Moving to Alaska - Engine Heaters
Discussion in '1st Gen. Tacomas (1995-2004)' started by ssoulssurfer, Jan 20, 2020.
  1. Jan 20, 2020 at 9:26 AM
    ssoulssurfer
    ssoulssurfer [OP] Well-Known Member
    1998 Tacoma 4x4 SR5 TRD MANUAL TRANS 3.4L V6
    2.0 FOX COILOVERS FRONT, 5100 BILLSTEINS REARS
    Finally got a job in Alaska, now I need to install an engine heater before leaving.
    I'm thinking I want to do an oil pan heater and a block heater with my battery tender, for a few hours when it's cold out to make sure and get a good start.
    I measured the bottom of the oil pan and it was only like 2-3 inches each way of flat area. I've seen some people put it on the side of the oil pan, but looks kind of tough to get a grinder wheel in there to take off the paint during install.
    What are some sizes and brands that people have used with good results for the V6?
    Some people have mentioned it takes several hours with theirs to heat up (obviously depends on ambient temp)?
    I want to get this, but need to go re-measure the oil pan: https://www.amazon.com/gp/product/B07H361JF2/ref=ask_ql_qh_dp_hza
    Otherwise I'll put this, with a block heater I figure should be fine: https://www.amazon.com/Zerostart-34...words=zerostart+3400061&qid=1579539823&sr=8-3
    Both are thermostatically controlled.
    Where have people mounted coolant block heaters? Any good brands for that?
  2. Jan 20, 2020 at 1:06 PM
    MagtechPA
    MagtechPA Thor
    Pittsburgh, PA
    Get a battery tender for sure, they are great. I'm not sure if I would be comfortable using a grinder wheel to remove the paint from the oil pan... seems potentially disastrous. Can't you just clean it really well with a scotch-brite pad and some degreaser, then hit it with denatured alcohol?
    I had a block heater (coolant) as a factory option on a car I used to own, and it was great. It felt like the cold starts were much easier on the engine.
    Taco critter likes this.
  3. Jan 20, 2020 at 2:23 PM
    Old n' slow
    Old n' slow Well-Known Member
    Oak Island, N.C.
    2000 Tacoma 2.4 5 speed flare side
    I had the orange heating pad on my Mercedes 300D oil pan for years, that plus a timer on the 120 V outlet set to come on a few hours before going to work at 5 am. It worked great up in the northern winters.
  4. Jan 21, 2020 at 6:58 AM
    Arctic Taco
    Arctic Taco Firefly, Serenity Ed. -Arctic Taco, a slow build
    Denali Park, Alaska
    98 Tacoma Xtra Cab DLX, 85 Toyota LWB 4x4
    dents and missing bits, built in the Gravel garage, hillbilly trained mechanic…
    I would go with a zero start on the side of the oil pan. Depending on where you are going that may be enough, if you’re going to Fairbanks or up into south central then I would add a battery blanket, and a freeze plug heater. When I had my motor swap done, the shop set me up with a pan heater mounted on the left side of the oil pan, clean it good and use high temp silicone. And welcome to the great land.
  5. Jan 21, 2020 at 7:05 AM
    ChiveOn
    ChiveOn City Slickin' Redneck, I wear a suit with a mullet
    A BC Boy in Calgary
    2013 MGM DCSB TRD Sport 6spd
    Plasti-Dipped Emblems, Tonnopro Tri-fold toneau cover (for winter use only), AVS in-channel visors, Ultra Gauge, Tepui Kukenam RTT, Muteki Trail Hog 285/70/17, Pop N' Lock, Bilstein 5100's in the front set at .85 with Eibach coils, Bilstein 5100's in the rear with a Toytec AAL. Toytec drivers side spacers, Toytec diff drop kit. All Pro u-bolt flip kit, TJM Compressor (permanently mounted), Custom rack for the RTT over the bed, Tepui Kukenam RTT, Toyota Bed Mat, Cobra 75 WX ST CB Radio, and a lot of gear behind the seats.
    Not in Alaska but Canada, so I still know the cold.
    I only have the OEM block heater and it is perfect. My truck wasn't plugged in last week when it was -40 (Celesius) here and my truck didn't hiccup once. Once the truck is running it takes 10 minutes for it to warm up to operating temperature. The main thing is making sure your battery is healthy and has a high CCA.
    Unless you are going away for a month in the dead of winter you don't need a battery tender, a simple plug in block heater is more than enough.
    No37 likes this.
  6. Jan 21, 2020 at 7:58 AM
    ssoulssurfer
    Ok awesome thanks everyone. My truck will be in anchorage while I'm working in Nome, so won't be so cold like fairbanks or something. I was trying to find the oem block heater (which is from canada apparently) but none of the dealers can get it now they say. Has anyone installed a different brand, and how did you do it?
