mpg loss with 1 inch wider tires?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by slow TURD I4, Jan 21, 2019.
  1. Jan 21, 2019 at 8:41 PM
    slow TURD I4
    slow TURD I4 [OP] Well-Known Member
    SD
    2018 DCSB 2.7
    so going from standard sr5 tires to stock trd tires the size difference is basically 1 inch difference. So
    245 75 r16 vs 265 70 r16...who has done it? How many mpg can expect to loose with just going with the stock trd offroad tire compared to my stock tire?
  2. Jan 21, 2019 at 8:52 PM
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    Expect to lose around .62515289MPG.
  3. Jan 21, 2019 at 8:58 PM
    shackley
    shackley Well-Known Member
    Albuquerque, New Mexico
    2018 TRD Pro MT Super White
    RCI rock sliders, Goodyear Ultraterrains 265/70/R16, BAK X2 tonneau
    I went from stock Goodyears (265-70/16) to 265-75/16 KO2s and lost a little over 1mpg, but the increase in off road traction was worth it.
  4. Jan 21, 2019 at 9:01 PM
    devidstaco
    devidstaco You look like a mothsfuckin uhhhhh
    David
    Tempe, AZ
    ‘18 QS DCSB TRD OR
    Nothing major
    Don’t do it if you’re worried lol
    Sclarpepplar likes this.
  5. Jan 21, 2019 at 9:08 PM
    Construct
    Construct Well-Known Member
    Tire size is only one part of it. You could switch to the exact same size of a different tire and lose 1-2mpg.
    Generally speaking: Bigger sizes, heavier tires, higher load ratings, and more aggressive M/T style tread patterns all contribute to decreased gas mileage.
  6. Jan 21, 2019 at 9:15 PM
    computeruser6
    computeruser6 Nuclear Janitor
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    As mentioned it will depend on the weight of the tire, tread, and compound and not just tire size. Giving you an estimate is nearly impossible.
    bobbyfresh24 likes this.
  7. Jan 21, 2019 at 9:32 PM
    Qwack
    Qwack Well-Known Member
    Oahu
    2016 TRD Sport 4x4 2017 4Runner
    just by leaving your wife home will make up for any loss of mpg from going up one tire size.
  8. Jan 21, 2019 at 9:41 PM
    bobbyfresh24
    bobbyfresh24 Well-Known Member
    Bob
    Southern Cal
    2017 SR5 DCSB 4x4 AT Super White
    BFG 265/70/17 KO2 FN FX Pro Matte Black
    I went from the stock sr5 wheels and tires (245/75/16 destination le, I believe) to 265/70/17 ko2 in C rating and have lost 2+ mpg.
  9. Jan 21, 2019 at 9:47 PM
    4drtaco03
    4drtaco03 Well-Known Member
    BAY AREA
    2003 TRD/ 2004 / 2019 SR5 4x4… now awd sprinter
    Just switched from the stock sr5 rims & tires to off road rims and tires. Do the same drive everyday and I was getting 23.0 now I get 22.3 haha. DF40D16F-8E15-4978-B77A-B8EB92CA8C28.jpg
    Tharris242 likes this.
  10. Jan 21, 2019 at 10:51 PM
    wood714
    wood714 Got any Quaaludes?
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    I went from 245/75-16 tires to 265/65-17. Their about the same height, but around an inch wider. I lost 1 to 1.5 MPG.
  11. Jan 22, 2019 at 8:20 AM
    Roddy13
    Roddy13 Well-Known Member
    Surprising feedback, I went from 265/70/16 to 265/75/16 and lost 1.5mpg city... gained most of it back by airing the tires up alot more than the tire shop put them at (had them at 35psi in an 80psi tire... I went to 50psi) and put a drop in dry flow filter and a free flow dynomax ultra
    muffler.... at the end of the day I was about even with stock.. maybe down .5mpg here and there.
  12. Jan 22, 2019 at 8:27 AM
    cowsquatch67
    cowsquatch67 Well-Known Member
    And look damn good doing it I might add!
    4drtaco03[QUOTED] likes this.
  13. Jan 22, 2019 at 8:29 AM
    Jere
    Jere Outdoorsman
    Northern Chester County, PA
    '18 TRD Sport MGM with ARE Cap
    As mentioned there are plenty of things that will impact your mpg, including tire compound, tread, weight, width, rolling resistance, . . .
    But, Also remember that a different rolling circumference tire will alter your odometer reading, and impact your mpg calculation independent of weather your actual mpg is changed.
  14. Jan 22, 2019 at 8:40 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Did you account for the 4% offset for your odometer? You def lost some MPGs with the KO2s, but it isn't QUITE as bad as it looks. That said, my swap from 265/70/16 mild ATs to 265/75/16 LT ST Maxx tires was about 2-3 mpg hit. Mainly due to the 16 pound increase per tire, plus much bigger treads.
  15. Jan 22, 2019 at 8:43 AM
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    Yes, but it fixes the taco lean.
    Qwack[QUOTED], WSW3 and Gunshot-6A like this.
  16. Jan 22, 2019 at 9:42 AM
    bobbyfresh24
    Bob
    Southern Cal
    You are absolutely correct and yes, I have been using the correction in my calculations. Good point that I forgot to mention.
    Gunshot-6A[QUOTED] likes this.
  17. Jan 22, 2019 at 9:43 AM
    LSUfan1975
    LSUfan1975 Well-Known Member
    Eric
    Washington NC
    2019 SR5 Dbcb MGM
    The loss in mpg is a bit overstated also. Math doesn't lie. Take for example changingfrom 245/75 16 to 265/75 16. Your computer measures the number of rotations of the wheel to calculate distance. Changing that route is roughly a 2% change in circumference. That's a 2% increase in the distance your truck reads as being one mile. You are actually getting 2% better than what the computer says. That math holds true to everything your truck measures as a mile. You are also going 2% faster than the Speedo says. And your odometer is reading 2% less than actual. Not saying it doesn't change at all. We know tread changes friction and weight changes rolling resistance. But 2% calculation error should be subtracted from the difference you think you are getting
  18. Jan 22, 2019 at 9:44 AM
    LSUfan1975
    Eric
    Washington NC
    2019 SR5 Dbcb MGM
    Didn't see gunshot beat me to it.
  19. Jan 22, 2019 at 9:55 AM
    Gunshot-6A
    Conner
    Everett, WA
    Math doesn't lie, but it also doesn't make it much better :(
  20. Jan 22, 2019 at 10:02 AM
    Sclarpepplar
    Sclarpepplar Your raptor lights look like braces.
    Corey
    2016 TRD sport
    BFG KO2's Fuel rims SPC uca's Arb OME lift Arb on board air Prinsu designs roof rack
    Thank you. This is how I always feel about these questions. Just go buy a small car with a 4cyl engine. Problem solved.
    devidstaco[QUOTED] likes this.
