Muffler/exhaust replacement question
Discussion in '1st Gen. Tacomas (1995-2004)' started by brian1649, Jun 17, 2020.
  1. Jun 17, 2020 at 5:04 AM
    brian1649
    brian1649 [OP] Well-Known Member
    Hi all,
    I've recently had a large (fist sized) hole blown out in the rear of the muffler from rust. When looking online at replacement exhaust parts, everything with the muffler seems to be cat back/resonator back, and include a flange. But looking at the exhaust on the truck, it seems to be one piece all the way from the header to the exhaust tip - am I missing a slip joint or something? (2001 2.7l ext cab 4x4 5spd)
    This will certainly sound silly, bit what's the process for replacing mufflers? I've only replaced an exhaust section on my Celica but it was bolt in with the flanges. I'm hoping to not have to replace the whole exhaust length in this truck since most of the upstream tubing is in decent shape (except the flange at the exhaust header is completely rusted so I doubt that will ever come apart). Do you typically just go to an exhaust shop and they'll cut and weld in a new section? Any recommendations on muffler to exhaust tip parts? Any recommendation on exhaust shops too? Should I avoid the big chains? I'm located in the Boston area. Thanks
  2. Jun 17, 2020 at 6:04 AM
    Kleenax
    Kleenax Well-Known Member
    Ray
    Michigan
    2001 SR5 4WD V6 Auto - Mica Green
    New frame & stuff CBI bolt-on Sliders
    I just did that muffler replacement on my 01' Tacoma. I found a muffler the exact length and configuration that I needed to replace the original, and just cut off the original with a Sawsall, and used 2 stainless band clamps to affix the new muffler. A little tip that I learned long ago about cutting pipe "reasonably straight" is to first put a stainless hose clamp around the pipe exactly where you want to cut, and use that as a guide for the sawsall blade. Be careful tho NOT to cut the hose clamp! ;-)
    As for hangers, the originals are welded to the back of the original muffler, so I used a 4" grinder to cut them off as-close-as-possible to the muffler and then used a stainless hose-type clamp to fasten the hangers to the new muffler system after it was installed; works perfectly, and I love the sound; sounds very V8'ish! The whole process took me about an hour. I DID clean up all of my cuts with a grinder prior to assembly.
    Incidentally, the actual muffler that I chose was a stainless steel guaranteed-for-life, MagnaFlow XL 3 Chamber Muffler #13745 from Summit Racing.
  3. Jun 17, 2020 at 8:19 AM
    IdahoRedBeard
    IdahoRedBeard Active Member
    Cody
    American Falls, ID
    01 Tacoma TRD Dbl Cab 3.4L
    Would love to hear this set up. Im looking at replacing the stock muffler as well
  4. Jun 17, 2020 at 11:15 AM
    SkunkMan17
    SkunkMan17 Jerry-rigging everything
    Owen
    Montana
    1997 Tacoma RC 4x4
    Tasteful modifications :)
    Having a dynomax ultra flo put on my truck soon here as well. I’ll let y’all know how it sounds
  5. Jun 17, 2020 at 3:01 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    I make it easy. buy a Bosal or Walker muffler and cut off the old muffler. the hangers are already welded and use one clamp to join them
    cruiserguy and Lucifer1 like this.
  6. Jun 17, 2020 at 4:45 PM
    brian1649
    Thanks for all the feedback.
    Kleenax, I'm looking to cut in pretty much the same spot you did, right upstream of the muffler. But I'm hoping to get something with the tailpipe out the back included
    Frizzman - does the Bosal or Walker muffler come with the tailpipe as well? I'd love if all the brackets were already on
  7. Jun 17, 2020 at 5:12 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    The easiest method would be just going to a muffler shop and have them cut out the muffler and add a new one. They don't need to mess with any of the rest of the pipe if it's in good shape.
  8. Jun 17, 2020 at 5:21 PM
    Lucifer1
    Lucifer1 Well-Known Member
    Lucifer
    Plano TX
    2023 Silver TRD Sport Access cab V6 automatic
    Toyota Bed divider
    On U- tube there is a grate video of a guy replacing his while system on the cheap, certainly worth watching. With this truck the possibilities are endless.
  9. Jun 17, 2020 at 5:41 PM
    Kleenax
    Ray
    Michigan
    My tailpipe was in GREAT shape (as was the pipe from the muffler to the back CAT), so for the $8.99 band clamp, I kept my original tailpipe. Like I said in my original post, the original (cut-off) hangers worked fine simply clamping them to my new muffler.
    Lucifer1 likes this.
  10. Jun 17, 2020 at 5:44 PM
    Kleenax
    Ray
    Michigan
    Incidentally, the Band Clamp to buy (you need 2) is this one:
    https://www.summitracing.com/parts/sum-681225
  11. Jun 17, 2020 at 10:59 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    yes, the bosal and walker have a short section in front of the muffler, and then the complete tailpipe as one piece
    Wyoming09 likes this.
  12. Jun 17, 2020 at 11:02 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
  13. Jun 18, 2020 at 1:09 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Anymore Walker Exhaust is all I use
    All Bolt on you get find it most places .
    Lucifer1 and cruiserguy like this.
