My coolant is Brown after one day..
Discussion in '1st Gen. Tacomas (1995-2004)' started by J.A.92, Jan 5, 2019.
  1. Jan 5, 2019 at 4:59 PM
    J.A.92
    J.A.92 [OP] 97 Tacoma 4x4 lx 5 speed manual.3.4L
    Juan
    1997 Tacoma 4x4 lx xtra cab.3.4
    Not liking the look of this.No visible leaks
  2. Jan 5, 2019 at 5:01 PM
    goldentaco03
    goldentaco03 Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    Pretty sure that means oil is getting in the coolant, or your radiator is fucked. Did the level rise at all? If not then maybe you just have a really crudded up radiator or block
  3. Jan 5, 2019 at 5:08 PM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    Smell the coolant and or test it/have it tested. Also, check the oil and don't drive it until you figure this one out. Could get really expensive really fast...
  4. Jan 5, 2019 at 5:39 PM
    J.A.92
    Juan
    I will when i get home.Im praying it's not a head gasket
  5. Jan 5, 2019 at 5:40 PM
    J.A.92
    Juan
    Well expensive obviously
  6. Jan 6, 2019 at 2:41 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    How did you get to this point ?
    All of a sudden your coolant in the overflow is rust brown??
    Then it might be the brown Milkshake of oil and antifreeze mix??
    Toyota Red coolant mixed with the Green can turn a pretty rust brown .
    Gunshot-6A and cruiserguy like this.
  7. Jan 6, 2019 at 8:59 AM
    J.A.92
    Juan
    Yeah I forgot last time I put red in.But it already went through 1/4 of the reservoir.Im gonna flush it today.and really see.it got hot yesterday and didn't have any coolant so I put green in it when I was already at the gastation.I replaced a knock sensor recently.Im wondering why I'm going through coolant so quick still
  8. Jan 6, 2019 at 9:23 AM
    J.A.92
    Juan
    What would the coolant smell like
  9. Jan 6, 2019 at 9:29 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    It smells "sweet". That's why animals like it.
    Gunshot-6A likes this.
  10. Jan 6, 2019 at 9:32 AM
    J.A.92
    Juan
  11. Jan 6, 2019 at 10:00 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    If you're consuming coolant that quickly then there is a big problem
  12. Jan 6, 2019 at 10:26 AM
    J.A.92
    Juan
    Yeah,I'm gonna drain it out cause all I did was top it off.And go from there.There is no white smoke or visible leaks.
  13. Jan 6, 2019 at 10:34 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Pull a sparkplug. If its shiny clean, its being steam cleaned, and that aint good.
  14. Jan 6, 2019 at 10:35 AM
    J.A.92
    Juan
    Ok I will do that and let you know shortly
    cruiserguy likes this.
  15. Jan 6, 2019 at 10:36 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    May have to pull all of them. Gasket could be leaking in just one cylinder.
  16. Jan 6, 2019 at 10:40 AM
    J.A.92
    Juan
  17. Jan 6, 2019 at 12:57 PM
    J.A.92
    Juan
    Doesn't smell sweet
  18. Jan 6, 2019 at 3:01 PM
    goldentaco03
    Liam
    NJ
    If the coolant level is dropping then it’s going somewhere. Could be anything from a radiator leak (which it sounds like it’s not) to a bad gasket like others are saying
    Leaning towards bad head gasket cause of the loss of coolant and the possible oil getting into the coolant
  19. Jan 6, 2019 at 3:07 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Don`t ever rule out the heater core since OP had no idea of the smell
    then it might drain out the evap drain you might never take notice
    goldentaco03 likes this.
  20. Jan 6, 2019 at 3:16 PM
    J.A.92
    Juan
    Don't rule out the hearter core?
