My 2013 Retro Satoshi Style Grill Mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PUBCRAWL, Oct 3, 2014.
  1. Oct 3, 2014 at 6:18 PM
    PUBCRAWL
    PUBCRAWL [OP] MIGHTY TACO
    Ontario, Canada
    Tacoma TRD DCLB
    Hey All,
    Just wanted to share my retro Satoshi style grille mod on my 2013 TRD DCLB.
    It turned out to be a little more involved than I originally thought.
    I've seen all those really great looking metal mesh mods posted on the forum but wanted something that looked a little different and a little more factory like. So I decided to go with an all plastic mod using a sheet of ABS Grille Mesh I purchased on eBay.
    I started off with a brand new grille and went at it.
    I used 3M's Automix System. For the bonding I used the 08237 Semi-Rigid Parts Repair. This stuff worked really good. I used it to hold the mesh panel in place and to fill in the gaps.
    To complete the "surround" ledge on the grille needed to attach the inset panel I ended up just using pieces of grille I cut out. I simply heated the pieces up to shape them into the proper curved shape. The plastic molded really well and once cool held its shape.
    For extra support and secure the grille insert firmly to the framework I screwed stainless screws into the lower section up into the insert to hold the grille insert in place. The screws ended up a little long but I simply cut them off and ground them flush. Once painted they were not even visible.
    Some sanding and shaping and it was ready for paint.
    I ended up used Dupli-colour's Truck Bead Liner in a spray can. The finish and colour was exactly what I as looking for.
    5ef0b79f-5e1c-4668-adc4-08ab5e9c5bbf_zps_04423d867c6f0ddb7c439985ce88aff8f099d5e3.jpg
  2. Oct 3, 2014 at 6:31 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Looks good. Props for taking on the project.
  3. Oct 3, 2014 at 6:53 PM
    krob32
    krob32 Well-Known Member
    Kelly
    Sierra Vista, AZ / Asheville, NC
    2012 MGM TRD Sport DCLB
    WeatherTec Digi Liners, AVS Bugflector II, TRD FJ SE Anthracite Rims, BF Goodrich AT KO2 265/75/16, AVS In-Channel Wind Deflectors, Extang Solid Fold, Pop & Lock, Color Match Grill Emblem (Anthracite), Plasti Dip Emblems, Tacoma Bed Mat, Tacoma Door Sill Protectors, ToyTec Ultimate Lift Kit, ICON UCAs, Wheeler's Progressive AAL, Wet Okoles, Sockmonkey 3rd Brake Light Cover, LED Hood/Bed Lighting w/ OTRATTW Switches, Famous Fabrication Sliders, Sockmonkey TRD Bed Decal, Proven Design 4x4 Mudflaps, BenWA's Rear Power Sliding Window, Jasper Off Road 6" Reverse LED Pod, ImMrYo Rear View Mirror Bracket, GrillCraft w/ Black Mesh and color matched Land Cruiser Emblem, LED Tail Lights, Badge Removal and Vinyl TRD/Tacoma Stickers, Bullaculla Trailer Harness Relocation.
    Very nice!
  4. Oct 3, 2014 at 7:16 PM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    Very nice.
  5. Oct 3, 2014 at 7:19 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Great job! :thumbsup:
  6. Oct 3, 2014 at 7:29 PM
    Pool Runner
    Pool Runner Well-Known Member
    Nor Cal
    '14,TRD/OR, Entune & Nav '13 Subaru Outback
    Lowes Slimline Tool box, OEM Bug shield.
    I like it, any pics on the truck?
  7. Oct 3, 2014 at 7:34 PM
    PUBCRAWL
    Ontario, Canada
    Tacoma TRD DCLB
    Not yet. Just finished it this afternoon and haven't mounted it yet. Tomorrow I'll be adding a new lift front and back and my new wheels. Probably get to the grille this weekend at some point.
    Powder coated TRD stock wheels with TRD caps and Mickey Thompson Baja STZ's LT275-70R-17
  8. Oct 3, 2014 at 7:35 PM
    John taco
    John taco Well-Known Member
    JT - Johnny
    King of Prussia PA
    Nice. Let's see it on the truck now
  9. Oct 4, 2014 at 2:24 PM
    Fox
    Fox Active Member
    Central Colorado
    '09 Tacoma DCSB, Leveled
    Leveled with Bilstein 5100 adjustable front shocks, All-pro front bumper, Red under dash lighting,
    Awesome grille man.
