Moving a Pool Table - One Piece Slate
Discussion in 'Off-Topic Discussion' started by weeksz, Jan 7, 2020.
  1. Jan 8, 2020 at 9:09 AM
    weeksz
    weeksz [OP] Well-Known Member
    Adam
    Traverse City, MI
    2017 DCLB Limited
    Stickers mostly
    Well unfortunately its not really an option, put a deposit on it for them to hold it. As they may always be free or damn near, they I'm sure they are always a PITA to move, too.
    Thanks for the advice guys, I'll report back when I get it moved, however that may be.
  2. Jan 13, 2020 at 6:06 AM
    weeksz
    Adam
    Traverse City, MI
    2017 DCLB Limited
    Stickers mostly
    Just an update, the pool table move was a success. 5 guys for the removal and 4 for the move into my basement. We ended up just taking the legs off and moving the table and the slate all in one. We used moving blankets to slide it on the ground into pisition on the stairs, then one lifted it one step at a time until we could slide it up the stairs. Once we got it on flat ground we used furnature mover straps with shoulder harnesses and walked it into the trailer (highly reccomend these). Would have been a breeze with 4 guys and no stairs. Couple of small scratches on the table but no drwall was damanged. The light even went up right where an existing fixture was. Was thoroughly tested saturday night.
    vssman, SR-71A, BassAckwards and 5 others like this.
  3. Dec 19, 2022 at 11:52 AM
    DarryJr
    DarryJr New Member
    Unfortunately, pool tables are not designed to be moved in one piece. You'll need to disassemble all the pieces and reassemble them at the new location. But if I were you, I'd hire a man with van services. They'll know how to transport it to avoid damage. Another option would be to rent a moving truck. However, in this case, you'll need someone strong enough to load and unload the pieces. In both cases, you'll need money and tolerance. Even more so if you don't have patience with movings, like me xd. However, the first plan seems to have more benefits.
  4. Dec 19, 2022 at 11:57 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Welcome aboard
    nobescare likes this.
  5. Dec 19, 2022 at 12:14 PM
    Clidarv
    Clidarv Well-Known Member
    Clinton
    2020 OR DCLB white
    Bed mat
    Good luck!
  6. May 23, 2024 at 5:25 AM
    Mack83
    Mack83 Well-Known Member
    Orlando
    2014 TRD OR DCSB Silver Streak Mica
    I'd hire someone to move the table piece by piece.
  7. May 23, 2024 at 5:29 AM
    Clay Darryl
    Clay Darryl New Member
    Clay
    2017 SR5 Red Tacoma
    I’ve moved one before and the best advice I can give is to disassemble it as much as possible. Remove the legs and secure the slate carefully, as it's the heaviest and most delicate part. However, it might be a good idea to hire specialized movers. Just read on https://threemovers.com/how-much-does-it-cost-to-move-a-pool-table/ about the aproximate costs and go on.
