Musty smell when running the heater
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Canyon lands, Dec 13, 2020.
  1. Dec 13, 2020 at 9:49 AM
    Canyon lands
    Canyon lands [OP] Well-Known Member
    Bill
    Colorado
    2015 red Tacoma TRD off-road
    3” lift, leer topper, James Baroud tent, Lund bull bar, 4 wheel running boards, Pioneer stereo, fosgate speakers, amp, bed slide, Thule racks, road shower
    We purchased a 2015 Tacoma, I replaced the filter in the cab/ air vent, and I’m still getting a slight musty smell when the heater is on. I don’t notice it with the a/c. Any ideas?
  2. Dec 13, 2020 at 9:50 AM
    Clearwater Bill
    Billy
    Largo Florida
  3. Dec 13, 2020 at 10:18 AM
    rednext
    rednext Well-Known Member
    Eh I just went to the hardware store and got a can of Ozium and sprayed it in the vents. And everywhere else. Seems to work
    tacotoe likes this.
  4. Dec 13, 2020 at 11:08 AM
    MNMLST
    MNMLST Well-Known Member
    Earth
    tinfoil lined cab runflat headlights pee-thru seats
    Have you tried clean underwear...?
  5. Dec 13, 2020 at 11:10 AM
    rednext
    Well this is my December pair. I'll let you know when I swap to my January pair if it helps
  6. Dec 13, 2020 at 11:12 AM
    MNMLST
    Earth
    Go commando, you’ll save a ton of ca$h on cabin filters...
  7. Dec 13, 2020 at 11:12 AM
    Canyon lands
    Bill
    Colorado
    I’m still on my November pair, could that be the issue?
    Rock Lobster, tacotoe and MNMLST like this.
  8. Dec 13, 2020 at 11:16 AM
    Canyon lands
    Bill
    Colorado
    I have since found several cleaning kits after the link sent by Clearwater Bill, any recommendations as to the best?
  9. Dec 13, 2020 at 11:19 AM
    MNMLST
    Earth
    Turn it on full blast and spray Lysol in the return
    (You can’t cover up mold, you gotta kill it)
    tacotoe likes this.
  10. Dec 13, 2020 at 11:53 AM
    Canyon lands
    Bill
    Colorado
    Most cleaners seem to recommend a disinfectant after the flush. BG seems to have a one they would probably do the trick. I want to get it throughout the entire system, and be done with the moldy smell
  11. Dec 13, 2020 at 12:04 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    I believe the Lysol as mentioned would be considered a disinfectant. Blower on high and recirc on.
    MNMLST likes this.
  12. Dec 13, 2020 at 12:27 PM
    MNMLST
    Earth
    I’m also guessing you have a condensate drain plugged up somewhere, hence the moisture/fungus/stank retention...
    tacotoe likes this.
  13. Dec 13, 2020 at 3:59 PM
    Canyon lands
    Bill
    Colorado
    I was wondering the same thing. Will check the drain as soon as it get back around freezing After viewing so many Youtube videos, I wonder how clean the evaporator/ heater core by spraying Lysol into the system. It would probably be disinfected, barring the wife’s smell test
    tacotoe likes this.
  14. Dec 13, 2020 at 5:17 PM
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    Happens a lot if the truck has been sitting. Two cars I bought had that smell. Both cases resolved themself. Try running full heat with windows open. Then Lysol, ozium has also worked well. I also have found in my case that summer is the culprit, and I try to run the a/c off for a few minutes before arriving at destination cleans out excess moisture.
  15. Dec 13, 2020 at 5:50 PM
    Clearwater Bill
    Billy
    Largo Florida
    https://www.tacomaworld.com/threads/rust-varmit-and-ac-clogging-prevention-project.557970/
    When you look in this thread and see how part of it is made, apply your disinfectant via the cowl intake with the cabin filter removed.
    Also you can attach a shop vac to the AC drain which will clear that if the tube is clogged.
    Using the thread above, you'll likely find lots of things to clean. And be able to prevent rodent intrusion (via the cowl) as well.
    tacotoe likes this.
  16. Dec 13, 2020 at 6:52 PM
    Canyon lands
    Bill
    Colorado
    Great thread! Thanks. Always amazed how much knowledge exists on this site.
    tacotoe likes this.
  17. Dec 14, 2020 at 3:51 AM
    cmoore
    cmoore Well-Known Member
    Charlie
    Dallas, Texas
    PreRunner
    Since it's new to you truck I would check the air intake and blower for any critter nesting. I found some dead baby mice in my blower one time.
    Canyon lands[OP] and tacotoe like this.
  18. Dec 14, 2020 at 4:25 AM
    blur
    blur Well-Known Member
    I’ve noticed this with my 12 and my brothers 13. Neither gets driven a lot, especially mine in the winter. Where is the ac drain? I’d like to check this first. I had a clogged vent drain on a 93 wrangler that caused water leaking problems for years before I stumbled across the clogged drain hose.
    I’ve always tried to turn off the ac before turning the truck off in the fall, assuming that has something to do with it but no luck yet.
  19. Dec 14, 2020 at 9:58 AM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    on the firewall on the passengers side
    kind of just stubs out from the FW
  20. Dec 14, 2020 at 10:26 AM
    blur
    Thank you. I’ll give it a look.
