My 1996 Tacoma 2.4 just it gave me a P0110 code NOT sure where to look
Discussion in '1st Gen. Tacomas (1995-2004)' started by oldguy128, Jul 3, 2021.
  1. Jul 3, 2021 at 9:22 PM
    oldguy128
    oldguy128 [OP] Well-Known Member
    GARY
    Southbury CT
    1996 Toyota Tacoma
    I have the air filter that you clean and spray oil, I touched around the air intake when this happened before, and it went away for 6 months, so I did it again, and maybe it's good again " where is that sensor exactly so I can look at it close up, and if needed what part number, and how to remove it, the truck has 131K miles on it, I just got the part today for the shifter and on the way home this happened to it, go figure I can't win, last week the windshield cracked
    davidstacoma likes this.
  2. Jul 3, 2021 at 9:35 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I think that code is for the Intake Air Temp.
    I also believe it’s a function of the MAF Sensor.
    It’s usually located just behind the air filter box.
    Check to make sure it is plugged in good.
  3. Jul 3, 2021 at 11:22 PM
    oldguy128
    GARY
    Southbury CT
    1996 Toyota Tacoma
    It happened, today, I reset it, I drove 20 seconds, and it came back on, I got home, reset again, and waited about 5 minutes running, "it did not act up", I see two items plugged in, I removed both, and put back the connectors, and drove around now its good WTF, I'm confused, to be honest, I feel its a bad wire issue, or connector maybe but once I mess with it it does not go bad when I want it to go bad, its got a mind of its own
  4. Jul 3, 2021 at 11:33 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    its not mystical
    U have a good idea & proximity where Ur issues emanate
    use ‘ Contact Cleaner ‘ ( alcohol sometimes WD40) to be certain NO contaminated faulty contaminated connections
    no need to be aggressive (age is a factor ) trace the wiring to be certain not worn or frayed
    good at both ends
    now U might have narrowed matters down
    could be either of the sensors in that area.................price them out
    if U replace 1 or both dont cheap out
    while OEM always costs more
    there is a reasonable expectation OEM will perform consistently the same in function & longevity
    oldguy128[QUOTED][OP] likes this.
  5. Jul 3, 2021 at 11:52 PM
    oldguy128
    GARY
    Southbury CT
    1996 Toyota Tacoma
    I'm going to pull them off again using wd40 it is a good contact cleaner
  6. Jul 4, 2021 at 11:42 AM
    TnShooter
    Deogee
    STOCK
  7. Jul 4, 2021 at 11:54 AM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    https://www.autocodes.com/p0110_toyota.html
    First thing I would do is replace that oiled filter with a good dry filter whether that’s the cause or not. Then look at this link for other possible causes.
    SLAPS 65 likes this.
