isn't that bad and I wouldnt worry about 3000lbs.
    Take it to a shop for inspection if you really want to ensure its 100%
  3. Jan 17, 2021 at 8:42 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Id replace the hitch receiver frame
    TnShooter likes this.
  4. Jan 17, 2021 at 8:44 PM
    LuvMyTacoma03
    2003 Red Tacoma trd
    Thanks! would you recommend coating it with por 15?
  5. Jan 17, 2021 at 8:44 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    X2 it looks weak from the rust
    wilcam47[QUOTED] likes this.
  6. Jan 17, 2021 at 8:46 PM
    Bishop84
    No that's a waste, you'd be better off replacing the hitch receiver with a new unit. It's actually separate from the trucks actual frame.
    TnShooter and wilcam47 like this.
  7. Jan 17, 2021 at 8:48 PM
    LuvMyTacoma03
    2003 Red Tacoma trd
    is that just the center piece that the hitch goes in or the whole bar that's bolted to either side of the truck?
  8. Jan 17, 2021 at 8:50 PM
    wilcam47
    Will
    Bourbon state
    This one is worst part it bubbled on the bar, i wouldnt tow with it
  9. Jan 17, 2021 at 8:53 PM
    wilcam47
    Will
    Bourbon state
  10. Jan 17, 2021 at 8:55 PM
    LuvMyTacoma03
    2003 Red Tacoma trd
    ok thanks, so i just need to replace that frame? do you know how much this should cost? what is the frame called? i tried to do a google search for hitch receiver frame and didnt really get anywere.
  11. Jan 17, 2021 at 9:02 PM
    wilcam47
    Will
    Bourbon state
    LuvMyTacoma03[OP] likes this.
  12. Jan 17, 2021 at 9:06 PM
    LuvMyTacoma03
    2003 Red Tacoma trd
  13. Jan 17, 2021 at 9:13 PM
    wilcam47
    Will
    Bourbon state
    Thats dealership?, expensive! Id go with curt. Class III
  14. Jan 17, 2021 at 9:18 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Please go to a u haul or a trailer supply store and get the tow bar. It will be half the cost and work just as well.
  15. Jan 17, 2021 at 9:18 PM
    LuvMyTacoma03
    2003 Red Tacoma trd
    Anyone know approx how much i should expect to pay in labor for trailer hitch installation?
  16. Jan 17, 2021 at 9:21 PM
    LuvMyTacoma03
    2003 Red Tacoma trd
    Could you possibly give me a link to check out.. I thought a tow bar is for sway control and has nothing to do with pull.
  17. Jan 17, 2021 at 9:30 PM
    wilcam47
    Will
    Bourbon state
  18. Jan 17, 2021 at 9:36 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If you go to the Uhaul website. They have the price of hitch, installation and tax.
    I’m not telling you to go to Uhaul. I’m giving you a idea what it would cost here in East Tennessee.
    The price may be different where you live.
    https://www.uhaul.com/Trailer-Hitches/
    54EA87EF-B3B5-4F01-848D-02484FB42AAB.jpg 17BC302D-67F3-42BD-9E96-6C39E0DB8524.jpg
    LuvMyTacoma03[OP] and wilcam47 like this.
  19. Jan 17, 2021 at 9:37 PM
    jake72
    Jake
    N.E. PA
    If you go with a curt hitch and find a local mechanic, it might cost you around 250 for everything. A member on here might install for free
  20. Jan 17, 2021 at 9:37 PM
    TnShooter
    Deogee
    STOCK
    You likely won’t need the wiring harness above.
    I included it just to give you an over all price.