  10. Oct 6, 2014 at 5:37 AM
    PUBCRAWL
    Ontario, Canada
    Tacoma TRD DCLB
    Busy weekend working on with the old Taco.
    Got the lift, wheels and the upper and lower grille assemblies installed.
    Here's a picture of the grille work.
    Lower grille was removed and painted with the same bed liner paint as the upper grille.
  11. Oct 6, 2014 at 5:58 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Looks good!
    These grills are definitely more involved than people seem to realize..
  12. Oct 6, 2014 at 6:04 AM
    randallxl
    randallxl PBRMEASAP
    Randall
    Upstate NY
    2012 DCSB TRD Sport
    just storm troopered
    Looks really really good!! props in taking the extra time to locate that ABS plastic mesh, looks almost factory!! nice job!!
  13. Oct 6, 2014 at 6:07 AM
    harley3
    harley3 Well-Known Member
    Scott
    Lexington KY
    2014 DCSB TRD Off-Road 4x4
    Redline Tuning Elite Hood Lifts, Weathertechs, Black Devil Horns (thank you Andres), G-Tek Fab Door Sill Protectors (thank you Greg), interior LED lights, Pioneer AVH-4000NEX, Kenwood 700w amp, Alpine door speakers tweeters and sub, SuperCrewSounds single sub box
    I really like that!!!!
  14. Oct 6, 2014 at 7:32 AM
    PUBCRAWL
    Ontario, Canada
    Tacoma TRD DCLB
    Thanks for the comments.
    It was a lot of messing around to make it all come together.
    The 3M Automix stuff was the key. Much better than bondo.
    It is as strong as the parent ABS plastic. Its expensive but it does a great job.
    This is the gun I have. Used the 08237 Semi-Rigid Plastic.
    What really makes the grille look good it the curved ends.
    I managed to bend the mesh inserts end to fit the grille frame properly.
    Already getting lots of comments on the grille from people that have seen it in person.
  15. Jan 18, 2015 at 5:30 PM
    la.vet1984
    la.vet1984 New Member
    TSS 4x4
    Weathertech Mats Readylift 3.0" Sst Lift
    I am wanting to get the satoshi grill with the retro Toyota emblem. Does someone sell the whole grill or do you have to do this mod on your own? I've seen a lot of posts of people doing the mod, but it would be nice just to buy it done already.
  16. Jan 18, 2015 at 5:36 PM
    PUBCRAWL
    Ontario, Canada
    Tacoma TRD DCLB
    What year is your truck?
    There seems to be a lot of aftermarket grills available for the 2005-2011 Tacoma but the newer 2nd Gen's 2012-2015 are usually make-your-own. Although not a true Satoshi style grill the 2015 Tacoma TRD Pro grill can be purchased at an excessively high price.
  17. Jan 19, 2015 at 9:48 PM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Nice work. Does almost have that factory look with the mesh you used .Got a spare grill been wanting to do a satoshi. Will try something like this .Definetly original . [​IMG]
  18. Jan 20, 2015 at 12:17 AM
    la.vet1984
    TSS 4x4
    Thanks PUBCRAWL...I have a 2013 tss 4x4. I looked up the 2015 TRD Pro grill and I want it now! Yeah, the price is high and hopefully it will go down. I haven't found much saying it will fit the 2013...some say it will fit and some say I won't. I have the chrome grill shell, so if I get the TRD Pro grill I will have to get the matching shell also. Both very hard to find!
  19. Jan 20, 2015 at 4:29 AM
    PUBCRAWL
    Ontario, Canada
    Tacoma TRD DCLB
    The Tacoma 2015 TRD Pro grille will fit your 2013 Tacoma. The Part # is PTR54-35150.
    Looking online at what's available it appears that you do NOT get the grille surround which would normally come with a standard Tacoma grille.
    You can reuse your original surround and paint it if needed. It's only held on to the grille insert by about 6 screws.
    Taking the grille out on a 2013-2015 Tacoma is pretty straight forward and it takes me all of about 3 minutes to do so.
  20. Jan 20, 2015 at 7:18 AM
    Rippin101
    Rippin101 Well-Known Member
    Jax Beach, FL
    2014 TRD Sport 4x4
    -Nitto G2 265/70/17 -Level 8 MK6 Wheels -Katzkin Leather Black on Black -BHLM -Weathertech -Extang Solid Fold -Bedlight LEDs -TRD Skid
    Wow great job!
