Mud guards for non flare Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Chief Ucon, Mar 18, 2023.
  1. Mar 18, 2023 at 9:19 AM
    Chief Ucon
    Chief Ucon [OP] Member
    2023 dark gray Tacoma
    My 2023 Tacoma does not have the fender flares. The OEM mud guards do not fit. I have contacted Weathertech and the truck is too new and they don't have anything yet that will fit. What say the Tacoma World bunch? What guards will fit my non-flare Tacom?. Thanks all.
  2. Mar 18, 2023 at 9:23 AM
    hanlan75
    hanlan75 Well-Known Member
    NNJ
    2023 White Taco SR, 2022 MSM Tesla Y P
    I put on a set of Rek gens on my SR with no fender flares and have no issues.
    Junkhead likes this.
  3. Mar 20, 2023 at 1:48 PM
    Commocean
    Commocean Well-Known Member
    St. Petersburg, FL
    2023 Tacoma SR5 DCSB 2.7L Ice Cap
    Wait for the Weathertech's. They look and fit like OEM on non-flared Tacoma's.
    tvterry likes this.
  4. Mar 20, 2023 at 2:19 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    order for a 2022.
  5. Mar 20, 2023 at 2:44 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    What do you mean your truck doesn’t have fender flares and thus the mud guards don’t fit? This doesn’t add up for me. Do you mean that you have color matched fender flares instead of black? Regardless, I’m not sure why that would interfere with mud guards.
    Nothing significant has changed on tacos since 2016. Weathertech probably hasn’t updated their product database to include 2023
  6. Mar 20, 2023 at 2:56 PM
    bcgill
    bcgill Well-Known Member
    Ben
    Blacksburg, Virginia
    2019 SR 3.5L V6 4x4 Magnetic Grey
    Same and I'm happy with them.
  7. Mar 20, 2023 at 3:11 PM
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    The OEM mud flaps are designed to fit with fender flares, otherwise when using them on trucks w/o them there'll be an excessive gap like shown in the following thread: https://www.tacomaworld.com/threads/mud-flaps-guards-on-a-2021-tacoma-sr-4x4-double-cab.720065/
    Stink_Bait! and Junkhead like this.
  8. Mar 20, 2023 at 3:12 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    +1 on rekgen.
    Order for 2022, their site simply isn't updated.
    I had to order for 2020 to put on my 2021.
  9. Mar 20, 2023 at 3:23 PM
    gudujarlson
    Minnesota
    I did not know the SR didn’t have plastic fender flares. I believe the fender has mounting points for the flare and it seems unlikely Toyota would make a special fender for the SR. Do they hide the fender flare mounting points?
    Also, does this mean that you cannot compare hub to fender flare measurements between an SR and any other trim?
  10. Mar 20, 2023 at 3:31 PM
    bcgill
    Ben
    SRs are missing some of the mounting holes the flares clip into. This thread that explains how to installing them on an SR shows the clips on the flares you have to cut off to make it work.
    https://www.tacomaworld.com/threads/fender-flare-installation-on-non-flared-tacomas-tutorial.494336/
  11. Mar 20, 2023 at 3:40 PM
    gudujarlson
    Minnesota
    Interesting. It’s hard for me to understand how Toyota is saving any money by creating a special stamping die for SR fenders, but there is likely some engineering subtleties I’m not privy to.
  12. Mar 20, 2023 at 3:48 PM
    GumShoe
    GumShoe Well-Known Member
    New Mexico
    MGM 2016 Tacoma SR V6 4x4 DCSB
    The screws in the wheel liner of the SR is the same as any other trim, it just doesn’t have the cutout/holes for the clips to support fender flares. Measurements wouldn’t be an issue since most installs, like steel bumpers, requires people to remove the fender flares anyways.
    Here’s a higher trim without the fender flares.
    Canufixit and Junkhead like this.
  13. Mar 20, 2023 at 3:54 PM
    gudujarlson
    Minnesota
    What I’m trying to say is that it’s my assumption that the fenders are stamped using a die, thus two different versions of them requires two different dies. Dies are typically expensive to create, so having two instead of one could out weigh the cost of not providing plastic fender flares on the SR. There are obviously subtleties I’m missing.
  14. Mar 20, 2023 at 3:55 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    As others said. 16's thru 22's will fit your 23.
    RIX TUX and GumShoe like this.
  15. Mar 20, 2023 at 4:28 PM
    mushroom_man7
    mushroom_man7 Well-Known Member
    i have no fender flares either. the oem ones suck, as they do not bend if you hit anything with the mudflap. i got after market ones called rekgen cause they are stiff but will bend if the flaps land om a rock while offroading. sometimes oem is not the best way to go, toyota just wasnt thinking straight on these flaps.
  16. Mar 20, 2023 at 4:35 PM
    GumShoe
    New Mexico
    It's so Toyota can sell more. You break one then you have to buy another set. It's the perfect crime.
  17. Mar 20, 2023 at 4:38 PM
    Reddirtnaps
    Reddirtnaps Well-Known Member
    Oklahoma
    2019 DCSB 99 UZJ100
    Another vote for rekgens
  18. Mar 20, 2023 at 5:25 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    No problems here with OEM mudflaps off-road.
  19. Mar 20, 2023 at 7:11 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    the oem guards only fit the black fender flares on the pro and the OR
  20. Mar 20, 2023 at 7:14 PM
    RIX TUX
    yes you are missing it
