Moving back up camera from mirror to radio??
Discussion in 'Audio & Video' started by chadlogan112, Nov 1, 2015.
  1. Nov 1, 2015 at 6:08 PM
    chadlogan112
    chadlogan112 [OP] Well-Known Member
    Chad
    Florida
    Bilstein 5100 Front and Rear, Maxtrac Spindles, Icon AAL, 285/60/18, 18x10, 5% Tint, K&N Intake
    Have an 09 Tacoma, with the camera in the rear view mirror; is it possible to wire it to my new sony touchscreen instead? Any help is much appreciated!
  2. Nov 2, 2015 at 9:14 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    These are threads that I used when I connected the existing OEM camera in my 2009 to my JVC unit. My truck didn't actually have the backup camera option, so I didn't have the special mirror (only the camera was factory installed). I recall that some people successfully wired the factory camera to BOTH their stereo and the special mirror. Be aware that the mirror currently supplies 5vdc to the camera, so if you do disconnect the mirror from the circuit you will have to build a 5vdc supply. Look through the threads and you should be able to find all the info you need:
    https://www.tacomaworld.com/threads/oem-camera-connection-below-dash.30889/
    https://www.tacomaworld.com/threads/noob-help-with-backup-camera.149448/
    http://www.toyotanation.com/forum/2...tory-rear-view-camera-aftermarket-stereo.html