    I'm gonna take the skid plates off tomorrow and get back in there to take a look. I'll try to use a scotch brite pad to take the paint off (is that enough?), and see if I would be able to mount that bigger zerostart pad on the side of the oil pan then.
  7. Jan 21, 2020 at 11:20 AM
    Arctic Taco
    Denali Park, Alaska
    That would work fine, Anchorage is kinda like a colder Washington so you should be golden.
    SierraMare likes this.
  8. Jan 21, 2020 at 11:47 AM
    ssoulssurfer
  9. Jan 21, 2020 at 12:03 PM
    CassND
    CassND Well-Known Member
    Cass
    North Dakota
    2020 Tacoma DCLB
    Stock
  10. Jan 21, 2020 at 12:05 PM
    CassND
    Cass
    North Dakota
    2020 Tacoma DCLB
    Stock
  11. Jan 21, 2020 at 12:39 PM
    Arctic Taco
    Denali Park, Alaska
    A Webasto might be overkill for his uses down on the Kenai, kinda tropical down there, wet snow and lots of ice, and lots of inexperienced drivers- lots of new military folk, that have never really dealt with the crappy road conditions there. Then of course everyone is in a hurry....
  12. Jan 22, 2020 at 7:20 AM
    ssoulssurfer
    Thanks, I'm just looking for something I can plug into with an extension cord from the garage.
  13. Jan 22, 2020 at 7:45 AM
    CoWj
    CoWj Lost and Found at the same time.
    Wyatt
    Northern CO
    Burt: 1998 2.7 Regular 5 speed 4x4
    Bilstein 5100, ARB Bumper, Warn VR EVO 8, 34x10.50 Toyo 4.88s ARB Locker
    I live in one of the coldest places in the lower 48, and I've started my truck in -20° without too much issues. Biggest thing it starting it with the clutch pushed in. The trans gear oil becomes so thick at that temp you can move the truck forward even in neutral. You have to hold it in for a little bit before you can release it. Or you may stall the engine.
    A battery with good CCA and a block heater are good to have. But I know a lot of people here with just pan heaters and it works fine for them even in -30, -40 temps. I personally don't have either but don't start my truck below -25°.
    Colchicine likes this.
  14. Jan 22, 2020 at 8:01 AM
    ssoulssurfer
    Aren't you concerned about long term wear and tear from cold starts with thick oil?
    Gen3TacomaOBX likes this.
  15. Jan 22, 2020 at 8:18 AM
    CoWj
    Wyatt
    Northern CO
    I've taken apart engines that have been sitting for a couple weeks. And I was shocked at how much oil was still coating everything, so sitting over night or for a day or two doesn't seem to make the engine "dry" of oil. While the oil is think, Toyota does recommend different oils for different temps in the owner's manual so they seemed to have designed them for starting in the cold. I do want to add a pan heater but I don't have access to a outlet where I live to be able to plug it in consistently.
  16. Jan 22, 2020 at 11:16 AM
    Mooseak907
    Mooseak907 Active Member
    2003 3.4 Toyota Tacoma
    2.5 ext king coilovers - ome leafs - ome nitrocharger rear shocks- 18” magnaflow exhaust - deck plate intake
    I’ve been living in anchorage for +10 years and to be honest our Tacoma’s start up every time just fine w/out block heaters. In anchorage and everything below anchorage at least, only dips down below 0 for maybe a month and as long as you start your truck every other day you’ll be fine. If you’re going north of anchorage different story, gets drastically colder further north you get.
  17. Jan 22, 2020 at 11:17 AM
    Mooseak907
    What I do recommend for driving in Alaska is a hood deflector, good m/s tires and have the sipped, and good lights. I’m still running stock but next back Friday I’ll be retrofitting my headlights.
  18. Jan 22, 2020 at 11:26 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    I’d suggest gettin’ the factory recommended block heater. Warms the engine water jacket & don’t forget a cold weather rated extension cord. If you can’t find a good one, then make one up.
  19. Jan 24, 2020 at 9:36 AM
    ssoulssurfer
    I got the Zerostart 3.5 x 4.5 inch one from above. Fyi I got in there looks like there's enough space on the passenger side of the oil pan to mount it, ~4x4 inches of space. I don't want to take a chance and want to install something to help oil get warmed and lubricate.
    To get the paint off, people say scotch brite, are you talking about the metal dish cleaning thing, or a specific type sand paper? With brake parts cleaner of course.
    Also, it comes with small tube of silicone sealant for edges, just in case if I run out, which would be good to get?
    CoWj likes this.
  20. Jan 24, 2020 at 10:01 AM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    There's an OEM block heater for Gen 1 Tacomas? News to me! I'd love to learn more about that.
    Update: A discussion from a few years ago of this Canadian-market accessory for Gen 2 trucks. I've had rental and other cars in Central Finland with a similar heater plug.
    https://www.tacomaworld.com/threads/oem-block-heater.398333/
