MPG 2024 Tacoma Pro
Discussion in '4th Gen. Tacomas (2024+)' started by U.P. Tacoma, Feb 9, 2025.
  1. Feb 9, 2025 at 3:25 PM
    U.P. Tacoma
    U.P. Tacoma [OP] New Member
    2024 Tacoma Pro
    What king of MPG are people seeing on the 24" I force max in a Tacoma Pro.I can't get over 14 on the highway in Eco mode.
  2. Feb 9, 2025 at 3:28 PM
    TS4x4
    TS4x4 Well-Known Member
    2018 TRD Offroad
    Friday was two days ago
  3. Feb 9, 2025 at 4:21 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    How many miles are on your odometer?
  4. Feb 9, 2025 at 4:54 PM
    U.P. Tacoma
    2024 Tacoma Pro
  5. Feb 9, 2025 at 6:00 PM
    CrispyTacoLover
  6. Feb 10, 2025 at 2:30 AM
    Beater1
    Beater1 Active Member
    2024 Tacoma TRD Pro
    I'm at 5000 miles on my pro and I get around 16. I don't use eco and occasionally use sport.
  7. Feb 10, 2025 at 5:54 AM
    Taco2GR86
    Taco2GR86 Well-Known Member
    2021 TRD Pro 6MT [sold]; 2024 TRD OR 6MT
    Drive Mode should make no discernible difference for highway driving. It changes throttle mapping and reduces HVAC intensity. At constant speeds, neither of these should have any impact on MPG.
  8. Feb 10, 2025 at 6:23 AM
    Snakepilot
    Snakepilot Well-Known Member
    Tucson, AZ
    2025 Tacoma TRD Pro
    TRD Jon talks about only getting 18.4 from his Pro (with <1,500mi) but says it totally his fault because he feels like he's driving a race car and isn't driving it easy.
    If you are only getting 14 on the highway (and that's what the computer is also saying) then something is wrong. Easy to have a Toyota tech ride in the car for a couple minutes with the computer displaying 14 for them to agree it's not right.
    batacoma likes this.
  9. Feb 10, 2025 at 6:54 AM
    Johnny919
    Johnny919 Well-Known Member
    Long Island, NY
    2006 Honda Pilot EXL 4WD
    Try normal mode or taking it out of eco mode. Also need to wait until you have more miles, it's still breaking in.
  10. Feb 10, 2025 at 7:15 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    My impression of turboed motors or probably anything with low end torque you are going to want to get in the throttle. The other week I was coasting up to the speed limlit, had to be on the gas as I was going up the ramp. Exterminator truck in the right lane it wasn't a Tacoma. Behind me in the left lane was an ecoboost presumably a 3.5tt as it was a 4dr with a longer bed. Next thing the ecoboost is next to me and right behind the exterminator truck. There wasn't anywhere for the eb to go. Had there been a 3rd lane that truck could have easily passed us both. The low end torque will have you wanting to use it, that will come at the price of fuel economy.
  11. Feb 10, 2025 at 7:34 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    500 miles isn't enough to come to any conclusions. Most engines do better after a few thousand miles. It's not a good idea to drive it like grandma when breaking in the engine. Drive like you stole it for a while at varying speeds. Some city, some highway. Once you get 2000-3000 miles on it get it out on a long road trip and see what it does. By long road trip I mean at least 2 tanks of gas.
    Don't trust the onboard display, at least not yet. Some vehicles are right on the money, my 2014 F150 has never been wrong by more than 1/2 mpg and most of the time is exactly what I get manually. Our Explorer is always off by 2 mpg and the Honda we used to have was off 4-5 mpg every time. Check it manually for a few months to get a feel for how close your truck will be.
    The driving mode can make a big difference in fuel mileage, but not always the way you think. Sport mode keeps it in lower gears longer and doesn't even allow it to go into the highest gear. If you're driving at a constant speed under 50-60 mph Sport mode will probably give you better mpg. Same when driving in hilly terrain or mountains.
    Eco quickly upshifts and tries to keep it in the highest gear. That's not always best for fuel mileage. If the engine is in a gear that's too high and the engine is running low rpm's the engine is actually working harder. Sometimes more engine speed uses less gas. If you're running 70 on level ground with no load Eco is good.
