Mouse proofing my Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by turkinator, Jul 23, 2021.
  1. Jul 23, 2021 at 5:51 AM
    turkinator
    turkinator [OP] Well-Known Member
    Ray
    SW Ohio
    2015 TRD sport double cab long bed
    Fiberglass shell level 17” wheels
    How do you keep mice out?
  2. Jul 23, 2021 at 6:07 AM
    Haole Toy
    Haole Toy Well-Known Member
    Mauna Kea, AZ
    '21 SR 4x4
    I use 1/4" screen over cabin intake and engine intake.
    gilligoon and Steve_P like this.
  3. Jul 23, 2021 at 6:11 AM
    VXEric
    VXEric Well-Known Member
    Eric
    Worcester, PA
    07 ACS V6 6 Spd TRD Sport
    265/70/17 ATs on 17x8"wheels and 0 offset Morimoto XB LED Fogs Reinforced tailgate 2011 Honeycomb grille URD Short Shifter and cue- ball style knob
    Try this.
    But seriously if you park outside or your garage has mice there isn't a lot you can to do keep them out of the engine bay. Putting a screen over the intake and the cabin air filter opening will at least keep them out of those areas. I put down a few traps around my garage with peanuts hoping to catch them before they made it to the cars, seemed to work OK but could take a while if there's a whole family of them.
  4. Jul 23, 2021 at 6:15 AM
    turkinator
    Ray
    SW Ohio
    I appreciate the responses.
  5. Jul 23, 2021 at 6:38 AM
    TacoFergie
    TacoFergie Well-Known Member
    Iowa
    I've heard/seen (working on cars in the past) many remedies but haven't found one that works 100%. The ones I've seen are irish spring bar soap, mothballs (but your truck will smell like grandmas house), dryer sheets (need replaced somewhat often, maybe once a month?) and I've seen some people put mouse/rodent poison in the engine bay. But the poison doesn't kill them instantly and then they could die inside the dash and create a lot of headache removing the carcass....
    lowmower likes this.
  6. Jul 23, 2021 at 6:50 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    hfjeff and JGO like this.
  7. Jul 23, 2021 at 8:38 AM
    JGO
    JGO Well-Known Member
    South Central Kentucky
    '14, 4 Cyl, A/T, Silver A/C
  8. Jul 23, 2021 at 9:05 AM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
  9. Jul 23, 2021 at 9:06 AM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    one of these
  10. Jul 23, 2021 at 9:40 AM
    dtaco10
    Dave
    I tried Mole repellent and at best it chased the moles away until it rained, then they were back. Now it's traps or one bite bait. With chipmunks, it's a live trap and pellet gun, no relocation. I don't want to make them somebody else's problem.
  11. Jul 23, 2021 at 3:31 PM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    It sounds silly but an outdoor cat helps 100%. I know you aren't supposed to keep them outside and all but here in AZ packrats are a huge problem.
    MGMDesertTaco likes this.
  12. Jul 23, 2021 at 3:40 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  13. Jul 23, 2021 at 5:14 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    There is a special rodent repellent tape you can wrap around wiring.
    You may want to look into that?
    Other than that, all I know is to park where mice aren’t.
    And I don’t know where that is?
  14. Jul 23, 2021 at 6:14 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    I tried the Irish spring soap once and the little bastard just took it and put in his nest, that was cleanest little bastard till I caught him on a sticky trap.
  15. Jul 23, 2021 at 6:23 PM
    TacoTuesday1
    FL
    you should ask how people keep out Marmots when camping above 10k' where they chew wiring
    I doubt many will know
    NachoTaco96 and jeminyned like this.
  16. Jul 23, 2021 at 6:27 PM
    TnShooter
    Deogee
    STOCK
    How?
    Some type of projectile, I assume?
  17. Jul 23, 2021 at 6:33 PM
    Clearwater Bill
    Billy
    Largo Florida
  18. Jul 24, 2021 at 8:27 AM
    GorgeRunner
    2005 PreRunner
    You can find them, or their close relatives, in much lower mountains. I had one sleeping on top of the engine cover and would not move. Eventually had to send it into low earth orbit. Don't like to hurt chipmunks with traps, they are just curious. Mice eat anything in sight, kill them all, they'll make more. Also super destructive are ground squirrels. They eat floors, walls, wiring, gardens, everything. 10-22 Therapy for them.
  19. Jul 24, 2021 at 8:49 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Couple tips:
    1.) Keep the interior void of ANY food, food wrappers, crumbs. This will serve as attractant.
    2.) Keep the interior void of ANY trash. This will serve as nest material.
    3.) Park in an open area. Mice do not like crossing open spaces.
    4.) Traps need to be placed OUTSIDE of the garage along a wall. Mice will travel along a wall. The trap bait will draw the mice outside of the garage.
    5.) Screen or close off the cab's air vents.
    6.) Use predator urine in the engine bay. Only need a little, their noses can detect a faint scent.
    7.) Clear the garage of all food (human, pet or other) and trash.
    8.) Hope none will venture to explore.
    Myths:
    cats, irish spring, high frequency sound, flashing lights....
    The mice are looking for their basic needs.....food, shelter. Remove both, then they look elsewhere.
  20. Jul 24, 2021 at 9:19 AM
    Oreo Cat
    Stupid ground squirrel started hanging out in the backyard, need to catch a snake and release it back there
