My curtain airbags deployed!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nathan_M, Nov 28, 2020.
  1. Nov 28, 2020 at 9:00 PM
    #41
    2000prerunner23
    2000prerunner23 Well-Known Member
    steve
    Ya . Your inertial collision sensor went off probably form a hard bottom out . It happens, aw well ... Just have insurance fix it and get the new shocks like I said :) .
    I have seen this happen in person (passenger), on a ford ranger and f150. Near that area actually (ocotillo wells) and it was from a very hard bottom out through big woops . It happens when you go trophy truck mode . Probably not as common for people who respect their vehicles...
    Dubiousveracity and philth like this.
  2. Nov 28, 2020 at 9:03 PM
    #42
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    It's not an overreaction, just a simple statement of fact. If you're going to lie about what happened in order to get a free repair there's really no difference than if you stole the money from someone to pay for it. Should the airbags be designed differently is an entirely separate discussion but Toyota lists the limits of the system in the owners manual.
  3. Nov 28, 2020 at 9:08 PM
    #43
    T4RFTMFW
    T4RFTMFW Well-Known Member
    He’s 18 and just regurgitating what he reads online about airbag deployment being an automatic total loss.
  4. Nov 28, 2020 at 9:14 PM
    #44
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Just a little info:
    "Side Airbag Sensor Assembly: Detect intensity of side collision through electrical deceleration sensor."
    "Side Collisions: The side and curtain shield airbags are in case of side collisions. The side airbags are installed in the seatbacks of the driver seat and the front passenger seat, and the curtain shield airbags are installed in the upper areas of the right and left center pillars. If a side airbag sensor assembly detects an impact, the airbag sensor assembly causes the side and curtain shield airbags to be deployed simultaneously."
    Looks like Toyota can look into what caused the airbags to deploy as well. Or, you could take a look yourself if you have Techstream. See attached file.
    Dirk Diggler likes this.
  5. Nov 28, 2020 at 9:25 PM
    #45
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    What fuse do you pull? The 1 ign fuse? How does the fuel injection system operate with out that fuse and do the brakes still operate with the anti lock system no operational?
  6. Nov 28, 2020 at 10:11 PM
    #46
    Tacosha
    Tacosha Well-Known Member
    Andy
    Calgary, AB, Canada
    2019 Black Tacoma TRD OR ACLB 6MT
    minor, TRD skid plate, front recovery points, Regken mud flaps, rear diff breather, AC drain pipe extended. Upgraded sound with active sub woofer, tonneau cover, CB radio.
    Can puy my 2c on that: Side curtain airbags usually deploying with reach of certain angle, 15 to 30 degrees on board, left or right. It was very common case with Nissan X Terra,
    and then Nissan have a TSB for that, it was recall. Probably the same with Tacoma, I will recommend contact dealership, and keep all of us posted.
    Good luck!
  7. Nov 28, 2020 at 10:20 PM
    #47
    frenchee
    frenchee Favorite Member
    Oceanside CA Area
    2003 Tacoma TRD Double Cab 4x4
    Converted to 4WD DD VW MK6 TDI
    Lool!!
  8. Nov 28, 2020 at 10:30 PM
    #48
    92se-r
    92se-r Well-Known Member
    What fuse would you pull to prevent this
  9. Nov 28, 2020 at 10:31 PM
    #49
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    very expensive to repair
    no less should be done by a certified tech..................................if confidence of proper deployment
    at a later date /incidence is a serious consideration
    Malvolio likes this.
  10. Nov 28, 2020 at 10:36 PM
    #50
    frenchee
    Oceanside CA Area
    LOL
    OldGregg likes this.
  11. Nov 28, 2020 at 10:43 PM
    #51
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
  12. Nov 28, 2020 at 10:52 PM
    #52
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    The main problem with that is that Toyota Care will know the lat and long of where the air bags deployed, middle of the sand dunes.
    My neighbors GMC had the side air bags go on him just turning around on a logging road when he got off angle on steep embankment.
  13. Nov 28, 2020 at 11:41 PM
    #53
    frenchee
    Oceanside CA Area
    They have lat and long really ?
  14. Nov 28, 2020 at 11:54 PM
    #54
    CaptainBart45
    Bart
    Work in progress...
    I am setting up for the Baja 250 run and if I can simply pull a fuse, I would really love to know what fuse to pull?
    eclane and Smokinnuts like this.
  15. Nov 29, 2020 at 3:33 AM
    #55
    Tacoma Mike
    Southern Maine
  16. Nov 29, 2020 at 4:09 AM
    #56
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    Wtf
  17. Nov 29, 2020 at 4:13 AM
    #57
    chstaco
    chstaco Well-Known Member
    SC
    2020 Tacoma
    Got any videos or pictures of the jump? :devil:
  18. Nov 29, 2020 at 4:19 AM
    #58
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    Probably came down and slammed bump to hard, 45 mph on sand with a stock truck will do that.
    Norsemanvike and GreyBaldTaco like this.
  19. Nov 29, 2020 at 4:32 AM
    #59
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Did you have the truck towed or did you pop the airbags and drive it home?
  20. Nov 29, 2020 at 4:33 AM
    #60
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Just disconnect all the yellow sheathed wires that go into the SRS UCU. Makes the system dead, but you can still drive it, but will have no seat belt retraction in the event of a crash.
    You can have the ECU reset after rebuilding the system. You have to remove the ECU from the vehicle. I haven't done a 3rd gen, but I expect its similar to a 2nd gen.
    The dealer is not going to care how you set off the bags and they are not going to go to the trouble of retrieving your crash data. That's only used in cases involving you killing someone.