    Johnny919 and CrispyTacoLover like this.
  12. Feb 10, 2025 at 7:48 AM
    Vitamins
    Vitamins Well-Known Member
    2024 TRD OR
    I've never seen a vehicle that had such a wide discrepancy between the reported fuel economy numbers from the EPA and the real life fuel economy numbers.
    5000 miles on my truck, it's an off-road it's not the pro, I get 17 to 18 highway.
    Eco mode, normal mode, it doesn't matter. It's just kind of dismal. I've tried all the different modes. Normal may be a little bit better than Eco. I don't know. I don't notice any difference.
  13. Feb 10, 2025 at 8:10 AM
    batacoma
    batacoma Truck Wars
    I'm sure the EPA or who ever did the testing used similarly equipped trucks. The 4G is a heavy truck, it's aluminum but the drive shaft looks the same size that's on a 1/2 ton the aero on the Tacoma might be the worst out there although probably not much different than any other TC midsize, 1/2 ton areo is just better overall. Being a 4cyl it's probably going to take a little more energy/fuel to get things moving over something with more displacement.
  14. Feb 10, 2025 at 9:37 AM
    SchwarzeEwigkt
    SchwarzeEwigkt Well-Known Member
    Central NY
    ‘24 Tacoma TRD Sport 4x4, Solar Octane
    You guys gotta get this out of your heads. The number of cylinders has no correlation with the energy/fuel required to "get things moving." More cylinders is not necessarily more betterer.
    Flori-duh Taco, Newwt, JB_TN and 2 others like this.
  15. Feb 10, 2025 at 9:49 AM
    CrispyTacoLover
    I wish I had a view across all 2024 Tacomas sold, not just the small sample at fuelly.com
  16. Feb 10, 2025 at 10:04 AM
    Hogleg918
    Hogleg918 Well-Known Member
    Oklahoma
    Ranger Raptor, sorry TW
    I don't get why semi trucks use I6 diesels, clearly they should be running V12's because more is better! :rofl:
    I laugh at all the YouTube comments on 6G 4Runners complaining about the "4 banger" and same for all the 1/4 ton trucks on the market as well. So many people out of touch with reality.
  17. Feb 10, 2025 at 10:06 AM
    SchwarzeEwigkt
    Central NY
    Here, have another datapoint.
    I'm averaging a bit over 18 in mixed driving. The cold weather and snow has dropped it down from about 20. Running 87AKI fuel with an unknown but indicated "up to 10% ethanol content" fuel. I've only got about 3200mi, though. Ain't even close to broke in yet. It got set to ECO a few weeks ago to make it a little more manageable in the snow (gawd do these tires suck). Happily, I'm doing about the same fuel economy wise as I was with the Subaru Legacy 3.6R I used to drag about town.
    PDKTaco likes this.
  18. Feb 10, 2025 at 10:17 AM
    Vitamins
    2024 TRD OR
    I don't know what they did, I don't know how they did it, but I suspect Toyota figured out some sort of secret sauce to perfecting those test circuit fuel economy numbers for the window sticker certification.
    thefinalstraw and batacoma like this.
  19. Feb 10, 2025 at 10:23 AM
    batacoma
    batacoma Truck Wars
    If you take a 2.3t4 Ranger and a 2.7ttv6 Ranger the 2.7 is going to take less effort to move same mas. The 4cyl going to have to produce more energy and use more fuel making that energy. The difference in fuel consumption is going to be marginal. Between the two Ford engines how could this be proven or disproven.
    I have a 2.7tt v6 now and had a 3.5tt v6 both 337 gears and both 145" wheelbase. The 2.7 takes more energy to move the same mass as the 3.5, the 3.5 got slightly better fuel econmy because the motor took less energy to make the same power. It's marginal and almost not noticeable at all but there's a difference.
  20. Feb 10, 2025 at 12:08 PM
    tactrac
    tactrac Well-Known Member
    2024 TRD Off-Road
    TRD OR (not Pro). 10165 miles tracked in Fuelly: 21.4 mpg.
    CrispyTacoLover likes this.
