MPG dropped after oil change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cllowe24, Feb 25, 2016.
  1. Feb 25, 2016 at 4:24 AM
    cllowe24
    cllowe24 [OP] Well-Known Member
    Mid Tennessee
    2015 access cab
    Billstines with 885 coils 2”aal Lce header, pro dry drop in filter, charcoal filter removal, light bar in grill, ditch lights, yaesu dual band radio, and a bunch of other junk
    So I had my oil changed last sat and now my mpg is horrible. Before I was getting 18-20. Truck is 15 with 35,000 miles. Any ideas
  2. Feb 25, 2016 at 4:40 AM
    keith88lx
    keith88lx Well-Known Member
    Mount Prospect
    15 DCSB TRD Sport 4x4
    Who changed it (dealer, friend, chain store)? And did they use the correct oil weight?
    This happened to my previous car (VW Jetta). Dealer changed oil and my MPG went to shit. I later changed it myself and the MPG went up significantly. I had no idea what the dealer did. I'm assuming the VW dealer didn't change my oil filter, just drained and refilled oil.
  3. Feb 25, 2016 at 4:41 AM
    BDL5589
    BDL5589 Well-Known Member
    NE Georgia
    '14 MGM 4WD RC
    Probably just a fluke. I'd give it a couple more tanks before I started looking into it.
  4. Feb 25, 2016 at 4:42 AM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    Did you get the muffler bearings lubricated? Additional friction in the bearings could be causing additional rolling resistance and increased engine load.
    TacoEngineer23 likes this.
  5. Feb 25, 2016 at 4:45 AM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    How do you track MPGs? Maybe the dealer, or whoever changed the oil, zeroed the mileage trip meter when they cancelled the oil change indicator which makes it look like you did less miles on that tank of gas. That's if you track the mileage per tank with your trip meter.
  6. Feb 25, 2016 at 5:02 AM
    cllowe24
    Mid Tennessee
    2015 access cab
    Dealer did it and I reset my trip myself. The muffler bearings are good. I have them changed when they do my blinker fluid :thumbsup:
    jasonct likes this.
  7. Feb 25, 2016 at 5:08 AM
    Pigpen
    Northwest Montana
    Did they do any other work? Maybe they unhooked the battery and reset the ECU..?
    It could be any of many variables unrelated to the oil change.
  8. Feb 25, 2016 at 5:10 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Never had a problem mpg-wise with muffler bearings, would guess 15w-45 blinker fluid (heavier) or they lubed the tires (less traction).
  9. Feb 25, 2016 at 5:11 AM
    cllowe24
    Mid Tennessee
    2015 access cab
    No just oil change
  10. Feb 25, 2016 at 1:03 PM
    Pushincaskets
    Pushincaskets Well-Known Member
    High Point, NC
    07 PreRunner DCSB
    4" Maxtrac Spindles, Dakars and extra leaf, SOS Concepts bed rack, Lund tonneau cover, RTT,
    This type of thing usually only happens with 3rd Gen owners.
  11. Feb 25, 2016 at 3:35 PM
    3coma
    3coma my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    Did they adjust your tire pressure lower possibly?
  12. Feb 25, 2016 at 3:48 PM
    cllowe24
    Mid Tennessee
    2015 access cab
    No pressure is good.
  13. Feb 25, 2016 at 7:35 PM
    TacoTaco15
    TacoTaco15 Well-Known Member
    Jake
    VA
    2015 MGM DCSB PreRunner 2.7
    As someone else mentioned, one week worth of gas isn't anything an average, and it certainly isn't anything to worry about. I'd give it at least a few tanks to see what the average is and see if it has been affected.
