Mounting Pelican cases
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sneumeyer, Jul 11, 2013.
  1. Jul 11, 2013 at 2:56 PM
    sneumeyer
    sneumeyer [OP] Active Member
    Skyler
    Wyoming
    2013 DCSB TRD-OR Super White
    Blacked out emblems and grill, custom bedside decals, BHLM, blacked out tail lights, Relentless Fab bed rack with Yakima MegaWarrior cargo basket.
    I have two Pelican cases that I think are the 1500 size. I was wanting to use them for bed storage and I was wondering if anyone had any ideas on how to mount them in the bed. They have to be relatively easily removable because I use the full bed quite often. I just have them bungeed in there right now but would like something more secure and preferably lockable.
  2. Jul 11, 2013 at 3:21 PM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    Get creative with the bed rail system...
  3. Jul 11, 2013 at 3:38 PM
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    Drill 4 holes in your bed and 2 in each box( matching holes). Then use bolts to secure them to the bed. Use wing nuts to clamp the pelican cases down to the bed. Solved
  4. Jul 11, 2013 at 3:41 PM
    sneumeyer
    Skyler
    Wyoming
    Is the bed rail system strong enough to hold that kind of weight? In one of the boxes I have chains and jumper cables and other stuff so it probably weighs 40lbs.
  5. Jul 11, 2013 at 3:42 PM
    sneumeyer
    Skyler
    Wyoming
    That'll probably be what I end up doing. But then I have to remove all of the stuff in the boxes to get to the wing nuts at the bottom of the case. The best thing about this plan would be that if I locked the cases then they are secure in the bed.
  6. Jul 11, 2013 at 6:08 PM
    kai38`
    kai38` Well-Known Member
    Mount them to the rail system. You can buy the hardware that slides into the track and drill two holes each box running bolts thru inside box into lock nut in track.
  7. Jul 20, 2013 at 10:02 AM
    mipawlus
    mipawlus #332 Veteran Overland, #159 TTC, #69 in your heart
    Captain Poopypants
    Aggieland
    BROJAHAHAHAHA!!!!
    Rust and dents and squeaks
    i'd like to see pics when you get around to it! i've got a few pelican cases that i might like to try this with!
  8. Jul 20, 2013 at 10:05 AM
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    industrial velcro
  9. Jul 20, 2013 at 2:18 PM
    H0LLYW00D
    H0LLYW00D Well-Known Member
    I mounted some larger cases on a tray system that attaches to my bedslide track rails, I can move the whole tray forward or backward in the bed and by undoing 4 bolts i can removed the whole system in 10 min, I used the mounting point for the handle system on the cases so I didn't have to drill into them or into the bed or the bedslide. I should have pics shortly on how the system works.
  10. Jul 21, 2013 at 2:07 AM
    mipawlus
    Captain Poopypants
    Aggieland
    BROJAHAHAHAHA!!!!
