Moving the rear view mirror
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SendinTheCavalry, May 23, 2021.
  1. May 23, 2021 at 8:24 PM
    SendinTheCavalry
    SendinTheCavalry [OP] Well-Known Member
    PNW
    2019 DCSB OR
    Anybody selling a bracket to move the rear view mirror up? Maybe someone smarter than I came up with a diy solution
    Thanks in advance:fistbump:
  2. May 23, 2021 at 8:30 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    There are brackets to raise it, but before we go into that, I have to mention something that catches a surprising number of people.
    The mirror has two points of articulation. It raises up almost to the headliner, stock.
    You are aware of that, right?
  3. May 23, 2021 at 8:35 PM
    SendinTheCavalry
    PNW
    2019 DCSB OR
    Caught me by surprise too..
    Just screwed with it and I see what you mean, thanks for the tip. What would I do without tacomaworld:rofl:
  4. May 23, 2021 at 8:36 PM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    :D
    No problem. Seriously, you would be surprised how many people don't realize that.
    Jaragon, StayinStock and waltuo like this.
  5. May 23, 2021 at 8:51 PM
    waltuo
    waltuo Well-Known Member
    Toyotas
    :anonymous: Found out a year after owning.
  6. May 24, 2021 at 3:16 AM
    jt13077
    jt13077 Well-Known Member
    CNY
    2021 Black DCSB TRD OR
    I had no idea, gonna go look at it now! :thumbsup:
    Rock Lobster[QUOTED] likes this.
  7. May 24, 2021 at 3:26 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    If you decide that's not enough for you, and or want to add and action camera mount as well I have the Bird Dawg Industries Mirror Riser with Ram ball mount and it has been great.
    I highly recommend adding additional 3M trim adhesive to it though as your end up giving the mirror a lot of leverage on the mount and then more weight as well and without the additional support it can unexpectedly remove the mount directly from the glass for you.
    tonered and Rock Lobster like this.
  8. May 25, 2021 at 9:10 AM
    SendinTheCavalry
    PNW
    2019 DCSB OR
    Happy to hear I’m not the only passenger on the struggle bus:wave:
  9. May 25, 2021 at 9:29 AM
    NEIPA27
    NEIPA27 Well-Known Member
    Florida
    2020 OR
    I can't wait to get home from work and try this.
  10. May 25, 2021 at 9:35 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The riser is a champ.
  11. May 25, 2021 at 4:58 PM
    OregontoBajaCA
    OregontoBajaCA Well-Known Member
    2017DCLBOR
    Another trick that works for plain (without a compass) rear view mirrors on a few cars I’ve owned is to rotate the mirror 180 degrees bringing the pivot point to the bottom of the mirror, thus raising the mirror upward for more sight line clearance.
    tonered and NorrinRadd like this.
  12. May 25, 2021 at 6:52 PM
    MrBrooks
    MrBrooks Well-Known Member
    Midwest
    2018 DCSB - 2021 Rav4
    I figured that one out awhile ago when I didn't see a semi coming on from an on ramp. Damn mirror blocked the whole thing! Got home & shoved it up to the roof
    vivid02 likes this.
  13. May 25, 2021 at 6:55 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Does not play well with the Off Road’s Crawl Control setup from what I read.
  14. May 25, 2021 at 6:56 PM
    playdixie
    playdixie Miss'ippi fella
    Mississippi
    2016 Blazing Blue TRD Sport DCSB 4x4
    Wait a minute!! The mirror will just go up???
    I swear I've missed out on this if true
  15. May 25, 2021 at 6:59 PM
    soggyBottom
    soggyBottom Well-Known Member
    Is this all 3rd gens?
  16. May 25, 2021 at 7:07 PM
    Grindstone
    Grindstone Requires Adult Supervision
    My 2020 has it, even with the big box.
  17. May 25, 2021 at 7:09 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Yep. I had one of those brackets to relocate the mount higher in my 2nd gen and recovered that when it was totaled out and insurance took ownership, was starting to take the mirror in my 2016 off so I could install the bracket and realized that it would move up to just about touching the the overhead console without any changes.
  18. May 25, 2021 at 7:12 PM
    playdixie
    Mississippi
    What kinda black magic is this???:rofl:
    But seriously, I did NOT know this. And I just replaced the OEM mirror with Gentex one since can open garage with it.
    Well, I learned something new today.
    Jaragon likes this.
  19. Jul 4, 2024 at 1:50 PM
    Jaragon
    Jaragon Active Member
    22 TRD Sport - Lunar Rock
    Skid plate for oil changes Cat shields for theft Snail Armor and pop lock tailgate LEDs and custom Inferno accents inside
    Landed here after searching for a relocation bracket or something ‍♂️ thank you!
  20. Jul 4, 2024 at 3:18 PM
    Xsjadows
    Xsjadows Well-Known Member
    Josh
    South Bay Area
    2020 Quicksand Tacoma TRD Off-Road DCSB
    King 2.5 Front/Rear Method 701 17s w/ Geolandar M/T g003 33s
    Always learning something new here :thumbsup:
