Mounting Pelican case or similar to roof rack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mashir, Jul 19, 2017.
  1. Jul 19, 2017 at 11:37 AM
    mashir
    mashir [OP] Well-Known Member
    Colorado
    2014 DCSB TRD Off-Road
    OME BP-51 full kit, SPC UCAs, FJ TRD Trail Team wheels in black, 255/85/16 Cooper Discoverer ST Maxx, All-Pro aluminum front bumper and IFS skid, Slee Off-Road silders and rear tire carrier bumper, Rigid and BD lighting, Baja Rack roof rack, Bruteforce Fab bed cage, CVT RTT
    Hey guys,
    Im hoping to find a solution to mount some storage cases to my BajaRacks roof rack semi-permanently. I've seen some people with Pelican cases mounted in such a way. I'm hoping to keep recovery gear up there, and ideally the case would be water resistant at least.
    Anyone done something similar to this or seen a solution that worked well? Appreciate the input!
    ChadsPride likes this.
  2. Jul 19, 2017 at 1:53 PM
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    I drilled holes through mine and bolted it down. Just use big washers so the bolt doesn't tear through.
    Tacoma’20 and Kyitty like this.
  3. Jul 19, 2017 at 5:08 PM
    mashir
    Colorado
    Awesome, thanks for the report. Have you run into water resistance problems after drilling the holes?
    What I'm most interested in is how people are attaching the case to the rack past the bolts themselves, i.e., what's holding it in place and on what sort of rack?
  4. Jul 19, 2017 at 5:09 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    This is what I plan to do with my Front Runner rack if it ever ships.
    FR racks have T-slots. Drop a nut in there and get a bolt short enough not to go through and crank it down.
    Dunno about Baja Racks.
  5. Jul 19, 2017 at 5:16 PM
    Capt. Obvious
    Darrick
    Gig Harbor
    '12 DCLB TRD
    No water issues thus far, and I live in Seattle. For extra security you could definitely put a little silicone on there after you mount it.
    In the case of my rack, the cross bars are made with Unistrut, so I just used standard Unistrut clamp nuts.
  6. Jul 19, 2017 at 5:18 PM
    Longboard1110
    Longboard1110 ...................
    San Jose
    A few things
    This, I have a Prinsu rack and it's fine. The holes are on the bottom so no water has got in.
  7. Jul 19, 2017 at 5:21 PM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    I drilled 4 holes into mine and made the stud go through the bottom of the case. (Basically flipped the bolt upside down.)
    My Prinsu has slots in it that I can slide a bolt head into so that works for my setup.
    As for water sealant, it hasn't been a concern of mine but I could find some kind of rubber washer to seal the hole off I suppose.
    TheLoki likes this.
  8. Jul 19, 2017 at 5:27 PM
    musher
    musher Well-Known Member
    Alabama(born) >(the world)>Alaska(now)
    2017 Tacoma
    I'd rather not think of all the $ spent :(
    I did this with U-bolts, no sealant but no water inside.
    3_TACOS_NEVER_ENOUGH likes this.
  9. Jul 19, 2017 at 6:13 PM
    mashir
    Colorado
    Thanks all! Yeah, I assume someone must make some sort of mounting solution for round bar racks, but haven't found it yet. Thanks all for the info about water resistance too.
  10. Jul 19, 2017 at 7:37 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    As a side note, I don't know what kind of UV stability a Pelican case has but I would think that they'd get a little cooked out in the sun after a while. Is anyone seeing that?
    You might consider a coating of rattle can paint on them.
  11. Jul 19, 2017 at 9:22 PM
    desertjunkie760
    Shane
    Check My Sig.
    Honestly, I'm not too concerned about it. I'm using the case for recovery gear storage and it's made for military usage. Cosmetics isn't really the purpose. They have lifetime warranty if the sun ever effects the integrity.
  12. Jul 19, 2017 at 9:34 PM
    musher
    2017 Tacoma
    I didn't know that part. I have had 3 that have circled the globe a few times in some harsh places. I have yet to have an issue with any of mine and I'm pretty rough on gear.
    Trey5150 likes this.
  13. Jan 23, 2019 at 6:35 PM
    3_TACOS_NEVER_ENOUGH Well-Known Member
    Various Locations: TX, CA, NC, AL, MS, and FL
    I may be reviving this thread but does anyone have any more pics or how to's?
  14. Jan 23, 2019 at 6:41 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Heavy bendable metal strap from Home Depot works well with holes drilled to add a lock,and you dont have to drill holes in the case.
  15. Mar 18, 2019 at 2:03 PM
    charlieyankee88
    charlieyankee88 Well-Known Member
    2017 TRD OR DCSB MT
    RADFLO Suspension, JBA HD UCAs, Mobtown low pro bumper, Mobtown bolt-on sliders, Engo SR10s, SCS Stealth 6, AFE CAI, URD Spec U, OV Tuned, Gobi Rack, Softopper, CMC
    Pics?
  16. Mar 18, 2019 at 2:27 PM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    What are you trying to attach it to? Yakima, Thule, etc. sell the parts for their rack systems including the clamps. Simplest way is to measure, drill your holes and mount some clamps. I'd use a neoprene washer on the inside just to be on the safe side. If you've got round bars, some conduit clamps would be an easy option but it wouldn't be hard to bend your own. If you want them more easily removable you could use something like the Caribou Cases mounting system.
  17. Mar 18, 2019 at 2:44 PM
    charlieyankee88
    2017 TRD OR DCSB MT
    Mine is going on a Gobi rack. I would like it to be easy to take on and off.
    Cross bars are off. So I am mounting to the mesh deck.
  18. Mar 18, 2019 at 6:04 PM
    Bajatacoma
    SC
    Gotta say, that's one of the funniest ways I've seen to take a picture of a roof. LOL
    That expanded metal is going to be kinda tricky. I can think of a couple of ways loosely based off other designs I've seen but I don't know if I can describe them. I'd probably just make a couple of plates that had two bolts welded through them (or you could tap the holes and thread them in). Put this under the expanded metal with the threaded part sticking up. Have another plate with matching holes that you dropped on top of those bolts then put nuts on to hold them in place. Now mount a piece of angle iron, again with matching holes, on the ends of your cases. Use nuts, nyloc nuts, wing nuts or you could even use bolts the same size as Yakima (for example) uses and then use an accessory lock.
    Just throwing ideas out there.
  19. Mar 18, 2019 at 6:30 PM
    charlieyankee88
    2017 TRD OR DCSB MT
    Thanks
  20. Mar 18, 2019 at 6:44 PM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    BalutTaco, Naveronski and outxider like this.
